Page 584 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
poke01
4,881
6,222
There are even more.
This one at 4.5GHz is a good comparison between M4 as it clocks at 4,5GHz too. It doesn’t look like it’s an ES sample as well.
Crazy how far ahead Apple is in 1t while also remaining stable. It will take at least 2 generations for AMD and Intel to catch up if they go at their current pace.
I really want this sort of performance in the PC world. Can you imagine a M4 level IPC x86 chip at 5.7GHz!!!!
The responsiveness be like butter.
poke01
4,881
6,222
There are no 6.2 Strix results so not comparable.
Either way STX1 is still a relatively cachepoor baby, real whacko mobile 1t race is where parts like STX-halo crawl into the ring, with full 32M L3 and some MALL on top of that.
Does Intel have a Halo competitor?
Looks like AMD and Apple are the only ones. I guess Intel would have to get their GPUs to scale properly first.
Ghostsonplanets
774
1,228
ARL-H 683 with ADM existed once and obviously vanished without trace.
But hey, it was supposed to have 384EUs.
It was a good idea to shelve it. Using a Alchemist as the GFX IP would be a disaster in the making.
They should revisit the idea with Panther Lake or Nova Lake, when they'll have far more mature GFX IPs like Celestial or Druid.
Hail The Brain Slug
3,890
3,331
I think 5.1 GHz Strix could approach 3050 in David Huang's setup.
I got as high as 3030 in GB6 6.2 on a 7950X with DDR5-6000 memory (Windows 11, VBS/core isolation turned off for the benchmark), so that would have the 7950X already beat (or matched), but perhaps not if I was running Linux too.
Assuming +16% IPC for same-clock 9950X, that would just about push up score 3500 points in single-thread in Windows... of course, it may scale differently in reality.
I am getting just over 3100 ST on a stock 7950X with 6400C30 tuned ram.
I'll run on some flavor of Linux when I have a chance tomorrow, it's a more fair comparison of hardware to hardware if we want to make estimates for zen 5 and inevitably compare to Apple.
DisEnchantment
1,779
6,798
You can run CachyOS x86-64-v4 version, Phoronix found several applications which benefited from AVX512 too, you can compare with Zen 5 later. Application that uses a lot of cryptography benefited a lot from it (including mining :p )
There are few percentage gains in some of them for x86-64-v4 vs standard.
tsamolotoff
261
512
I recovered my old config. It only improved the rate marginally
Are you running air cooler or just AIO? I was under impression that properly clocked 7950x can do about 1.4 gflops if thermals can be sustained (one of my friends tested 7900x with custom water loop at release time and he managed to score 1.1 gflops or about that)
Det0x
1,488
5,114
We are still oscillating between 5% and 50%. The only thing worse than Zen 5 leak accuracy is Samsung 3nm yields.
Maybe both are true at the same time, some benches are 5% while others are upwards 40% 🤔
In my mind this new Zen 5 architecture is a fundation to build upon in the future while there was not possible to gain much more form the outgoing Zen 4 architecture
CouncilorIrissa
788
2,855
Ask and you shall receive. It's a 4+6 chop tho.
itsmydamnation
3,139
4,010
I would like to have a Zen 5 Ryzen 9 please, with 2x 6 wide decoders, 8 ALUs, 8 FP pipes, 6 Giggle Hertz and please make it 25 watts.
Just take zen4 and double almost everything , it would have be awesome....
This most things are bigger , but the fpu is only wider ports and then some structures are smaller seems so mid. Sad, build the core and they will come.
