It dies in 8 hours doing nothing? That's terrible.
Though to be honest, I don't know how long the average Ultrabook that gets 7 hours would last in such a test. It's a data point that needs more data for actual comparison.
But will they last as long as an actual SSD though, especially when being used as such and not just occasional copy pasting?
Excellent question; I've no idea.
Doubtful, and that's something I didn't even consider.
But truth be told, external storage like that should be mostly reserved for strictly transfer of data between devices or the storage vessel for all forms of documents/media.
It's only write cycles that degrade memory, not read cycles, correct? If so, even using it as the MP3, video, photo, pdf and doc file repository would still mean a low number of total writes and a good drive would be plenty fast enough for that (and yet it's enough to ensure one notices the improvement over external HDDs or SD cards).
And that helps leave a lot of room on the SSD (potentially, if you don't store many documents/media on it), which helps the longevity of that SSD. Especially since temporary files and the page file are on the SSD (which is great for performance, but that's a lot of write cycles). Which, as long as there is enough space left empty on the drive, TRIM will help ensure the writes are balanced and the drive keeps on going.
Completed my first battery test: If the system is set to min brightness, WiFi on, Bluetooth off, local account, fully updated, screen saver off, and left completely idle, the system will last approximately 8hrs 13 minutes before it shuts itself off (critical battery percentage set to 3%, can't be set any lower).
As such, the major inference I can make is that even when the CPU is down to it's lowest possible frequency (800Mhz), the platform as a whole is still consuming too much power. Supposedly Haswell fixes this, as the system really needs to get ~12 hours under this scenario to get 7-8 hours in typical use.
That's all preventing any kind of Sleep, isn't it?
If you have a touch/type cover and close it, would the device normally enter sleep mode, or simply turn the screen off?
If you even left it open under normal settings, under normal conditions, it will enter into some kind of sleep mode, yes?
Does it still keep active with notifications under sleep mode on the device? (I've heard that either this and the Surface RT, just the Surface RT, or even possibly just the WP8 phones do this).
Basically, if you use it normally, set it down and don't touch it for awhile, will the device retain a good charge? I know even sleep mode will drain the battery, but it'll take awhile compared to leaving half of the system actively sucking down power doing nothing.
so it uses an mSata... 512GB here I come!!!! but haswell... not so well...
Has anyone with a Surface Pro tried upping the 16 point pen calibration method to 100 points?
Here are the results of my battery tests again so far:
1) min brightness, WiFi on, idle system - 8hrs 13 min
2) 50% brightness, WiFi on, idle system - 6hrs 13 min
3) 100% brightness, WiFi on, idle system - 4hrs 57 min
"Idle system" means the battery profile was set to power saver, critical battery was set to 3% before shutting off, screen saver was turned off, and the system was left sitting at the desktop.
Last thing is the torture test: 100% brightness, 100% CPU.
Not bad, do you mind taking pictures on how bright the 3 settings are?
Yeah, I'll need to grab my dSLR so the exposure can be fixed (otherwise the pictures are invalid).
haha it looks like Microsoft underestimated the demand. Another missed opportunity.
Rumour has it that this Saturday is the new shipment of Pros.
Stylus: This is my biggest beef with the Pro, how they handled stylus storage. The stylus will "dock" in the power connector port via magnets, which seems like a good idea at first. Then you run into two major issues:
1. If you need to charge your device, there is no good place to store the stylus. I almost forgot my stylus this morning because I left it sitting next to the device while charging.
2. The stylus is in the way and easily knocked loose when picking up or while holding the device by its sides.
It's such a small thing, but such a huge issue for me! I shouldn't have to think about the stylus until I need it. I don't want to always worry about forgetting the stylus at home or knocking it loose while using the tablet. The EP121 had the space for an internal storage slot for the stylus, but it also had a spot on the case for you to store it or, in my situation, keep a 2nd stylus that was aftermarket and didn't fit in the slot. Either way, the guys at Asus had that figured out.
From the MS blog itself....
http://blog.surface.com/b/surface/a...?wt.mc_id=Microsoft Surface, FBPAGE, Outgoing
Bad news for Canada and the 128 version.
