Page 585 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
yuri69
699
1,252
So what's the consensus here, is zen 5 good yet?
So far it seems it shouldn't be called Zen anymore - it's not a single balanced product anymore. It's heavily leaning towards SIMD and SMT(?). The core even requires two separate "lighter" versions.
It feels like made for HPC first, not for the general purpose compute as Zen 1-4 were. I'm just afraid of necessity of recompiled binaries, odd performance drops, etc.
I hope the final product won't be that bent towards HPC but...
tsamolotoff
262
512
To be honest don't get why many peeps are so focused on GB which was always an instrument for Apple to make their products look good.
xiewe3wq
16
27
51
Hmm, it seems then notebookcheck was wrong.
Honestly, Geekbench needs filters. Till then Geekbench 5 is one to use.
It should be higher than 3400 with proper cooling, considering that the Ryzen result also has proper cooling it would be required for a fair comparison.
Reactions: poke01
The Hardcard
354
448
Geekbench was in existence for many years before Apple Silicon. For most of its existence, the Mac OS X version measured Intel CPUs. Apple’s chips look good with everything you can get to run on them, pretty much across the board. DaVinci Resolve, Handbrake, the Adobe Suite, the list goes on.
in fact, I have yet to hear of anything compiled for Apple Silicon that doesn’t run extremely well. it would be very interesting to hear about such an application, if anyone knows of one.
19,218
Sorry, folks. I created the table for the ES 9950X DDR5-8000 configuration in LibreCalc and I guess I don't know how to make formulas work flawlessly in that AND I was in a hurry to post.
Here's the updated percentage improvement table and I hope I got it right this time:
So looking at that, maybe the ST perf isn't that hot but in MT, it's a beast?
If you are perplexed by these numbers, you are not alone :oops:
Any mistakes are all mine!
CouncilorIrissa
788
2,855
In this particular case it's not about 1T/nT.
It's all AVX-512. "The most overkill AVX-512 implementation ever" or something along these lines according to @adroc_thurston.
AMD specifically mentioned doubled L1 -> FP PRF throughput in their slides even.
Hail The Brain Slug
3,890
3,331
Are you running air cooler or just AIO? I was under impression that properly clocked 7950x can do about 1.4 gflops if thermals can be sustained (one of my friends tested 7900x with custom water loop at release time and he managed to score 1.1 gflops or about that)
It's on an air cooler.
I have a 7950X3D on a custom loop that is not thermally limited and it only scores about 1.1gflop.
The benchmark behaves weirdly, causing clockspeeds to run only at 4.5-4.7 GHz, even though it's not thermally or power limited. I can only surmise it's not a great benchmark.
Hitman928
6,755
12,501
"It's all AVX-512" - No. ;) This is the fault of all the changes listed below. The ZEN5 architecture is the most revolutionary since ZEN1 and has the most profound changes and is not just an extension of previous architectures. .
and this
The simulations shown are basically FP throughput tests. They will not translate at all to generalized workloads.
The Hardcard
354
448
I can’t begin to describe or even understand myself the amusement I will have if Zen 5 is a working Bulldozer design.
coercitiv
7,492
17,908
