Too hot for CPU?
What I got after half an hour:
If it is gradually warming up while just idling, then yes, the case isn't moving enough air.
seams that way.
I haven't add fans yet. And it's with the side panel on
k now play a game putting it under a load for 30 mins and post temps.
If the temps get past 65c then lay the comp on its side, open the side panel and reboot and play for another 30 mins with the case open and on its side.
seams that way.
I don't know why but it seems that my CPU temps never goes above 62*C now. Maybe because I only play warband these days
62c Still a bit warm for gaming but not an issue. I would just thows some fans in the case to help get some of the gpu heat out.If you like get the Cooler Master Hyper 212 evo as well. Its cheap and a great cpu cooler.
Alright, thanks for the help. Man, I made over 40+ posts in one thread 😀
UPDATE: Me again, being busy with school lately. But I'm ready to get the fans now. Problem is, the ones I wanted are no longer available in the store. So I'm left with this or this
