Originally posted by: Marlin1975
Originally posted by: MasterAndCommander
3k...regardless of conventional or synthetic.
you are wasting money.
Good to know all that marketing money jiffy lube etc.. is spending is going to good use.
I do. Pushing the engine past spec. Higher shift points than stock. More lift on the rocker arms, lower thermostat, etc etcwho the heck changes every 1K-2K miles?
Unless of course you are doing more than just driving to work/soccer practice/grocery store/mall in which case the small amount of money is worth protecting your engine. Good oil perserves gaskets. If you drive your car hard often then it is worth the $25 ($50 for oil and labor if you dont do it yourself) worth of synthetic oil to protect your car.Don't spend more money on expensive oil
Originally posted by: squirrel dog
I try to do it every 3k or so , not to exceed 5k . When to oil darkens from honey colored to brown,I change it and the filter .
Originally posted by: jonesthewine
Using Amsoil or Redline full sythetic oils, the filter is changed every 5000 miles, the oil stays in for 20, 000 miles.
Poll needs more options
