Any time i look at new video cards they all say the same thing: "lose the wife"
Single for life.😉
No! NV used to perform better in BF3.
Multiple sources or don't bother
You didn't even post a single source
OP good decision to stick with the GTX 670.
http://www.guru3d.com/articles_pages/his_radeon_7950_x_iceq_review,16.html
http://www.guru3d.com/articles_pages/radeon_7790_review_benchmark,18.html
BF3 1920 x 1200
HD 7970 Ghz - 65 fps
HD 7970 - 58 fps
HIS hd 7950 iceq x2 boost - 57 fps
GTX 670 - 55 fps
HIS HD 7950 runs at 950 mhz. the GTX 670 boosts to 1+ ghz even at stock. also the scaling on the HD 7950 is excellent. HD 7950(1100 Mhz) matches HD 7970 Ghz. it would need a 1.25+ ghz GTX 670 card to match a 1.1 Ghz HD 7950.
http://gamegpu.ru/action-/-fps-/-tps/battlefield-3-ehd-game-test-gpu.html
BF3 End Game multiplayer
1920 X 1080 UQ
HD 7970 Ghz - 82
GTX 680 - 73
HD 7970 - 71
GTX 670 - 64
HD 7950 - 62
thats a HD 7950 running at 800 mhz keeping up with a GTX 670. HD 7950 boost even at stock would be just behind the HD 7970(925 mhz) and at 1100 mhz it will match a HD 7970 Ghz. it would require a 1.3+ Ghz GTX 670 to keep up with a HD 7950(1.15 Ghz)
lol the ghz 9 frames faster than the 680? Sure. Im happy for all your calculations, a stock 670 matches an overclocked 7950. Proof is right there. Don't bring up boost, its different for any card and the reference model is the worst of the bunch. Try comparing an overclocked 670 to that overclocked 7950 now.
You're reading comprehension failed there - try rereading what he wrote
for 670 to keep up 1100 OC 7950 usually needs 1250+ how many 670s do that?
*sighs* both cards are nice - op already has one - as I said before use it or don't its up to the op.....but right now 7950 is a much better buy than the 670....
Its cheaper; OC *usually better* with OC is faster and better game bundle.....sorry that hurts you but hey....
Hi, I am a Fanboi, nice to meet you.
Except, some of us live in the real world where most cards don't OC as well as you think they do. My 7950 is locked to 1.25V and it crashes after 1100 MHz.
My old 670 took 150 MHz boost without me touching anything else. Those 670s can OC fairly well.
FYI, a 670 at stock will still be faster than a 7950 at 1000. It needs that overclock while the 670 does fairly well at stock.
I do understand that my friend - but I still stand by that overall value 7950 is a better buy right now than the 670.....🙂
No where have I ever said 670 was a bad card; if they were equal priced; with same games - I'd possibly lean towards 670.......but they aren't
7950 is cheaper card; better game bundle - and with the possibly of better OC........but as I keep saying to people buy what's in your budget....OC is extra
Either card you'll max most games out at 1080p.....😀
oh, you have a 7950. wouldnt expect that. The whole board is pro AMD, misleading consumers who ask for advice here.
AMD took months to catch up in many games as previously stated.
AMD had to release higher clocked versions of their cards to look better in benchmarks, especially because the lowly 660ti was about to spank the 7950 at stock.
AMD even has problems now with frame latency issues and crossfire is basically useless.
Why anyone would buy an AMD graphics card is a great question.
If they were equally priced, nobody would recommend the 7950 over the 670, only the pro AMD people on this board. The OP already has the 670, which is the better card. So why would he send it back?
Basically this is the point. To send it back, buy another card, is another week or so without a card, to get a minimal improvement at best. A $60 difference for the Sapphire (downgrade in quality, IMO), or $30 for a TF3/WF3, isn't worth the time and effort, unless he really wants that 7950.
For me I did it because my 670 was reference while I got the quieter cooler with my WF3, and my 670 was giving me graphical issues.
I still don't notice the difference between the two. Except the 7950 has coil whine, as did my 7970, while the 660 and the 670 never gave me any.
