WOOOOT !!!! 2400mhz from 2000mhz on my 3800x2 powered 100% stock DELL E521 !!!!!
eBauer
533
Originally posted by: bryanW1995
Originally posted by: eBauer
Got an 800MHz overclock on my x2 3600+ powered E521 - had to bump down the memory ratio to /10, but even with the slower memory speed I shaved an honest 36 seconds off a 2MB Super Pi run.
how did you adjust the memory ratio? I'm at 2400 running 10 windows + at work and 2x seti @home when not using it for work on my 4000+ brisbane C521. Also, I could never get any programs to work that would adjust the htt ratio.
I used CBiD (thanks Dazed and Confused) - Click memory, then controller, and you're all set. I was only able to get one of the ratios (1.0) to work though, the others would lock up the system.
sgrinavi
4,537
Originally posted by: Noubourne
400Mhz OC. That is just so cute.
I'd have to say the 30-day break-in comment was my favorite.
Where's the respect in that? Isn't there some rule about thread crapping around here?
Farfrumhumpn
Banned
Nov 22, 2009
210
Has anyone been able to change the multiplier using any of the tools listed in this thread? I just gave a friend a 5200+ x2 brisbane which has a 13.5 multi for 2700mhz but the motherboard runs the CPU as a 13x multi so the CPU is running 100mhz slower than it should.
I know this thread hasn't had a post in over a year but was wondering if anyone has any ideas on changing the multi on this motherboard thru winows.
