kjboughton
- Dec 19, 2007
- 330
- 117
- 116
Post your CPUID or simply a CPU-Z screen shot if you are unsure what is being asked of you.My problem is that i have QDE4 engineering sample and it is 4770K.
Post your CPUID or simply a CPU-Z screen shot if you are unsure what is being asked of you.Hello i have a problem
then i try to Load v3.efi in to shell it says Wrong cpu but i have a E5 2650 v3 but is this because its an es model
Thank you! When I have time I look into it.Thanks for answer. I ran last night sandsifter for you. Here is the file, it is most efficient compress that I have ever done, 238 Mb > 2,3 Mb
sandsifter_instructions
Tell me if you need the log file with different settings.
For me it did not solve the bug. Anyway its not only the BSOD you will face problems with. See above mentioned bugs. Much earlier post in this thread already discussed this issue and suggestions kept disabling C3.Balanced Performance perhaps allows C3 at the core level (which cannot be stopped with the in-BIOS Package limit) and BSOD can result.
It should be fused. However if you dig into the technical papers there are many points which may raise your eyebrows. Intel clearly defined ways to change how the EDP is determined, and even disabled. Further going from no microcode to latest, Intel changed twice the EDP calculation for bug resolving. So if its in the code, its code (logic, he?^^).Nearest I can tell EDP is a hardwired (fused) limit set at time of binning must like how multipliers are set.
here you go. made one for you. removed haswell microcode: http://www.mediafire.com/file/vrvi4ruah3uovv0/mod_X99TC_1.80/fileCould I ask you for the Taichi x99 bios which you gave to shorty1111 ?
Thank you![]()
Thank you ! I'm going to deploy it nowhere you go. made one for you. removed haswell microcode: http://www.mediafire.com/file/vrvi4ruah3uovv0/mod_X99TC_1.80/file
V4 won't work with this all core turbo mod. As for the V3 I believe the 2696v3/2699v3 will get you the highest overclock speed of about 3.9ghz on all cores. I believe I saw that that chip has 38 multipliers so you would only need to push your bclk to 102.6mhz to get 3.9ghz.Hello everyone,
What pair of xeons E5 v3(V4) do you recommend to get max performance after OCing (I will be using them for poker solving calculations which means it's 100% load)?
That's strange. Not sure what's going on there. I could try again tomorrow and give you the file. Which version do you need? Link meThank you ! I'm going to deploy it now
Update:
Weird, I checked and the microcodes are not in the given bios yet ... it did not work:
https://ibb.co/iCqk3L
When I load v3.efi it says the Microcodes are present.
On second bios I have version 1.40 and the v3.efi does work there ... yet both checked bioses shows exactly the same status in MMtool for microcodes.
But if you have a m.2 SSD drive you could stuck under 101 Mhz BCLK, like me.V4 won't work with this all core turbo mod. As for the V3 I believe the 2696v3/2699v3 will get you the highest overclock speed of about 3.9ghz on all cores. I believe I saw that that chip has 38 multipliers so you would only need to push your bclk to 102.6mhz to get 3.9ghz.
I actually have 5 m.2 nvme drives. All Samsung 970 evoBut if you have a m.2 SSD drive you could stuck under 101 Mhz BCLK, like me.
i7-5930k is bang for the buck to gaming with 2011-3 socket. It is 4,7 Ghz OC capable if you are lucky. Clock-to-clock perfermance is awsome compared to newer skylake and etc.
I won't be using it for gaming at all. Only usecase will be poker solver applications which basically means 100% load all the time. I have seen on previous pages that 18 core xeons can sustain only 3.1GHz turbo on all cores during 100% load, is that still correct or something changed? What for mobo I already own ASUS Z10PE-D16 WS.V4 won't work with this all core turbo mod. As for the V3 I believe the 2696v3/2699v3 will get you the highest overclock speed of about 3.9ghz on all cores. I believe I saw that that chip has 38 multipliers so you would only need to push your bclk to 102.6mhz to get 3.9ghz.
I am currently running 2667v3 which has 36 multipliers and I am able to get 3.8ghz overclocked with a bclk of 105.6. Which is pushing my motherboard's stability -- for this use @kjboughton's base driver without voltage offset. Else you will have stability issues. He and I are both running on the Asus z10pe-d8 ws. It's a solid motherboard.
I am currently using this for work and gaming and I do find that with 1080ti SLI, you will still have CPU bottleneck with 3440x1440 (https://github.com/freecableguy/v3x4/releases/tag/v3x4-0.10b-i306f2-rc9). I don't know if the 3.9ghz or maybe even 4ghz (if that's doable) on the 2699/2696 would help SLI for gaming. If you're looking for a gaming rig, it's probably better to get a second hand i9-9740x or 9760x. Much higher oc capability.
It really does suck that the multiplier on these xeons are locked. I wish there was some hack to unlock them. I am pretty sure they can handle the oc.
Hi foureight84, I need following bios (new NVME drivers - with version 1.40 my PC randomly freezes now with WD Black NVME drive):That's strange. Not sure what's going on there. I could try again tomorrow and give you the file. Which version do you need? Link me
I have EVO 960 256 GB on my own. Maybe 970 can hand more BLCK.I actually have 5 m.2 nvme drives. All Samsung 970 evo
HeyGot the hack applied on my Z10PE-D8 WS with dual E5-2697 v3s.
Sadly, I couldn't get to 3.9 GHz, but it's close.
Running the 3407 bios with microcode removed and the v3x2_80-50-50_39_vcc1.8.efi driver MOF posted a while back.
I left the latest microcode update from Intel in place. It seems to boost to 3.8 in most situations.
I believe the driver is maxing out turbo and 37x is apparently the highest available multiplier for this CPU.HeyI am missing something with the ratio ? is not the e5 2697 v3 x36 max ?
This result is amazing. I was considering buying these two chips: https://www.ebay.es/itm/Intel-Xeon-E5-2698-v3-QS-QGEN-QGN2-2-3GHz-16C-LGA2011-3-for-C612-X99-i7-6950X/163287253604?hash=item2604adc264:g:FzIAAOSwDYxbsOFO:rk:14:pf:0 and possibly OC them to 3.6GHz. Are these QS chips a good idea? I was looking for 18 core xeon, but non-ES chips are still quite expensive.Got the hack applied on my Z10PE-D8 WS with dual E5-2697 v3s.
Thanks !I left the latest microcode update from Intel in place. It seems to boost to 3.8 in most situations.
I had for e5 2697 v3[QS] :What is the max turbo for all cores that someone managed to achieve using E5-2698 v3 or E5-2697 v3?
