Track Car Suggestions
EXCellR8
4,138
949
Would like to get in some serious track time next year; preferably in a decent car that will reach 100mph in under 10 seconds. I had a KA Silvia but I didn't want to hoon it around after I was done refurbing the engine bay; ended up selling it off.
Car suggestions would be helpful, and I don't want to start a brand war or anything... that's what all automotive only forums are for after all.
Was thinking of spending only two thousand, but I'd swing for something nicer if it was a good deal. Drivetrain doesn't have to be anything in particular, but obviously needs to be a stick shift; bonus points for turbo.
I don't know if I'll be doing any actual competitive racing other than trial runs, but the car doesn't need to be insured or road legal, just relatively safe. I was thinking about an MX-5 but the NA models are really aged now and I'm pretty tall so I'm not sure it would be practical.
Just no European money pits... I want to spend more time on the track than in the repair bay fabbing up parts all day long.
Subaru can be tricky with head gaskets and former abusive owners, but Nissan, Toyota, or Mitsubishi and Mazda might be a better pick. Ideally, I just want something that runs well and isn't a Honda. Civics are great, but they are hard to move without lots of proper work and tuning, minus the S2K and RSX S but those are out of price range.
jlee
48,518
224
You want to spend $2k and get a car that will do 0-100 in 10 seconds....?
Unless you have a lot of track time, a stock Miata is a great place to start.
monkeydelmagico
3,961
145
Where dreams collide with reality....
On your budget I would suggest Lemons or Chump car. You will get as much track time as your hooptie will endure.
agent00f
12,203
1,243
86
If you're serious about learning to drive on such a paltry budget you're basically looking at rental karts. Not that it's bad thing since a run in a shifter or even rotax will ensure nothing you can drive legally on public roads will ever feel exciting again.
Zivic
3,505
38
miata has to be the best thing that is even remotely close to your budget. 2 grand barely buys you decent brakes let a lone a decent car
Reactions: iwajabitw
EXCellR8
4,138
949
I paid $1800 for my s13, granted it was a KA and I had to convert to manual... if it was the SR20DET it would have been a $6500 car easy. People go nuts over those motors... obviously.
Like I said, $2000 for the car and it doesn't need to pass inspection. I am in the new england rust belt, so it's easy to talk people down on higher mileage cars. I'm not going to go searching country wide for a gem that I might wreck or may catch fire or something.
I have my BRZ, and I already know how to drive a track, but unless you're sponsored or on a team with several drivers the track insurance is not even remotely practical. Plus, if I wreck a car on the track in a beater I just brush myself off, curse a few times, and put it back on the trailer home.
Lemons is a complete joke. You spend $500 on a car and then several thousand making it as safe as possible with full roll cage, relocated fuel cell, frame rails, plexiglass, and whatever else it needs to be track ready.
Fenixgoon
33,673
13,396
winner winner. the answer is always miata.
agent00f
12,203
1,243
86
The fact that even shitbox racing requires some semblance of safety should tell you something. Because much as you might not give a shit about your own other people do about theirs. If you push on track you will go off, no matter how talented you believe yourself to be.
The common cheapest track car is whatever light piece of crap nobody wants which isn't going to completely fall apart, like maybe a neon. But it's a question which makes no sense because racing is inherently expensive & not conducive to folks for whom 2 grand matters.
Again, if the goal is learning some semblance of driving skill, getting into something you'll spend all your time fixing up is just about the worst way.
JCH13
4,981
66
No one said you had to start your own lemons team. Many teams offer driver seats for 700-1k per race, which gets you 4ish hours of wheel-to-wheel track time and pays for fuel, tires, brakes, etc. It's a great way to get track time without a ton of investment.
It is! Just don't forget the $500-1k in wheels/tires one can easily chew up on a season... frequently much more!
OP - the vehicle cost is a small fraction of what you'll spend to get competitive track time. You'll be looking at 1-2k in safety gear, putting in a cage, 5-6point harness, kill switch, etc. You'll be scrubbing tires and brakes really quick. Then add on track fees, a tow vehicle, etc. You'll wind up spending a lot more than 2k to get to the track and get rolling, so don't get too worried about the specific vehicle cost...
