RussianSensation
- Sep 5, 2003
- 19,458
- 765
- 126
Damn 12k at 60fps on a single fury. Even if it graphic settings aren't on high I'm not so worried about the 64 ROPs anymore.
From your link:
"The most impressive part about the 12K AMD Eyefinity demo shown this week by AMD running the game title Dirt Rally is that they needed just one video card in the PC to push all those pixels at a playable frame rate, the AMD Radeon R9 Fury X. The frame rate was pushing 60FPS, which isn’t too bad considering what the single $649 graphics card is doing behind the scenes to push out all those pixels at an acceptable rate. AMD informed us that two Radeon R9 290X’s or a Radeon R9 295×2 get around 45-50 FPS on this exact setup."
WOW.
Also, I wouldn't worry about ROPs as it's double Tonga's and Tonga's 32 ROPs are > Hawaii's 64. TechReport once again made a giant mistake of comparing paper specs, that is despite themselves being fully aware that Tonga's pixel fill-rate is higher than Hawaii's. They should have known better from HD6970 vs. 7970 or from R9 280X vs. 285 that you cannot compare ROPs on paper in theory from different GPU architectures. Since Fury X is not based on a Hawaii architecture, TechReport's projection about Fury X's ROP bottlenecks is unfounded.
"In other respects, including peak triangle throughput for rasterization and pixel fill rates, Fiji is simply no more capable in theory than Hawaii. As a result, Fiji offers a very different mix of resources than its predecessor. There's tons more shader and computing power on tap, and the Fury X can access memory via its texturing units and HBM interfaces at much higher rates than the R9 290X.
In situations where a game's performance is limited primarily by shader effects processing, texturing, or memory bandwidth, the Fury X should easily outpace the 290X. On the other hand, if gaming performance is gated by any sort of ROP throughput—including raw pixel-pushing power, blending rates for multisampled anti-aliasing, or effects based on depth and stencil like shadowing—the Fury X has little to offer beyond the R9 290X. The same is true for geometry throughput." ~ AMD's Radeon Fury X architecture revealed
vs.
I really don't know what to say -- how do you make such MAJOR mistakes as a professional reviewer?! Wow, just wow, it's like so many of these "professional sites" can't even keep track of their own reviews. If 32 Tonga ROPs > 64 Hawaii ROPs, what happens if you have 64 Tonga ROPs vs. 64 Hawaii ROPs? According to TechReport, the same pixel fill-rate throughput. *Shakes head*.
So according to TechReport, Fury X also has little to offer beyond R9 290X when it comes to geometry throughput. Did Scott Wasson literally forget his R9 285 review or is he assuming Fury X is GCN 1.1 not 1.2? I mean come on, the data in his own reviews proves his own hypothesis wrong and if he wants to go on paper, Fury X should have close 2X the pixel fill-rate and geometry performance of a 290X (even if we account for non-linear scaling, surely 70-80% higher than a 290X).
PCPer, Legit Reviews, KitGuru, HardOCP, TechReport - so many gross mistakes and exaggerations/misconstrued data on the AMD side as of late. It's getting ridiculous.
