Page 847 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Joe NYC
4,275
5,958
I have to say, it's a super interesting concept. I can't really imagine it being used in server or desktop CPUs, would they really route hundreds of watts of power (total) through DDR chips?
But I'd really like to see a mobile chip where the entire CPU is placed on top of the RAM. This looks like the next logical step up from the "memory on package" era, offering power (and potentially latency) improvements.
However, it's worth noting that not every exciting packaging patent ends up being used. Remember this one:
https://www.freepatentsonline.com/20210097013.pdf
I think the DDR label there is just from DDR memory controller on the AIB base tile.
Reactions: lightmanek
MadRat
12,010
320
Longer layout times to squeeze out performance on each process perhaps? Seems like if you were to reimagine things then layout would maximize distribution of power management and heat production first with the more focused on shared access at the IO level also a high priority. You should be able to do several improvements at same time, just not as easily as the original layout that literally evolved from each previous version. Keeping the first run simple and on time is pretty important. But competition seems to force manufacturers to focus on incremental improvements over big leaps to keep risks down, too. So maybe early Zen5 performance was held back out of caution and now we are simply seeing it mature.
Reactions: OneEng2
19,219
I am also wondering if AMD will not make X3D part of its main product line. Surely more than just games would benefit from more L3?
Yeah any workloads that re-use data a lot will benefit. The most important benefit should be in doing multiple things at once, like browsing while there's encoding going on in the background and also Discord running etc.
SteinFG
743
873
If they buy their own retail samples, yes. But if they want to keep receiving review samples from Intel, they may try to focus more on points other than performance.
At least intel claims equal performance to 14900K. Not like AMD with their outrageous claims of 9950X being "14% better in gaming than 14900K and on par with 7800X3D"
Abwx
12,038
5,014
Computerbase updated their gaming benchmarks with power consumption
also measured.
FI the 7800X3D wich reign supreme in the gaming charts has as much as 3x the perf/watt of the least efficient contender.
inf64
3,884
4,692
It looks like 9800X3D will dominate every other chip. Arrow Lake had no chance even versus Zen 4 Vcache, so I guess it will look pretty bad Vs Zen 5 Vcache version in games.
Nov 7 looks like it's a year away lol.
gaav87
659
1,279
More expensive doesn't necessarily mean better.
People get discrete sound cards for better sound anyway.
Thanks to you i checked out asrock mobos did not have once since q8300 or q6600 (still have them xD)
Asrock x870 RS pro wifi looks good. ALC1220, WIFI 7, BT 5.4 and its 100$ cheaper then b650-a strix lol
gaav87
659
1,279
Thats why its fun, lol.
And you laughed at me when i said 9800x3d will be 15-20% over 7800x3d then next day igor posted the benches and you started hyping 9800x3d with memes xD
Also check out asrock x870 RS pro wifi. I think its best bang for buck mobo right now or did you not return that mobo yet ?
Reactions: Tlh97 and OneEng2
Makaveli
5,026
1,624
also measured.
The power consumption of the X3D chips in those benchmarks are impressive.
Josh128
Banned
Oct 14, 2022
1,542
2,297
Where did I laugh at you? But yes, without the obvious hefty tuning that was done in the bench Igor posted I still think the chip will struggle to achieve +15% average in gaming vs 7800X3D. 5.2GHz just wont be enough for that outside of games that already benefit from Zen 5 architecture.
I considered Asrock, but I found an unbeatable deal on a X870E Tomahawk and have it coming, so I will be returning the Pro Wifi.
Hitman928
6,758
12,506
Kepler just posted a patent that is one level above of what I was thinking, namely, there is a separate "pair node" which sits on top of IOD / AID. This "pair node" I am guessing would be SRAM for L3.
My thinking was that there could just be a section of the bottom die dedicated to L3.
I believe others have mentioned it, but the patent itself is about putting dies face to face and "sharing" at least 1 metal layer. The patent then goes on to show/describe a bunch of different ways they could use this, the picture Keplar showed is just one example where, it seems to me, that the bottom die is used for backside power delivery and potentially contains some circuitry as well (some analog and/or Vcache). Then, the 2 stacked dies are on top of an active interposer that would contain the memory controller and other IO. In the end, they could end up using all of it, or just parts, but obviously they want the patent to cover as much as possible.
Previously, AMD has done face to back stacking.
StefanR5R
6,854
11,036
supermicro is backordered since Zen 5 was released for my Turin motherboard.
I am idly asking myself:
  • Why are there still so few vendors offering SP4, SP5, and SP6 mainboards?
  • What is the change from SP5 rev1 boards to SP5 rev2 boards? Power delivery improved for 500 W socket power? Or flash capacity increased for dual Genoa+Turin BIOS? Or both or more or something else?
  • What is taking so long for rev2 boards to get into the channel? Perhaps it is just the usual loooong delay between a new server CPU generation being "launched",¹ and hardware actually making its way into sales channels.
________
¹) Meanwhile, some priority customers may already have many rows of racks of working machines many months before the "launch".
  • Love
Reactions: Markfw