If you're just doing HPDEs, then your insurance might cover you. If it doesn't, HPDE insurance isn't a whole lot: https://www.motorsportreg.com/index.cfm/event/hpdeinsurance
AdamK47
3,638
What you want is a Honda Civic EX. You'll need a massive wing for downforce and a loud muffler for more performance.
GoodRevrnd
6,801
581
I'm wondering what people would pick for max $15k (including initial necessary repairs), but preferably < $10k. I would probably only do HPDEs. Something very small. I think one of my main criteria would be relatively easy to work on myself with inexpensive parts. Somehow I had it in my head I could get a deal on an old MR2, Z, Supra, etc. if I found something serviceable with a trashed interior. Unfortunately, most of those cars are old enough that what is left is in pretty good shape. e36 is a maybe, but that basically doubles parts cost.
jlee
48,518
224
Miata.
You can easily find cheaper MR2s for sale - I think I know of a track-ready ~355rwhp turbo for $12k, actually. Not cheap, but far from slow.
GoodRevrnd
6,801
581
Miata.
Except vert is a nonstarter. Should have mentioned that.
agent00f
12,203
1,243
86
Frankly anything reasonable works for HPDEs, since the point is basic car control skills, unless your goal is learning the prep side of racing which is uncommon; so just get what you like for rest of the time w/ the car. Futzing over equipment details is a typical pitfall for all sorts of amateur sports.
Dr. Detroit
8,660
1,039
The answer is '94 or '95 Mustang GT with the ultra reliable and cheap to modify 5.0L engine. You can dump money into the suspension, upgrade to Cobra brakes, and you will have a great track car. They weigh in at about 3300lbs.
$2,000 is not feasible but you gotta start somewhere.
EXCellR8
4,138
949
I had prepared for this type of thing, naturally, as an avid internet-goer... but I will admit that I probably should have been more careful.
Firstly, it does not take 16.4 seconds to get a brz/86 to 100mph, unless you're towing an atv or something. On 93 octane, I can get to 60 in just under 6 seconds and then maybe another 6 to 7 seconds to get to 100 thereafter. Keep in mind this is a full manual, stock tune, and no weight reduction.
Secondly, when someone says they can drive a track... this doesn't mean they are a professional. I know, it's the internet, and I can occasionally be very quick to judge and placate also... but there's quite a range of skill involved in driving around a track at speed. How do I know this? I've been to many track days and I've completed many clean laps. Yup, I've entered in some real crap boxes, but I've also been behind the wheel of much more capable machines like the 458 and Gallardo. No, I do not have a rich uncle or seriously hooked up friends... I am an enthusiast and I carefully plan outings and attend many events with as many people as possible.
I care very much about my own safety, and even more about others' ...but there is plenty of legal paperwork that attendees need sign before even the tech inspection. Racing is dangerous, is what I am acknowledging here. Just because a car passes tech and is deemed track worthy does not mean the driver will survive a wreck. Yes, I will spend more on top of the cost of the car to prep it... and I will still be in grave danger because anything can happen.
Lastly, high performance driving insurance doesn't cover a whole lot if you read the fine print. It covers basic damages to the track/facility and may not even fully cover damage to other drivers' cars or equipment. If you wreck your car on the track, it's wrecked, and will not be replaced or even partially paid for unless another party can disprove that they were involved. This is all stuff that they go over at the driver's meeting before nearly every public and even some invite only track events.
$2000 is enough to get started with a decent platform car, to be then built up and prepped for an afternoon or two of spirited track time. More time will require more labor, more parts, and obviously more money.
I found a '91 miata a few towns over that I'm going to look at tomorrow evening. It's been repainted, but owner claims it's very sound. I can source a hard top from one of the local part out shops.
iwajabitw
828
138
This is the best thing to do, parts are everywhere and inexpensive.
herm0016
8,524
1,132
You must have a different definition of one second than NIST does. Call it 16. That's more than 50% off of 10 sec to 100. Stock of course. Every test I found was over 16. (YouTube does not count)
XavierMace
4,307
450
The entirety of the internet disagree's with that assessment. I can't find a single reputable site getting the car to 60 in under 6 seconds or to 100 in under 16. I loved then handling and interior on mine, but quick cars they are not.
HarryLui
1,518
33
