"Write Protect" error on Olympus digital camera... how to fix?
imported_Tomato
7,608
When I turn on my digital camera, all functions work but it won't allow me to take pictures. When I press down on the button, a "WRITE PROTECT!" error message comes up. Is there a way to fix this without having to take it into the shop?
*feeling horribly tech-illiterate*
EDIT: Apparently I can't spell, either. :(
EDIT #2: Thank you, okay for Mods to lock if necessary. :)
EDIT #3: Doh! It's actually an Olympus digital camera... my old one was a Sony, and I got confused. I've tried everything, and all functions work fine except for that damn "Write Protect!". Any more suggestions?
EDIT #4: Formatted, it works perfectly again. :) Thank you, ATOT! :heart:
TuxDave
10,571
Were you able to take pictures before? What type of memory does the camera use?
geno
25,074
4
If it's a Sony, I know MemoryStick has a switch to turn write protection on...
Ornery
17
There's probably a switch on the memory card to keep it from being written to. I'm just gueesing, but that's the case with Memory Sticks.
gopunk
29,239
regardless of what brand it is, chances are the memory card has the write protection switch on... just look for a switch of some sort....
Brutuskend
26,558
4
My guess as well
fs5
11,774
it's an olympus that means it probably uses smart media. SM doesn't have a switch IIRC. (or possibly XD)
Do you have a card reader? Does the card read in it?
imported_Tomato
7,608
I didn't see a switch when I checked the memory card... and no, I don't have a card reader...
Electric Amish, RTFM?
BigSmooth
10,484
12
Have you checked your owner's manual? Maybe there is a suggestion in the troubleshooting section.
If it uses SmartMedia, there's a chance the card is scratched or something. Does this happen with different cards? If not, SM is super-cheap so you should just toss the bad one and get another.
imported_Tomato
7,608
Unfortunately, I managed to lose the manual shortly after purchasing the camera... I haven't tried different cards, but it sounds like I'll be bringing it into Fry's for SM.
freegeeks
5,460
RTFM = Read The F*cking Manual
imported_Tomato
7,608
Wish I could, thx...
BigSmooth
10,484
12
If possible, I would try formatting the card first as well.
SM is pretty cheap, though.
Brutuskend
26,558
4
The Smartmedia Memory Card is an SSFDC (Solid State Floppy Disk Card) removable memory card. With a card like this you can record and erase data from Cameras, MP3 Players, Handheld PC's and more. A Smartmedia Memory Card is very small and thin. It is about 1/64 of an inch thick, (The Thickness is an estimated guess be me.) 1-¾ inches in length and 1-½ inches wide. Actual Dimensions are 45mm x 37mm x 0.76mm and the Weight is approximately 1.8g. There is a gold metal like area on the card, this is the contact area with the device for storing and deleting your photos or data. (DO NOT TOUCH THE GOLD AREA.) You will see a little circle in the right center of the card, this is the write-protect area. To make a Smartmedia Memory Card read only place a write-protect adhesive seal over the circle.
Removing the write-protect adhesive seal will make the card like it was before so you can place data or your photos back on it. Smartmedia Memory Card come with a static-free sleeve and plastic case for storage. Usually included are index labels and write-protect adhesive seals. Use a little common sense when handling these tiny storage cards, you could damage them if misused. Storage sizes come in 8, 16, 32, 64 and 128MB. (Megabytes) Each Smartmedia Memory Card is marked on what size they are on the outside of the card. The 8MB and 16MB cards are the Olympus cards.The Olympus Camedia Smartmedia Memory Card have a Panorama function. The 2048x1536 Resolution is in the High Quality Mode and the 1280x960 & 640x480 Resolutions are in the Normal mode of camera.
freegeeks
5,460
is there a little circle in the right center of the card??? if so this is the write protect area
make sure there is no seal on that circle
BigSmooth
10,484
12
what kind of camera is it, someone here probably has an olympus. There SHOULD be a way to format the card in the camera itself. If that doesn't work just buy another like BigSmooth suggested
There should definitely be an option to format the card somewhere in the delete options... at least there has been on every camera I've used.
imported_Tomato
7,608
Phew, sounds like that should work... thank you so much, I'll check and see if there's a write-protect adhesive seal on the card when I go home for lunch today. Will be back in ~3 hours with Model # and verdict.
You guys are the best, thank you so much. :)
JoeKing
if there's not an option in the cam to format, winxp should allow you to do it when you hook it up to the computer.
