WAAAAA!!! Just changed my monitor refresh to 85!!
WinkOsmosis
Banned
Sep 18, 2002
13,990
If a monitor supports 85hz at 1600x1200, does that mean it will do a higher refresh at 1280x960 even though it's not supported?
Shawn
32,236
53
probably.
Kadarin
44,296
16
How can you not realize you're only at 60? That would drive me nuts... I'm currently at 1280x1024@85Hz
niwi7
1,095
how do u change refresh rates? ti4200 here with acer 77e 17" crt monitor
SagaLore
24,036
21
Originally posted by: blakeatwork
weird... just switched between 60 & 85... i don't really notice a difference either way..
Stay with the 85 for awhile, then go back to 60. Then you'll see a difference.
Joemonkey
8,859
4
i'm running dual 22" CRTs and the best they can do is 75hz at 1600x1200 w/ both heads going...
Marauder-
2,248
niwi7 - you dont have to worry about refresh rates if you're using an LCD screen. Your native refresh rate will be fine.
UNCjigga
25,597
10,296
Heh, 1280x1024x60hz works fine for me!
<--recent LCD convert
Actually, before I got my new monitor I couldn't stand anything below 100hz...even 85 annoyed me after awhile. Using a laptop 6-8 hours out of the day kinda spoiled me.
neilm
1,108
Does anyone notice the text is sharper at anything below 100Hz?
I run 1024 @ 90Hz / 19".
geno
25,074
4
higher refresh rates = blurrier image
Chaotic42
34,874
2,034
The problem is that when you get down to 60Hz, the text gets so sharp that it slices through your eyes. :p
neilm
1,108
Cheers I thought so, I'll stick with 90 then :)
neilm
1,108
When my win2000 boots up and gets to the white screen (with the windows logo and blue progress bar at the bottom), that is 60Hz until it loads my personal settings and restores to 90Hz.
Is there any way to get that white screen anything above 60hz?? cause I can hear my eyes crying when looking directly at it.
