Why is AMD better than Intel?
DAPUNISHER
32,142
32,717
Hey chemhaqr don't go scaring me off by using words like P4 :Q I haven't owned an Intel since the socket7 days and this Celery looks to be just what I've been hoping for from Intel price/performance wise to get me to build a box with them "inside"! As to the mem bandwidth I agree it's not everything but it is an issuse when it comes down to it and Sandra CPU benchies aren't everything either, ya know? Anyways, I appreciate you exposing me to the data as if not for your crusade to enlighten us AMD fanatics I wouldn't be aware of the value and overclockability of some Intel platforms as the only ones I crack open are OEM's.
chemhaqr
351
I would expect the XP 1600+ @ 1600MHz to beat the celery in most real world benchies but I bet it ain't gonna be by much. My problem is I have never owned a AMD system yet but when their .13u chips come out I think I am going to defect;) I only want a good stable platform not a gaming behemouth that every so often locks up on me or crashes you know.
Yeah I am sure I am calling out the wolves with that statement but I have been told by many a AMD zeolots that the AMD 760 chipset is the way to go for any one really concerned about absolute stability and I have owned a VIA chipset before and it scared the PISS outa me.
I couldn't find any reason for my system to be crashing at stock speed. RMA'd it to get a BX board and all was well. It is shi# like that makes you not wanna switch you know. I would be writting a paper or using molecular modeling software and all of a sudden BAM it would go. Yes I did set it up right it was something about that board and maybe VIA is changing for the better which I am sure they are but I will not use a VIA Northbridge board. Not even the KT266a. I would rather use the 760 but that is me. Now if all I did was surf and game the KT266a would most likely blow my top but I am not so I want stability but I want it too be quick about it;)
Hopefullywe will see a AMD 770 chipset but I have heard from many it is going to be vaporware. Would also like to see the south bridge made by AMD too but I guess even AMD finds a way to bend you over sometimes too eh.
chemhaqr
351
Hey also it seems the best board at the moment for the celery is the ST6. Not sure if you know that...my advice since I am a intel fanatic and all....Also if the BD133u allows you to use the 1/4 multi under 133fsb then that may be a good option too. I am rma'n a tusl-2. Not a good IMHO yet. Needs work still or something. I have seen that be the buggiest board so far for these celeries. Soemtimes it has ran the L2 cache at 1/2 speed for some or for me my Aux voltages were at 1.7~1.9v. Not good since the new FCPGA2 uses a 1.25 Aux or AGTL if I am not mistaken. All I know is that on my ST6 my Aux voltage is at 1.25v which is also the new AGTL standard over the old AGTL+ @ 1.5v like the PIII cumine were. I think the board couldn't tell the difference and was running the AGTL voltage at 1.7~1.9v which caused problems like too much heat. You may get a chip that runs like mine right at 1600MHz no more no less in that case the TUSL-2 would suck as you would have to run it at 120FSB as the highest cause the chipset configuration doesn't like anything over that FSB with a 1/3 divider and there is no 133fsb setting with the TUSL-2 only 134fsb when set to 133sb in the bios or with the dippies . Not sure why it is like that but it is.
