T
What's funny is that of 0 of the Colts balls were out of spec and the balls were measured immediately at half time. That meant that the COLTS balls were over inflated. It is an absolute fact that all the balls would have been 1 - 1.8 pounds lower at Half Time. That means either the NFL adjusted for the loss in pressure for all the balls when doing the half time measurements or the COLTS balls were overinflated to not have been out of spec.
Seriously with your bias it's time you pull away from the thread. This team is infallible in your eyes
bwhahahah
keep it going. some of you are looking like major idiots.
oh my god! htey fumbled more after they went to other teams! noooo! lol
Also, only beta chumps use non-confrontational passive language like "some of you". There's a reason God built you the way you are and me the way I am.
Speaking to reporters on Thursday, the NFL's vice president of officiating Dean Blandino explained why the Patriots had an illegal formation on the play when Solder recorded his first NFL catch and first NFL touchdown in the same play against the Colts in the AFC title game.
Right.. so the Pats balls were deflated by the temperature but Indy's stayed to regulation. Did those "scientists" explain why ones teams balls deflated and the other didnt? The answer is NOPE they just call it a "loose end" in the FUD article that bias cheatriot lover is sharing.Bias? You post FUD and get counter posts with data showing your post is incorrect but you keep on posting.
http://www.csnne.com/blog/patriots-...uchdown-play-was-illegal?p=ya5nbcs&ocid=yahoo
Now it's just not "the biased Patriot hating" Tony Dungy complaining of the illegal formations of the Patriots, the NFL is making official statements now.
Sure the Patriots didn't need the illegal formations to beat the Colts, but they absolutely needed them to win against the Ravens.
This has been adressed several times in the damn thread.Right.. so the Pats balls were deflated by the temperature but Indy's stayed to regulation. Did those "scientists" explain why ones teams balls deflated and the other didnt?
bwhahahah
well they were not taken into the bathroom on the indy side that is for sure.Yawn, do you know where those balls were inflated to what psi, what process was used to prepare the balls, etc... Looks forward to your link that shows it.
Sure the Patriots didn't need the illegal formations to beat the Colts, but they absolutely needed the illegal formations to win against the Ravens.
"Maybe those guys got to study the rule book and figure it out. We obviously knew what we were doing"
that's weird. they came out saying it was legal too.
Since then there have been other issues with the substitutions taken which I haven't seen the NFL respond to. I posted a link earlier. The formations are legit and the substitutions are valid in regards to the players initially coming on the field and registering eligible or ineligible but Dungy raises concerns that the protocol for successive plays was not followed.
I haven't dug into that part of the rule book so I won't venture a guess if Dungy is right/wrong but it is an issue being raised.
Note I am not anti-Belichick on these exotic formations. I like the change of pace deception.
The first two times the Patriots used the tactic, Vereen and Hoomanawanui, came off the field on the following play. The third time, a penalty allowed Vereen to stay on the field for the next play.
I agree!! I've never seen a single play turn a game around. Just ask my Browns "The Fumble" or ask Dallas "the Catch"One illegal formation not formations but keep on spreading FUD.
So can we file "FUD" under Capt Caveman like McOwned's "Bridge to sell" now? overused, worn out and unoriginal as hell?The formations against the Ravens were all legal and I already debunked the FUD.
That's completely incorrect. Dungy is an idiot and hater. If you note, he was corrected in that article over another illegal play that he thought NE used against his own Colts.
Patriots receiver-eligibility tactic could catch on
Dungy should retire from being an analyst.
Nope never in the history of the world has a single play changed a game.
Wrong again.
Absolutely NOT true. While it is true that they were exposed to the same conditions after being inspected by officials, there are many factors leading up to that you have failed to consider. For one: they could have already cooled or been exposed to those conditions before their initial inspection before the game. Hell, they could have even been topped off again once cooled. They could have been at the opposite end of the range (13.5 PSI). They could have been filled with cool air in the first place and allowed more time to cool before inspection (pressurization with environmental air proportionally raises temperature relative to the environmental air outside).
The Pats, preferring a ball on the low end of the range, would have done the opposite, such as inflating to the low end of the range (12.5 PSI) while warm and keeping them warm until pre-game inspection, filling them with warm air to begin with and not allowing much cooling time before inspection.
I can't believe how many times I have had to explain this. Does no one think critically anymore?! The world isn't as simple as you want it to be. We know that the rules were changed in 2006 to allow them to tailor the balls to the QB's preference and this is the kind of tailoring they were talking about. Duh.
Likely filled to spec.. I'll file that under ASSumptionI just explained how for the umpteenth time in post 700. I shouldn't have to explain it even once, but it seems that the world is full of blind idiots.
Let me put it in a way your simplistic mind can understand: their balls had already dropped in pressure when they were initially inspected before the game. They were likely filled to spec in conditions closer to what they were to experience during the game which would lead to less deflation by already being exposed to the same or similar conditions.
Go go, gadget BRAIN!
ohhhhhhhhhh Snapple!Well the lack of critical thinking would have to be on your end in this circumstance. You are missing the fact that the balls sat in the complex for 2.5 after being checked by the Refs.
So..
The Refs checked the balls and they were all between 12.5 and 13.5 PSI. The balls sat in the complex for at least 2.5 hours before the game began. If the Colts balls had been at 13.5 PSI because of initially being inflated in cold weather, they would have inflated due to the temperature inside and outside the ball reaching equilibrium which would be the temperature inside the complex. If they were 13.5 as you stated the colts like the ball it would have inflated past the 13.5 PSI once the air warmed up. Thus being overinflated. (Same concept of pumping hot air into the ball to make an underinflated ball legal at ball check in). Agree or Disagree?
The balls deflated by an average of 1.8 PSI (HeadSmart Labs) due to the rain and cold. Unless the NFL let the balls reach equilibrium inside then the Colts balls were either overinflated to stay in the range or somewhat underinflated as well.
Math -
Based on the HeadSmart Labs, the average PSI drop was 1.8 PSI
13.5 PSI - 1.8 PSI = 11.7 PSI
11.7 PSI < 12.5 PSI (the low range of acceptable ball PSI)
So, tell me how the Colts balls were not under the range or not initially overinflated if the Refs didn't let the balls reach equilibrium inside the Complex before testing.
Disclaimer: I'm an Engineer so rely on math and science. So, the only facts I trust are the calculated numbers people have put out on PSI drops due to ideal gas law.
