the black cable is the power supply part 😀 ?
Don't think taking off the side panel helps. Just gathers more dust and stuff faster.
Why ask for advice if you already know everything?
Did I say I know everything? I only know about the side panels.
What they are suggesting is just removing the one side panel temporarily, just to see if it helps bring the CPU temps down. If it does help, then that is proof that the single case fan is inadequate. You can reinstall the panel afterwards.
Ah okay, any suggestion where I should place it in order to get the maximum CPU cooled down? I already have a big blue LED fan in the front
Look at the back of the case. See the grill at the top? That's where you put one fan (size 80mm up to 120mm). Make sure that is blowing OUT. Use the fan header at the rear of the motherboard labeled "cha_fan".
Look at the top of the case. See the two grills? Put one in the front grill. Make sure that is blowing IN.
Well since I can only get one, I'm going to have take this
Although I can't take off my side panel right now, I started to download Killing Floor about 20 seconds ago, my CPU temperature went from 40*C to 48*C. Is that a clear "symptom" showing my fan isn't working?
Edit: Going to sleep now, will check in about 10 hours.
Why can you only get one? The price of two of those (98x2=196) is roughly equivalent to one of the fans (185) you said you could get earlier. Either way, get what you can, but definitely get something.
As for those temps, yes, something is not working very well. I would expect a small bump in temps, but not that much just for downloading files.
EDIT>> To keep cost down, you could get one of these (79) for the rear and one of these (98) for the top (79+98=177).
Played Team Fortress for an hour, temperature is 70 C O_O
Better get the hyper 212 fast
Mainly because I only have one 3-pin plug and have no idea where the second plug is going.
yes put the case fan money toward that ?
From the first pic you posted, you can see two of those 4-pin molex plugs (red circle). You would use one of those.
My main object now is to get the hyper 212 first, then we'll see if I can afford the fans.
But if I don't get a cooler/case fans forever, how long would my CPU last?
EDIT: Several of my friends say the stock cooler on my CPU is pretty much a horseshit dipped in molten lava, puked by a fat lady.
