Page 936 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Hitman928
6,751
12,481
We can rule that out I think. Wouldn't have lasted 20 days unless there's some process that causes unconductive crap to turn into conductive crap through heat over a period of three weeks. Most likely ASROCK BIOS defaults or EXPO voltage handling are to blame.
If there's a bent pin, it may not cause issues at first, but after many thermal cycles the pin continues to deform until it gets too close to a neighboring pad/pin and then the problem becomes spectacularly apparent.
Jan Olšan
617
1,240
smells like FUD
Well, it is conceivable Nvidia for example could try try to divert attention due to their melting issue (or at least give fans ammo for whataboutisms cope), but I *really* doubt it. Such conspiracy explanations are unlikely. Maybe more to be expected from a single silly fan (think Userbenchmark guy), but in that case the dude would have to sacrifice a lot of money.
It's likely just normal failures. Hidden manufacturing fault, board somehow frying the CPU (wouldn't be the first time on AMD or Intel platforms - remember V-Cache is voltage sensitive)...
Thibsie
1,170
1,376
I suggest sacrifying the dude instead :D
MS_AT
920
1,842
I think from the chips and cheese interview, most is provisioned to the graphics. They kept saying something like all the fabric goes there.
They said in the interview that Halo CCD has the same BW (actually it's higher as Granite Ridge has 32B/c read and 16B/c write BW between CCD and IOD, and Halo is supposed to have 32B/c BW for both R/W) that desktop parts, so both CCDs together should be able to reach 200GB/s read. It makes little sense for write to be able to reach that and read not being able to do so, therefore I would wait for tests with final bioses before reaching any conclusions.
therealmongo
135
314
Ooouh, now you got me worried, not 9800x3d but 7800x3d, a friend gave me an Asus x670e Gene that they had damaged several pins. I managed to straighten them and am using the system as my daily. Its been functioning fine since I repaired it and thats around 6 months ago.
TimCh
59
67
We already knew the CPU read bandwidth would be limited by the fabric, the low score isn’t really a surprise.
Edit: Yes, it is strange that read is so far below the write bandwidth.
19,204
No, that latency is a disappointment.
That's what you get with LPDDR any version. Only way to avoid that is to not use LPDDR. Or come up with some sort of FrankenDDR tech that uses both DDR4 and LPDDR5 together in such a way that low latency is provided by the former and high bandwidth by the latter.
Reactions: MadRat
DavidC1
2,062
3,200
140nS is really high if that's accurate. Most mobile systems are in the 100nS range. It makes Arrowlake look very good.
Reactions: Bahari93
Schmide
5,768
1,065
It's lpddr5x which should have high latency high bandwidth, quad or octo channel. I think the system can do weird subchannel dual quad or something which is probably what were seeing here. Video gets a dedicated quad channel plus the MALL cache. CPU and GPU share the other quad channel.
Tuna-Fish
1,688
2,581
Doesn't work like that, the channels are not dedicated.
Geddagod
1,648
1,680
7ish hours until this, I hope slides get released online soonish.
Very curious about what claims they have about the CCX power vs Zen 4, V/F curve, and CaC numbers they have about Zen 5. I don't think AMD has yet to release a gen since zen where even at low power their next gen core hasn't had a perf/watt increase vs their past gen, but this doesn't seem to be the case with Zen 5.
fastandfurious6
864
1,018
where's this? how to check for slides?
fastandfurious6
864
1,018
btw re:9800x3d exploding (lmao)
gamersnexus published this 1 month ago
and there's evidence of shills spreading FUD of "exploding AMD chips!!!" (lmao) on reddit
then 1 week ago in light of brand new highly anticipated nVidia 5900 meltdowns, suddenly there's several new reddit posts claiming dead/burned 9800x3d, out of nowhere, all at once
#1 market cap company in the world is no joke after all
gamersnexus shows up and offers full retail price to buy the burned cpu/mobo and test them out
the claimants more or less disappeared and the topic died down
reddit is ideal grounds to create and spread FUD
