Page 872 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
StefanR5R
6,821
10,905
Steve and Tim are already saying 10% more performance for 10% more money is bad. So yes indeed everyone, the measly $30 price hike is the lead talkingpoint.
If reviewers want to relate performance to MSRP, and do so specifically for application scenarios in which the hardware-side of the performance is mostly determined by the combo of GPU & RAM & CPU, then they should put the performance delta into relation with the [GPU MSRP & RAM MSRP & CPU MSRP] delta.
Josh128
1,505
2,256
There's another screenshot from that chiphell.com link, but yeah not sure if these two screenshots were from same machine.
It shows 1.248v @ 5490Mhz.
another gaming screenshot, also from that link:
Yeah the HWinfo shows multiplier of 55x for a 99.8MHz BCLK, so that is def 5.49 GHz OC. Butt the 5.145 game shots are probably a 54x multipler with a 100.3 MHz BCLK or something.
Makaveli
5,004
1,600
Last time I looked into it a lot of AIO's were worse than good air coolers.
Nah been running a 360mm AIO on AM4 since 2019 zero issues. Will finally have to replace it when I go AM5 but still going with a newer 360 :)
I do agree air cooling is fine with X3D chips.
Reactions: lightmanek
MS_AT
920
1,842
Btw, does anyone know, why, despite AMD listing support DDR5-5600 supported on Strix-Point, there were no models to date announced with socketed DRAM? I mean everything from MiniPCs to gaming laptops? I would understand the decision to stick to soldered only RAM for models depending on iGPU, but if dGPU is present why force soldered DRAM?
SteinFG
739
873
DDR5 and LPDDR5 are different memory standards, AMD clearly prioritized LPDDR5 support. DDR5 is coming later if I had to guess.
poke01
4,691
6,028
That would be up to the OEMs, not AMD, wouldn't it?
Unless AMD put restrictions or a limit until a certain time. The fact no one released a DDR5 is telling.
My guess is Framework might be the company to use DDR5 next year
maddogmcgee
411
425
Anyone know when the review embargo is supposed to lift? I thought it was the 6th with release on the 7th. Its almost the 7th here already.
Reactions: Racan
sl0519
58
151
66
Still two hours to go but here's one review to relieve some boredom for yall while waiting~
edit: can someone do the math and calculate the avgs out?
edit 2: it's 10% on avg faster than 78x3d
techjunkie123
161
354
Eyeballing it id say about 5-10% on average. But the lead should grow when the 5090 launches.
maddogmcgee
411
425
10 percent (mostly due to higher freq I guess ) is much higher than a lot of people were expecting a few weeks ago. Will be interesting to see the gain from my 5800x3d but I think I am sold.
Reactions: DAPUNISHER
In2Photos
2,625
2,794
That's easy, soldered RAM means you will need to replace the item rather than upgrade. OEMs/SIs don't get revenue when you upgrade.
MS_AT
920
1,842
It also means you turn off some of your potential clients but maybe in the end it's a successful strategy for them.
