1. what are you talking about? you dont pay interest from day 1. you start paying interest if you dont make the payment in full at the next billing cycle. if she charges $250 in month 1 and pays it all off at month 2 bill she doesnt pay any interest. if she doesnt pay it all off, then interest starts rolling.
2. more credit generally doesn't hurt your credit score. it helps because of utilization %. new credit reduces your average length of credit. that can pull your score down. that's why you should never close your oldest cards if they are free, just set them aside.
The credit card company (i.e., the bank) is not doing anything to her score. They simply report the credit limit and the amount that is in use. They don't create a score, they don't report a score.
The credit SCORE (again, which does not come from the bank) assesses various factors to create a score. One of the factors is the amount of credit being used (which is called utilization). The higher the utilization, the more it negatively affects your score. Credit scores are derived from various formulas - FICO, VantageScore, etc. - created by different companies.
The utilization calculations are not public, but it is generally understood that they fall into brackets. Under 10% has little impact on your score. At 30%, you get dinged more. At 50%, even more. At 80% even more than that. Scoring does not say "She's using 80% of her credit, but that shouldn't count against her very much since it's only $500." It only sees the percentage in use.
The typical advice given to someone in her position is: Pay the card in full. Stop using it. In a month or so, her utilization will be zero. Then her score will no longer be affected by the utilization on that card. Her score might go up enough to enable her to get a card with a much larger credit line which is the best way to solve the problem.
If she had a card with a $5,000 credit line, her typical monthly spending on that card would hardly affect her score at all.
It depends on your card. More of them have started doing daily periodic charges to counter the rules Congress put in place. It's one of the reasons I cancelled 2 of my cards and don't charge anything unless I have to. Typically, they acrue the charges and apply them in bulk with little or no explanation to mask what they're actually doing.
Number 2 totally depends on if you need to take out a loan and who the underwriters of the loan are. Many of them aren't looking at just the utilization these days, they're trying to make sure you're not going to owe more than you can make the minimum payment on. So if you increase your credit limits and have 10 cards you don't use, you're better off closing these accounts than keeping them open. The underwriters look at those ancillary accounts as liabilities.
My best advice is to get a credit report and call up the cards you'll never use again to close them out. If nothing else, it may help reduce your odds of identity theft in the long run.
This has been pointed out in a couple of threads with people claiming "I put 100% of my bills, etc., on my credit card, and pay it off in full every month." Depending on your credit limit, it *could* have a negative effect on your credit score, regardless of the fact that you pay it off every month.
Thank you, best answer so far.
I think what the lady is doing, she is trying to use a low limit card so that she can not spend too much in a single month. With a $500 limit, the card stays within a limit where she can pay it off with a single paycheck.
The problem seems to be that she is using a high percentage of her limit. She does not want to get a card with a higher limit, so that she can not overspend.
The solution seems to be to buy less stuff with the card. If I remember right, she mentioned trying to stay around the $200 - $300 balance on the card.
A lady I carpool with was telling about her credit card usage. She has a card with a low limit (she said $500 limit), which she uses to buy various stuff with. The items usually include her lunch and fuel for her truck.
Every month she pays the card balance off.
The credit card company is reporting her as having a high balance on the card, and its having a negative effect on her credit score.
She thinks that the high balance is using a certain percentage on the limit of the card. That if she goes over 50% of the card limit, the card company reports her as having a high balance.
Why would a credit card company give you a penalty for using the card, and then paying the balance off every month?
What? That makes no sense. For every credit card I have ever encountered, if the balance is paid every month, there should be no penalties and it should not have a negative impact on someone's credit score.
Something is messed if they are saying she has a high balance when she does not.
KT
It is all about the timing. When the statement is produced, the balance is usually pulled that day. If the billing cycle is such that a balance exists, there ya go.
Also lots of people simply don't understand this:
The "Maximum Positive" benefit to a credit score, "with regards to balance" is if that balance is at 0.1%-5% (subjectively). A completely clear balance has ever so slightly less of a "Positive Impact" than the slight balance. A totally maxed out card has the "Least Positive" impact to a credit score. It isn't "Negative" until we start dealing with lates and brand new accounts, and over the limit situations.
Mr Hiker, who cares. Credit cards are worthless and a waste of time.
(I do it via online payment) or less BEFORE the closing date of that month (NOT due date) or get a higher limit CC.
Having 2 different dates seems like a scam on the consumer.
A credit card is a tool, you're not a fan of it anymore than you are a screwdriver. Its a tool you use when you need it and thats the end of it.
Just because you have no idea how to use them doesn't mean the rest of us don't either
