What method to you choose when you are done using your PC?
  • Shut Down
  • Hibernate/Standby
  • Sleep
  • RavenSEAL is sexy
HAL9000
22,021
I continually hit mine with a small hammer until I hear a crack/ snap, or until the screen goes black.
Unless it's one of my Macs, in which case I put it to sleep.
Bateluer
27,730
8
I let the monitor go into standby, but the PC stays on 24/7. Its better for the system.
It gets shut down and unplugged if I'm out of town for a weekend or on vacation or some such.
Demo24
8,356
9
Hibernate is easy - it's writing RAM to a file (hiberfil.sys) to the HDD.
Standby/sleep is another story. So many motherboard BIOS' issues with that. Both my ASUS P6T7 and REXIII boards do sleep fairly well although about one in ten times I lose USB on wake.
If you don't have a RAID with a "flight checklist" BIOS, it's easier to just shutdown. :D
I find that with the Areca hosts even sleep mode recovery is slow because POST is still running in the background, the display is OFF so the wake time while faster than booting; is still lengthy.
I've been looking for an explanation for why my system takes soo long to boot out of sleep mode. Finally got my answer! :thumbsup: Ironic that my 4 year old laptop can boot from sleep mode faster than my core i5 system I built in January. :\
Regardless of how long sleep mode takes I usually use it on the weekdays, and shut down whenever I leave for the night. By that time it usually wants to install some updates anyway.
1sikbITCH
4,194
574
My main PC stays on all the time as I use it to serve media to the rest of the house. I would just have a server in a closet but my drives are SATA and I don't have another SATA board that I could use for a server.
My bedroom HTPC also stays on all the time too. We watch streamed content on there and whenever I'm on that floor it's the PC I hop on to look stuff up. I could probably put it to sleep or something but I like being able to just shake the mouse and go.
My other 2 HTPC's get booted up and shut down when not in use. One of them is watercooled so I don't want it running all the time and the other only gets used a couple times a week.
BurnItDwn
26,353
1,862
Lock PC, it's habit from work.. whenever I step away.
Then it goes into standby.
yhelothar
18,409
39
Just close the monitor and walk away. I only shut off the monitor since often the idle timer doesn't work in Win7.
I use remote desktop all the time so it's useful that my comp is up, plus I usually have a dozen plus things open so it's a PITA to start over.
Dec 10, 2005
28,896
14,168
HTPC: Sleep. Only gets restarted if it's acting sluggish.
Desktop: If I'm going out for the day or going to bed: shut-down. If I'm hanging around the apartment, just sleep.
Raduque
13,140
138
My desktop stays running 24/7, but I close my laptop and it does STR. It hibernates if the battery gets too low while suspended.
rcpratt
10,433
110
Just screensaver, mine is pretty much running 24/7 unless I'm leaving town for a few days.
rudeguy
47,351
14
61
I turn off my monitors but my computer stays on.
I planted a tree once, so the environment is ok.
xSauronx
19,582
4
done?
i put mine to sleep sometimes...well...really i lock it and it sleeps in a couple of hours, i almost never actually put it directly to sleep
Amused
57,391
19,711
None of the above. My monitor goes to sleep after 10 minutes. That's it. My system acts as the house media and print server. So it stays on 24/7
BoomerD
66,332
14,746
During the day, I just turn off the monitor and walk away...at night, shut down.
rudeguy
47,351
14
61
really? My antivirus and antispyware run at night. I also like to seed torrents to help others (nothing illegal, mostly android ROMs).
Modular
5,027
67
Most of computing time is spent on my laptop. Generally, I have it go to sleep, but if I'm not going to be using it for a while, I'll let it hibernate as sleep mode still draws battery power if it's not plugged in.
My HTPC goes to sleep as well, but I generally shut down my gaming computer.
MovingTarget
9,002
115
I usually let mine fall asleep because I use my pc frequently in short bursts. I watch a TV show on my HTPC, get up to have some dinner, and it has put itself to sleep by the time I get back from nuking a hot pocket. Before I had a PC that had a decent sleep function, I would just get up and turn it off. I still shut it down regularly, about 1x/wk.
Udgnim
3,681
124
sleep, but I've run into sound / mouse stuttering issues when coming out of sleep which require a restart to fix
it doesn't happen often enough for me to stop using sleep, but it's occurred enough for me to remember the issue
BoomerD
66,332
14,746
Fuck that. Those programs get about 18 hours/day to run...and I don't need to pay the electric bill for someone else's benefit.
As old and "dead-tech" as my current rig is, it still draws about 250 watts at idle with the monitor turned off. (per kill-a-watt)
We try to cut the light bill wherever possible nowadays.
I've never seen any real benefit of folding, SETI, or any of the other distributed computing programs. The concept is good...but what has it really accomplished?
HAL9000
22,021
I've got 6 home servers that run 24/7 for one reason or another... FUN!
Rubycon
Madame President
Aug 10, 2005
17,768
485
You must be doing it wrong. :p
Imp
18,828
184
Shut down, don't want to waste the juice. Gets annoying if I forget that I should have done something, and just need to Google something though. Which is why I bought a brand new laptop:).
Shawn
32,236
53
I checked mine with my kill-a-watt and my computer uses 3w both in sleep mode and shut down (unless of course I turn off the switch on the PSU), so it doesn't make sense not to use sleep.
KaOTiK
10,877
8
When I go to sleep I shut it down. Only time I don't is if I'm DLing stuff or rendering.
