v3x2_80-50-50_39_vcc1.8.efi
Where to get for one processor
Give thanks!https://github.com/freecableguy/v3x4/releases
RC9 - you can choose from one of the several different efi's provided by kjboughton.
Hello.
New cpu arrived week ago.
Intel Xeon E5-2666v3 ES QFSC
10cores/ 10 threads 2,90Ghz max Turbo 3,30Ghz
No HyperThreading.
Uncore ratio 27x = 2700Mhz
TDP=135W
Vcore- 1,05V
33x - (1-2core)
31x - (3-10cores)
Price 209USD/ 1piece.
Cpu is not recognized - Asrock x99 Taichi ( 1,80 and 1,40 bios)
Cpu-z 1.86 R2 stepping.
stock perfomance similar to my Intel Core i7-5820K 4,0Ghz 6c/12threads
Cinebench R15 -1215pts.
HWbot X265 bench 43,2fps overkill mode x2
Cpuz 1,86 bench single 336pts, multi 3333pts
I need Taichi X99 bios 1,40 or 1,80 ver modded.
Hello again,
I bought these 2687 v3 QS and they seem to work perfectly fine. What for overclocking I searched this thread, but it is already too big to effectively use it as a source of knowledge (a lot of posts from the beginning of the thread were helpful, but I have no idea if that's current best solution).
I am using ASUS Z10PE-D16 motherboard.
Could someone post their modded bios to this motherboard or briefly explain step by step what to do to get these CPUs to 3.5-3.6 on all cores?
If this knowledge can be found in this thread I'm sorry, but I was unable to find it![]()
bumpTo flash bios on your motherboard did you use something like this: https://www.amazon.es/gp/product/B07DRCVZB3/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 ?
I have almost the same setup (d16 instead of d8) and am wondering what coolers are you using? Right now I have 2x nh-u12s in nzxt s340 case and in aida64 stress test cpu temp maxes out at 67C (stock without OC). I am going to add nf-a12x25 for both coolers as push and put current nf-f12 as pull which should lower the temps another 5C.
I am afraid that it won't have enough overclocking headroom and the only option left will be custom water loop (nh-u14s won't fit in s340, but comparing it to nh-u12s it would be give me 5C lower temps which isn't worth switching to another case).
What do you think. Is 62C(after adding 2x nf-a12x25) during 100% load at stock enough to overclock cpus to 3.7GHz? Maybe I should look at another cooler brands?
Tried flashing this bios using usb flasher. Unfortunately nothing changed. Does someone have another modded bios for z10pe-d16 ws?Try this, I remove secure lock and update microcode
http://www109.zippyshare.com/v/MWaCYD94/file.html
I use Asrock Taichi x99 and it's quite good.I got myself brand new Xeon E5-2650V3
Im wondering what motherboard I should buy?
I was offered the ASUS Z10PA-D8 ASMB8-iKVM 2xLGA2011-3 pretty cheap but can it unlock the core multiplier? 2 socket is not must but interests me for future use.
Or should I choose the easy way and buy Asrock Extreme 4 X99?
Not sure if I understand correctly but E5-2650V3 is quite bad for gaming due to max turbo @ 3.0 GHZ.I mainly game with machine and have watercooled i4770k@4.5Ghz and Titan X maxwell at 1500Mhz watercooled too
I want to use the E5-2650V3 from now on and I got 32Gb@3200Mhz of ram incoming already. Only motherboard is missing.
I have for TaichiDoes anyone have the microcde tc. for asrock exreme 4 x99 so I could just flash the bios and try get more multiplier?
Try using a lower voltage offset like -20 or use this https://github.com/freecableguy/v3x4/releases/tag/v3x4-0.10b-i306f2-rc9 the one without voltage offset. Also in your bios overclock settings, change loadline calibration to level 9 for both CPUs and also voltage capacity to 140%. Also for the ram, voltage capacity to 140% while manually set ram voltage to 1.2v. I have the same motherboard and 105.6 seems stable for me.
Running 2667v3 @ 3.8ghz
Its also support single processor too.v3x2_80-50-50_39_vcc1.8.efi
That's unbelievable result!
For me so far the best results for me are -
-70-50-50 @ 1.9VCCIN with 104 mhz BCLK(over this my nvme driver throws randomly BSOD]
14 cores x35
13 or less at x36
[tested in CINBENCHMARK - 2475 max reached]
with AVX @ x33 for all cores
I have watercooling but the temperatures are under 50C - For now I guess the main problem is that my CPU goes max 130-140W and this is restriction which does not allow me to work with all cores at x36. Even "normal" cooling would handle my CPU now.
I would go for an Asus z10pe-d8 ws. It's a solid motherboard for later down the road if you want to add a second CPU. Check eBay
- CPU an Xeon E5-2620V4. (B0001D, SR2NX, SR2R6)
