Have not tried. I'll need to break down the machine Friday to install new heat-sinks. I'll do so then.can you get away with c3 on
If that's the option in the UEFI bios that searches the local file systems and comes up with a list of images to load, then yes. I forget who calls what option what name... It found the modified 2.13b (as it did with the modified 2.1) and let me select and flash it in without complaint. Subsequent boot showed uCode 0 and the results you see above.you used instant flash correct
that's your increased memory bandwith performance previously lower than asusHave not tried. I'll need to break down the machine Friday to install new heat-sinks. I'll do so then.
I assumed the same, but had not gone back to test it to confirm.that's your increased memory bandwith performance previously lower than asus
think c3 will give you like asus for freq but might have issues prob same for asusthat's your increased memory bandwith performance previously lower than asus
I have full watercooling now but even when using h50 push pull was nice tempsthink c3 will give you like asus for freq but might have issues prob same for asus
will do mine this weekend thanks for testing and yes its instant flashI have full watercooling now but even when using h50 push pull was nice temps
Thanks (many of them) for the 2.13b bios - what's the deal with that? Are they going to post it to their website eventually?will do mine this weekend thanks for testing and yes its instant flash
probably notThanks (many of them) for the 2.13b bios - what's the deal with that? Are they going to post it to their website eventually?
Well, that's terrible...probably not
Yeah, I honestly have no idea if the 4xxx CPUs are even expected to work in X99? Given the additional pin assignments to QPI it seems possible that bios would not be enough, but that if so, modding the bios to support that would not be a trivial (or even necessarily possible, depending on your access to software).Maybe you need to dig reel deep into this fact to get an v3 ES working.
Strange is i think it should be... i have a X99A Raider (much cheaper) and it even takes my E5-2630v4 ES very early stepping...
I looked in your bios, (1D) and there is an entry 2f0603 so i think it should work.
Maybe something else is wrong? Bad socket pins? Tried with one module in dimm A1?
Checked if the GPU is sitting well in the board?
Keep in mind with a BW CPU you are making things even more difficult as the BIOS flashed on the MB presently may or may not support BW. There are quite a lot of x99 and xeon boards out there with BIOS that pre-date BW and corresponding support.Pins are OK,
I try buy Broadwell 14nm cpu e5-4640 v4 and one time check ,
after that I will send the motherboard to the service shop.
Yes, using BIOS v5, deleted only v3 microcode. Using mix of 8 and 4 GB RDIMM ECC (4 of each, total 48G), so there should be no problem.is the mod only done on the microcode?
CekimI haven't tried. It's pretty unfortunate, that lime is dragging their feet on that given the reality of devices starting to require EFI to function as boot devices (NVMe for example). The request for support there seems to go back to at least 2014 with the response being, "don't need it", but even during late 2016, I'm still finding that response.
I'm not a huge fan of Secure Boot specifically - it has caused me enormous headaches, but UEFI is a good thing.
v3 efi files.zipI am having trouble finding the V3x2_cup27.efi file, the link seems to be dead. I found the V3x2_50_39.efi, but I would like to use microcode 27 to get more performance, so if anyone has these files I would appreciate if you can share them again.
I haven't downloaded yet, but if they are booting in EFI mode, you would:Cekim
LTT have rolled out UEFI boot to unRAID 6.4 RC4 - I believe for those with a modded BIOS it should be a case of dropping the EFIShell file into a folder called EFI on the unRAID USB stick - can you confirm? I don't have modded BIOS etc yet.... or any previous experience. This could be a godsend for unRAID users to boost their speeds.
Hello guys, can somebody please re-upload those 2 files? The links are dead. Thank you.Can you try the following two EFI drivers? There's two modifications of the original V3_2 EFI with some additional msr hackery. I've compiled both v39 and uCode-less versions (I run v39 version on my system). They include 50mV vcore undervolting which is stable for me but may be unstable on your system - if you get any weird crashes, I can recompile without it.
!!! NOTE FOR ANYONE DOWNLOADING THOSE !!!
Use at your own risk! Ensure that your CPU has adequate cooling and monitor temperature if you decide to stress-test it! This breaks all in-system power consumption monitors - do not rely on them!
https://ufile.io/skgjj
https://ufile.io/1aiek
Use my link hereHello guys, can somebody please re-upload those 2 files? The links are dead. Thank you.
