Page 1027 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
highland145
43,973
6,338
My fully charged jump box won't jump off the car. I got the $85 one. The wife's has been in the trunk for 2 months and it works fine. She go the $150 one.
Cheap bastard has regerts.
sdifox
100,369
17,931
Did you try the high boost mode? There is usually a button that does that. Goes to like 75A
highland145
43,973
6,338
No boost mode but 75A.....I could do a lot with that.
Pay up, sucka, or the dog get the boost mode. 😀
I've learned that the dog has higher value to a deadbeat than the wife/kids.
13,816
Maybe try different drivers. I start with the open source drivers, then alter as necessary. So far, the open source drivers work fine for my simple needs. I haven't used a proprietary driver in over a decade.
I'm already on the open source ones, I think that's the only option as nothing shows up under the tool to install proprietary ones. (card is an ATI which has good support compared to Nvidia)
It's weird since the problem comes and goes but normally it goes for a good month or two before it resurfaces. The first time it happened I was worried it was the monitor (expensive 4k one) but it does not appear to be the monitor itself. It might also be GPU memory, I read that while researching this. I might try to just buy the exact same card on Ebay or something and hope for the best. This is still relatively minor compared to other GPU related Linux issues I've dealt with in the past, so always reluctant to try a different GPU or driver.
The power company has power lines running through the wilderness? They will do the installation?
Going to setup solar. I have a portable setup for now, but I use the word portable very loosely here... this thing ended up so heavy that it's actually a pain to move it anywhere, even with wheels. I stashed it in the bush for now with a tarp over it. Next time I go I'm going to throw in a bunch of "do not eat" packets in it since when I last checked it, there was condensation building up inside. Probably not good... There's a hard power switch though so think even if stuff gets wet as long as no power is applied to it.
I might actually just cannibalize the parts and setup a permanent system. Either that or I will set it up on an utility trailer. The original goal was being able to load it in the truck with an IBC tote and run a pump to get water but getting it in and out of the truck is involved so that plan will change. For getting water I will probably just use a drill pump. I'll buy a basic Ryobi drill and set it up with an on/off switch so I can flick it on and leave it. Won't bother doing anything to do with water until I have a building with heat though otherwise the pipes will freeze. We get freezing days even in middle of July sometimes. I would purge everything in winter as solar won't be enough to keep things heated until I'm more established with a big system like 10kw.
Reactions: highland145
13,816
This was today's FWP but kinda averted.
Working my next 2 shifts at the office and when I came in our public wired internet was not working. Supposedly it got ransomware attacked by hackers, so they turned it off while they investigate. We were told to scan all our devices but mine is Linux so I think I should be fine... I don't see anything weird. Recently bought this NUC too since the laptop stopped playing nice with my KVM. So it's a relatively new fresh distro install and all up to date.
Was going to be a very long night without it, but I managed to get the public wifi to work on it. For some reason the wireless option was not showing up but when I did lspci there was a wlan adapter. I found on Google that if you pull the power cord from the NUC and hold the power button for 30 seconds (with power cord still out) and then plug it back in, it fixes the wireless issue. And it worked! I have no idea how that even does anything, but it somehow did. Guess there is some residual power in the box and it detects that as some kind of reset sequence or something.
Failing that I can still surf on the corporate network but without vpn access to my home network to access my password manager I don't have any logins to any sites I use.
That ransomeware attack is an eye opener though... wonder if my home network could have been hit while I was VPNed in. I should perhaps add some restrictions on the vpn. If I want to get to stuff past that I'd have to do a SSH tunnel through a jump box.
balloonshark
7,148
3,622
I forgot the put the coffee pot on the warmer before turning on the coffee maker. I burnt two fingers removing the full filter basket that overflowed everywhere. Coffee grounds were everywhere. There is nothing worse than having to deal with a problem before getting your first taste of coffee. :mad:
13,816
Crackheads keep cutting our fibre optic cables thinking it's copper and it's making us busy at work.
They need to start charging these people with domestic terrorism. I'm sure severing major telecommunication lines could count as that. Especially when they manage to isolate entire towns.
Reactions: pmv
sdifox
100,369
17,931
Another restaurant gives me a VIP card that gets me ten percent off. Problem is I have to pay in cash. That means going to the ATM so I am not sure it is worth my time :colbert:
Motostu
578
598
Speaking of AC, a snake got into the fan of our outdoor unit today. Got wrapped around the motor shaft, so my FWP was having to get it out and clean the inside of the unit.
Poor snek :(
13,816
Home now, switch into shorts. Nothing worse than being overheated in pants, they seem to just absorb and capture the heat and you can't cool off even once you move to a cooler place.
One of the managers did find a snake in his office the other day, maybe our AC was also a victim of snakes. :p
There was also a snake in the customer care centre, thankfully they found it before the CSRs showed up, they would have been freaking out lol.
13,816
More my company's first world problem and not mine, but someone decided it would be fun to set off fireworks off the vent pipe leading to the battery room. That could have been very bad. They also stole the valves for the fire standpipes a while back. Seems that building has been made a target now that we don't work out of there anymore, so there's less activity. There's no windows and it's a rather plain looking building so they probably think it's abandoned.
