Who's on Jellybean?
trmiv
14,670
18
Yea if figured out home by itself. It thought work was a nearby grocery store since i did this last week and was working from home, but went back and forth to the store three times. But I edited the address to my real work address yesterday and it was ready to go this morning.
My only beef so far is my GPS is really really slow to lock on. It's fine when I reboot, but by the next day it takes 10 minutes to lock on. If I reboot it's fast again for another few hours.
T_Yamamoto
15,007
795
Vanirbean v6 rc6 fixes it
Spoooon
11,563
203
My GPS has been slow to lock on as well. On team Vicious.
I notice funky behavior in text fields in chrome. Not sure if it's chrome or if it's jelly bean, hasn't been much of an issue, just noticed while typing this.
Headcase_Fargone
388
All this location awareness sounds brutal on the battery. I put in a lot of time and effort in Tasker to specifically avoid using GPS. There better be a way to turn all this nonsense off.
SickBeast
14,377
19
Juice Defender kills a bunch of stuff when the screen is off to save your battery.
trmiv
14,670
18
I haven't really noticed the battery has been that much worse than it was on ICS. And I've been using the hell out of my phone. And yes if you want to turn it off you can turn it off. Selectively or the entire thing. I think any battery hit is worth it though. My smartphone actually feels smart now.
AstroManLuca
15,628
Just going through the various settings:
1. You can always go to Settings -> Location Services and turn off GPS Satellites. Then all it will do is find your rough location using nearby wifi networks and cell towers. Of course if you also have wifi off then it will only use towers. This will still give it a good enough idea of where you are that it can tell what's nearby (restaurants, movie theaters, weather conditions, etc).
2. Latitude is an opt-in service. In my case at least, it was off by default and I had to specifically grant it permission to turn on. You can also decide whether location data is collected at all, and if it is, whether it can be shared with Google or not.
3. Google Now can be fully disabled if you want. When you launch it, you can press the menu button in the lower right and enable/disable specific features (weather, sports, traffic, nearby places, public transportation, and so on) or globally disable the whole thing with an on/off switch in the upper right corner.
I had GPS satellites on by default, but since I rarely use navigation, I'm going to try turning it off and seeing if my battery life is improved a bit. Far as I can tell, there isn't much benefit to having GPS on unless you're using it for navigation or if you're in an unfamiliar area. If you generally know where you are, it's not necessary.
Headcase_Fargone
388
It's not a task killer, it's more like Tasker in that it has various triggers that allow it to disable some features when they're not in use. Mostly things like disabling wifi, GPS, or mobile data in some situations.
Is there a reason to use this if you're already running Tasker?
ponyo
19,688
2,811
I haven't noticed any noticeable hit on battery life. It's only been 3 days or so but I'm still getting full day usage and ~5+ hour screen time before dropping below 20%. But mine is GSM with 2000mah official extended battery.
Sid59
11,879
You guys feel getting a Nexus is worth it? no LTE and a new Nexus might be on the horizon? Probably selling 16gig iPhone 4s with 6 months of warranty left.
Red Storm
14,233
234
On Verizon yes cause I suspect they might not get another Nexus phone, but you can bet all GSM carriers will be getting the new Nexus(es) this fall.
Sid59
11,879
ATT here. I see a Google I/O phone on CL or buy from Play store.
Red Storm
14,233
234
If you're willing to wait a few months we should be seeing a new Nexus this fall, and judging from the Galaxy Nexus, it should be a pentaband phone (works with AT&T and T-Mobile).
NeoV
9,504
Can anyone with a verizon Galaxy Nexus help me through upgrading it to jelly bean? Pm me, thanks!
Chocu1a
1,386
79
Vicious JB here. Using the stock kernel, it is more buttery than all the rest
Phobic9
1,822
I'm using this with Trinity kernel (which I've never used before) and I don't even want to bother with AOKP anymore. So smooth and very fluid.
I'm going to be very sad if Verizon doesn't get any more Nexus phones though. They're pretty much the only Android phones worth getting for me.
Chocu1a
1,386
79
Once my contract is up with Verizon next year I am going prepaid with a Nexus from Google
bucwylde23
4,180
Just flashed VanirBEAN v7. Ridiculously fast. Fixed my GPS issues too.
I can't wait for source to drop, these JB ROM's will be amazing.
