AnonymouseUser
But if I don't get a cooler/case fans forever, how long would my CPU last?
EDIT: Several of my friends say the stock cooler on my CPU is pretty much a horseshit dipped in molten lava, puked by a fat lady.
The stock cooler should be adequate given proper case cooling. Even the Hyper 212 Plus/Evo needs proper case cooling.
For example: I put a PC together for my SO with my old parts and a new Hyper 212 Plus. The case I put it in was an old case and only had one front fan, so the CPU temps were pretty bad and prevented me from Overclocking the Athlon II X4 635 (default 2.9GHz). Adding a second fan at the rear allowed me to overclock to 3.5Ghz with very acceptable temps.
So all I am saying is that while yes, the Hyper 212 Evo will certainly help, it is also possible you won't need that if you give your case the cooling fan/s it needs.
