Page 801 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
fastandfurious6
864
1,018
regardless true or not, it's the right thing to do
as mobile becomes thermally practical enough tobe desktop replacements (power+slim balance)
desktop doesn't make sense anymore and should be replaced by client-friendly server mobo+epyc/threadripper
already happening with mac pro i.e. M2 ultra desktop = M3 max laptop
is there any real reason to get 9950X instead of threadripper or phoenix/STXH?
calling it now Medusa will be the real x86 desktop killer
if not zen6 then definitely 100% the tsmc 2nm version
Mahboi
1,058
1,969
Thing I just noticed re-reading the Zen 5 Info thread:
Zen 5Zen 4Zen 3Zen 2
Transistor Count8.315B6.5B4.15B3.9B
6.5 / 4.15 = 56% increase
8.315 / 6.5 = 27.9% increase
How did Zen 4, which is supposedly more or less a tweak on Zen 3, have this much more transistor count? Obviously the node leap was massive, but...that's still huge. 56% more.
Zen 5 is a massive rework with a completely new decode, and they still only added 28% in comparison.
Reactions: Racan
MS_AT
920
1,842
Caches. L2 got twice as big. I think uop cache got larger, not sure about BTBs and so on. And don't forget about register files [not only more entries but for SIMD they doubled in size] and tweaks to make it clock higher
Philste
308
486
L2 doubled, AVX512 and actually the higher clocks need a big Transistor budget. The Core itself also has enough changes, of course not the big obvious ones that ZEN5 has but the 13% IPC of ZEN4 isn't that much below ZEN5s 16%.
Josh128
1,505
2,256
Cache, double pumped AVX-512 & frequency increase. AMD has stated in the past, I think it was for RDNA 2, that designing for higher frequency requires higher transistor count, as counterintuitive as it seems.
Abwx
11,985
4,944
Typical AMD APU launch.
Typical clulessness used as argument.to badmouth AMD.
If 26 games out of 30 work flawlessly it means that the 4 remaining ones have half broken code, i wont abound on that matter but FI google "Resident Evil crash", and do the same with F1 24, it s just so much easy to blame AMD for the incompetence of some games developpers.
Markfw
May 16, 2002
27,376
16,217
Z3 to Z4, got a onboard GPU for the first time since Z1 and avx-512. Z4 to Z5, avx512 doubled in capacity and others have mentioned several things. THose were the most noticeable things though.
Markfw
May 16, 2002
27,376
16,217
Anybody giving credence to to someone commenting on server performance of Genoa over Milan who does not think it was an immense improvement is frankly a moron. in addition to the mhz which is like one ghz more at full load of all cores, plus the addition of avx-512, which IS a real server thing, proves they don't know what they are talking about. Genoa to Turin, I will know soon, as I have a Turin in my hand. But doubling the avx-512 alone is a big change. I don't expect that many other noticeable changes, but we will see.
Josh128
1,505
2,256
How do you have a Turin in hand? ES? What is stopping you from running it now?
Hail The Brain Slug
3,889
3,329
These are the transistor counts for the CCD, so core and CCX changes only - iGPU, I/O, IMC, IOD changes are not reflected here.
Markfw
May 16, 2002
27,376
16,217
Gee, first there is no motherboard or vendor that has Turin CPU BIOS out there , so if I put my $2600 aquisition in, its a risk. Yes, its an ES. I have to decided to take the risk.
Reactions: marees
19,204
True. If a studio doesn't test on AMD APUs, not AMD's fault. They are just ignoring a potentially large percentage of sales, especially in second/third world countries.
Tup3x
1,297
1,434
Ah yes, the typical everyone else is to blame attitude. If it worked with pervious gen, there really shouldn't be any reason why those are suddenly broken. If things suddenly start working after driver update, whose the incompetent part (rhetorical question)?
They need to improve their own software/firmware and involvement with devs across the board. Things sure could be better.
Reactions: luro
