Page 963 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Abwx
12,034
4,995
That's pL2 and that's transient on LNL.
Irrelevant metric.
LNL was never built around maximizing nT perf@20W.
It handily wins over KRK1 at actually doing Laptop Things (at a price. pretty steep price mind you).
Plainly speaking, you're dumb. As bricks.
Yes PL2 at 37W and PL1 between 30 and 37W, i checked most reviews while you are
throwing random numbers, even when it s stated 17-20W they still stick at 30W+, the CB R23 scores dont lie.
  • Screenshot 2025-05-17 at 02-18-21 Intel Core Ultra 7 258V Processor - Benchmarks and Specs.png
poke01
4,887
6,233
These battery tests do not take into account a user will do multiple things.
No ones gonna watch a youtube video for like 4hrs or refresh the same webpage every 15 seconds . Most laptop users will have word, chrome with lots of tabs open, spotify, zoom and will interact with them snd switch periodically. In these situations LNL will excel at.
The problem with Intel and AMD x86 designs is that a simple refresh of a browser will make a SoC power balloon past 25 watts esp if it goes past 5GHz. Intel minimised this problem with LNL.
The reason why the AI 350 did so well in the cinebench MT test in Hardware Canucks video is cause its MT SoC power cousmption capped at 10 watts, much lower than the M4's and Lunar Lake. However, that same lead did not translate to the browser test or the youtube test cause here low level clock optimisations and media engines endurence come into play respectively.
TLDR; In the real world, LNL will come out ahead. You HAVE to stop looking thru a cinebench outlook. Its not a real world test for laptops.
Abwx
12,034
4,995
Wow an irrelevant metric. next.
We can also try the 2024 cinememe, it hates AMD cores with passion.
Quite the contrary, CB R23 scores are proportional to power, you can see that the delta is quite low between all models, at 37W it does about 11k, comparatively the AI 350 does at best 17.9k at 65W, we can infer that at 15W it does about 10k.
adroc_thurston
8,646
11,359
Who the hell cares about cinememe scores on ultrathin laptop parts?
That's not even remotely the usage model.
LNL has lower 1t power and is generally more efficient at doing laptop stuff on both SOC and platform level.
But it ain't free.
Abwx
12,034
4,995
But it ain't free.
As already said the era of 1T is long gone, and with bursty loads the CPU wont reach its thermal limit, hence all bursts will reach the max TDP or close, if a single core can reach 15-17W then in any bursty workload the CPU will reach 30-34W for two cores, if there s 3 cores loaded then each will use 11W, and if there s 4 it will be 8W/core.
adroc_thurston
8,646
11,359
It's literally forever.
Indeed. That's why LNL wins at doing Laptop Things.
That's not how bursty workloads work.
I almost miss Andrei and his AT SPEC runs that had total workload energy in joules.
poke01
4,887
6,233
watch this, start from 5:20 and watch till 8:30
AMD hasn't fixed this in Zen5, however Zen6 LP cores should help a lot if the right threads are allocated to the LP cores.
Reactions: Tlh97
Abwx
12,034
4,995
Lol, it does better in advertisement and gullibility of the general public, wich you seems to be part of, same Asus Vivobook laptops and about the same wifi websurfing time as a HX370 :
  • Screenshot 2025-05-17 at 03-04-21 Asus Vivobook S 14 OLED Review Affordable quieter and long l...png
Abwx
12,034
4,995
It just does better.
well yeah it's defined by the OLED turd here.
Try something like X1c LNL.
Both have an OLED, that s the same ASUS Vivobooks 14" laptops set apart for the CPU, and if you look at the battery life at full load, both 75Wh, it will be exhausted while having processed only 50-60% of the work done by the HX370 using the same energy.
poke01
4,887
6,233
I wouldn't take that battery chart as gospel, if you actually read what they tested LNL will get battery life for real world tasks while also being up to 10 degrees cooler which is a huge difference.
The HX 370 is not tuned for ultrathin laptops as LNL is.
Abwx
12,034
4,995
They use the same tests so the numbers make sense, and as pointed if you load the CPU from time to time then the HX370 will be much better for perfs and battery life.
Keep in mind that it s the same laptops with the same equipement while we have been historicaly accustomed to Intel getting better and more efficent parts, if not better batteries.
Once the playing field is leveled things appear for what they are and ultimately i wont hesitate to say that LNL is vastly overestimated because that s a weak CPU in real world and often sold at outrageous price given its perfs, between the two Asus Vivobooks the one with the HX370 is a no brainer comparatively.
Notice that the Intel one is ranked 85.9% by NBC despite only 16GB and 512GB SSD while the AMD is only 84.9% with 24GB and 1024GB SSD while CB R23 scores are 112% apart and 7Zip by 126%, lol, if that s not plain bias i dont know what it is.
ToTTenTranz
963
1,581
So are we calling Strix Halo a massive failure or what?
4 months into 2025, Computex is over and mobility wise we got a total of 1 design wins for a laptop and 1 for a "gaming tablet".
And then we're getting like 5 design wins for those 8 people who somehow need high performance edge clients without having to take them on the go.
This last week, we heard AMD is selling trays of Strix Halo modules in China.
Such a spectacular chip with such an incompetent B2B marketing team.
marees
2,295
2,905
Depends on what you call by "massive failure"
I would look for 2 signs
1. Unsold inventory
2. No zen 6 successor
branch_suggestion
905
1,967
Nope, it is more prolific than expected, this is a brand new swimlane for companies not called Apple.
Laptops are easily the hardest things to get design wins for, doubly so with an unproven market and AMD still being looked cautiously at.
I think they're neat.
Well yeah, it is a good fit for a market that isn't allowed the shiniest stuff.
It is a tough egg to crack, and they just cracked Dell, who was Intel's greatest ally.
1. Unsold inventory
TBD.
Medusa Halo is the part AMD actually needs to succeed with, Strix Halo was just a pipecleaner to establish the market, they will have competition next gen and that is good for the consumer and market prospects.
