Page 447 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Mopetar
8,531
7,795
Clockspeed, yields, node? 8c could be on an older node than 16c and 32c so would be quite a bit cheaper. V-cache compatibility.
Those are just off of the top of my head.
The biggest is cost. 8C is a smaller chiplet and there are plenty of consumers who don't even need that many cores.
I think 3D V-Cache is everywhere.
Doubtful unless they've fixed a lot of the performance quirks and are moving the L3 off the base die. V-cache does nothing for most consumer workloads outside of gaming or isn't worth the loss in clock speed it currently brings. Some professional users certainly benefit, but it's not worth the added cost to make everyone pay.
Joe NYC
4,232
5,836
Why use 2x8c instead of 1x16c, for the 16c client CPU variants of Zen6?
Assuming there will be 16c CCD of Zen6 available anyway, why not use them on client too? Also opens up for 2x16c on client CPUs, and 1x16c + 1x8c.
Because of 95% of units sold on client will have a single 8 core CCD.
The server CCDs may be optimized for different settings, and also, may not be at all compatible from client style packaging.
So it will still be the most efficient to serve the 95% with single CCD and the remaining 5% with dual 8c CCDs.
Reactions: Tlh97
Ajay
16,094
8,116
Zen5 is already old news. Leaks about Zen6 starting to appear now:
LOL! Zen5 isn't even released yet.
Here's another idea. Start an New Zen6 thread. I'd start it, but I don't know a damn thing.
zacharychieply
9
4
Going to 16 cores on a single ccx would reduce core to core latency, but they will probably need upgrade their ring interconnect to either a 4x4 tile interconnect or something better.
Reactions: Tlh97
StefanR5R
6,851
11,029
and energy consumption of intra-CCX traffic is lower than that of inter-CCX traffic too. But the workloads in which this matters are rarely seen on client computing devices.
which, in turn, is bound to increase the cache's power consumption, or cache performance will regress (for some access patterns).
CouncilorIrissa
788
2,855
The thread has cooled down a little.
So what are everyone's final guesses on the perf increase now that Computex is around the corner? I think pretty much everything that could leak already did at this point, and we're not getting any more info until the announcement.
My guess is +21% IPC, +200MHz for top desktop chip, take it or leave it. Zen 3 reloaded basically.
edit: SIR 2017.
Goop_reformed
316
341
25%+ st uplift. Higher in synthetic, lower in real world usage. 20% for multi.
Reactions: spursindonesia
StefanR5R
6,851
11,029
Re #11,158 and #11,159: Doesn't mean anything if the workload isn't specified.
(And IPC is not the correct acronym for iso-clock performance anyway.)
Abwx
12,033
4,995
edit: SIR 2017.
Not easy to draw conclusive estimations out of half baked GB numbers with an ES
or from the Blender bench in unknown conditions.
I will stand with my 22.47% minimal average IPC extracted out of nebulous statistics based on said early numbers and from the alleged uarch evolution.
Philste
308
486
No matter if IPC is the right word or not:
ZEN5: 22-23% IPC, 5.8 GHz for top CPU in Desktop stack
Lion Cove: 17-18% IPC, 5.5GHz max
So my guess is ZEN5 has 10% better singlethread than top ARL and arrived a quarter earlier (or more). ARL will be competitive in multi tho and maybe even more efficient in multi.
Gaming wise, I think both new products will fail to beat their predecessors. ZEN5 because X3D is just too strong, ARL because of horrible Cache characteristics.
adroc_thurston
8,607
11,325
CakeMonster
1,663
843
What about some more relatable predictions? Game performance vs Z4 X3D? Sustained encoding speed with Handbrake? Browser benchmarks?
Joe NYC
4,232
5,836
Yeah, I am really curious about the use case where this matter, and I can't think of a good one.
The real issue with 2 CCDs (in client) is thread jumping from 1st CCD to 2nd CCD, while all it's cached data is on 1st CCD.
It seems to me that this case can be mittigated by some sort of algorithm that would have awareness of content of both CCD caches, and being able to copy content of L3s between CCDs.
Also, the new packaging for Strix Halo could allow direct (and fast) CCD to CCD communication.
adroc_thurston
8,607
11,325
CouncilorIrissa
788
2,855
Vidya too.
What effectively is a dingus quad-core won a ton of gaming laptops.
HC in general is insanely stacked this year.
Vidya benefits a lot from 3D-cache as well, so not sure if front-end improvements will be big enough to offset that and add some performance on top.
this is far bigger and meaner than Zen3.
Well, wider does not always translate to large perf improvements (*cough* A17 Pro P-cores vs Everest), and leaked memebench numbers, while good, weren't THAT good (obviously those were from ES chips that have all sorts of immature firmware and locks).
adroc_thurston
8,607
11,325
of course. child's play.
This is AMD we're talking about.
cinememe isn't a relevant workload. basically doesn't exist as a target for uarch people.
