What to do? Bought a MP3 player off Craigslist and it's not working properly??
nakedfrog
62,919
19,149
Man, it sounds like you've got a big problem. We'd better dispatch a waaaahmbulance.
Beyond emailing Creative, did you look for solutions on their site?
mchammer187
9,114
the only thing USB 2.0 says is speeds up to 480 Mbps
no device ever hits this
and
there is no guaranteed minimum
DBL
2,637
Originally posted by: Brassman
No, I still want a Zen Micro... had one before this without any problems.. it transferred songs quick.
How are you transferring music? What program?
Savij
4,233
Originally posted by: dabuddha
I think the seller really isn't at fault here. He advertised the product with the same specs that the manufacturer advertises it. From an earlier post, it seems like it's a known hardware problem (overall, not just this particular unit) which is not in the Seller's control. Unless I missed something.
I haven't done the research so I'm going from what I picked up in this thread, but I think the seller isn't really at fault here. If it's a known issue that appears on many (maybe not all but enough for reviewers to mention it, then it sounds like a decent number of the players) then I think its reasonable to stop bugging the seller about it. Learn to read the reviews closely when buying used items or from smaller sellers because they can't offer refunds just because you don't like the item. If they misrepresented the item that's one thing, but I don't think that is the case here.
dainthomas
14,936
3,915
Originally posted by: suse920
Originally posted by: Savij
Originally posted by: DBL
I think you need to contact Creative about this.
Review
Performance
Although the Zen Micro comes with a USB 2.0 interface, we found music transfer to be much slower than we expected and noticeably slower than other hard drive based music players we have tested in the past. We transferred the same album to both the iPod Mini and the Zen Micro, and the results where surprising. They both use USB 2.0, but the Zen Micro seemed like it was transferring at USB 1.0 speeds. The iPod Mini took about 2 seconds to transfer each song, where the Zen Micro took between 8 to 10 seconds per song, depending on size.
Hmmm, if it's just a design problem then i don't think it's the sellers fault.
good find. Looks like the payer just sucks, not the buyer
This is not true... I had a Zen Micro before this one without any problems transferring songs at 2-3 secs each.
1. Select 5GB worth of songs
2. Copy to player
3. Go to bed
4. Wake up. Bam! Several months worth of music on player.
5. ???
6. Profit!
HonkeyDonk
4,020
So when you plug the device into your computer, does windows pop up saying "USB 2.0 device found" or does it say "You could be running this device faster..."
If it says USB 2.0 device found and it's running slow...then maybe it's either: 1) Design flaw or 2) actual hardware flaw
If it says "you could be running this faster...", then it's either: 1) your comp doesn't have usb 2.0 correctly installed or 2) it's actual mp3 hardware fault.
First determine 100% whether it's not running at USB 2.0 high speeds due to hardware fault. If so, then the seller should refund you since it's not "flawless" as he said it was. But again, this is cragislist so it's really iffy.
But if you can't get him to refund you, then have you tried to RMA the sucker? If it's still relatively new, you still should have some warranty.
Kelvrick
18,422
Ok, I think it was a little harsh earlier, but I still don't think you should be getting a refund. I looked at the creative site for the zen micro and I see a lot of "usb 2.0 blah blah" but I don't see the mention of usb 2.0 high speed.
Care to link somewhere that says so?
The player is supposed to be high-speed.. Check here.
Where does it say usb 2.0 high speed? It says "Hi-Speed USB."
Brassman
1,984
Using Notmad Explorer... but, have also used creative's program..
Brassman
1,984
Windows says "the device could be running faster if you plugged it into a HI-SPEED port" and it lists the ports that are supposedly hi-speed (but there's nothing connected to any of them. I've tried all ports on my computer and i've even bought a PCI USB 2.0 expansion card with no luck. See here.
Brassman
1,984
Originally posted by: WTT0001
Just a dumb question, have you tried a different USB cable???
WTT
Yes, i've tried 3 different cables that are "rated at USB 2.0 Hi-speed" ... one of which I used with my old Zen Micro (which worked at "hi-speed") and including the one which came with the Micro.
Brassman
1,984
Originally posted by: Pepsi90919
but there's nowhere on the post which says it's an "as-is" sale... I've
then it's an as-is sale.
Never heard of that in my life.. I've heard that you have to list the item as an "as-is" item if there's problems with it?
Brassman
1,984
and
Indeed. But - it should hit more than 7mbit/s
Kelvrick
18,422
Iono, you said it worked before you repaired windows, so it looks like maybe a reinstall is the only other choice. But, you said it doesn't work on other computers too...
Iono, i'm still waiting for you to link me to a page that says the creative zen has usb 2.0 high speed. All that I've seen says high speed usb or something like that.
Also, the other thread said resolution found. What was teh resolution?
Brassman
1,984
Iono, you said it worked before you repaired windows, so it looks like maybe a reinstall is the only other choice, unless you wanna go out and try buying another cable.
No no no... it worked before I repaired windows with my other player.. then, I tried to use my new player and it didn't work...so I repaired windows and it still didn't work.. so I reinstalled and it still didn't work. Hope that makes sense?
My resolution was that the player was bad... as I tried a repair, reinstall, update/downgrade of drivers.. new hardware (with new drivers) and 2 other computers that are compatible with USB "hi-speed" devices. Also tried a USB 2.0 harddrive enclosure on my computer in it's current running state and it runs at USB 2.0 "hi-speed"
mugs
48,920
46
WTT
Well there's your problem, you need to pick up a $40 Best Buy Geek Squad gold plated USB cable.
Brassman
1,984
Check here and clicking on the link of "hi-speed" leads you here. Under that page, it clearly states this:
You won't be fooled from now on as you now aware that Full Speed USB is only 12Mbits/second where Hi-Speed USB mode is capable of a much faster 480Mbits/second.
Brassman
1,984
WTT
rofl. you better be kidding. ;)
Brassman
1,984
Yes, i've literally spent a week trying to find alternate solutions for the problem with no luck.
Kelvrick
18,422
Ok, that page links you to usb full speed, but then how come it doesn't just plain say usb 2.0 high speed? Thats what I'm looking for, as that is the definition of the fast trasfer version of usb 2.0. And see, nowhere do I see anything remotely similar to high speed usb 2.0 on the Creative's site.
For all I know, maybe creative used the high speed parts for their earlier models but to save a little money, skimped out? Or, maybe earlier models had the crappy 2.0 and the newer ones had the good one? Maybe, it just depends on each batch?
EDIT: Hmm, it IS USB 2.0 High speed. Creative doesn't really have a good RMA service though. I still don't think the seller is in the wrong, you just gotta get creative in how you're gonna replace your player there. *wink wink*
picture of manual I dl'ed off of Creative's site
Brassman
1,984
In the pic it does say USB 2.0 (High Speed) under the port? I would take that to mean that it is high-speed myself...
Anyways, maybe creative did skimp out, but I seriously doubt it. I'm sure there'd be a major uproar if people bought the player and it didn't perform worth a crap?
And I don't want to pawn it off on someone else... I would have to take a hit on the price and sell it for like $40 less or more just because it's 1.1.. ..If somebody would even buy it for $120... but still, it's just not fair. /whining. ;)
