question, don't they share the balls? so like, those under-inflated balls would end up on Colt's hand and to their advantage.
Under Inflated balls are easier to throw and catch. Patriots throw the ball more. Colts have a running game.
This is such a non-event. I feel for sorry for Brady, that this is going to take away some of his thunder.
I think they should be forced to replay the game...with footballs controlled by the NFL...and played this time in Indy.
would be the most epic thing EVER
Perfect. It can replace the pro-bowl.
You want to trade one game that no one watches for a game almost no one will watch?![]()
Of course tires are inflated to 35 psi. But if going from 70F room to 30F field, and scaling by the pressure difference:Air pressure in a tire typically goes down 1-2 pounds for every 10 degrees of temperature change.
OK, the Patriots may have done something outside the rules, and that's unacceptable... but I don't care if the Colts used regular balls and the Patriots used origami footballs, the Patriots are still winning that game. It was 45-7. Does anyone on Earth legitimately believe that's solely because of a few pound feet of air pressure in a ball?
yup
NFL rulebook states 25k per person responsible for tampering with balls.
I bet they lose draft picts.
they are gonna CUT EM with a shiv and let em bleed a little roster wise.
I bet 2-3 picks including 1st rounder gets taken away.
members of the Ravens on twitter are complaining about balls too.
All of a sudden the nfl is tea bagging each other
Two pounds of air is a ridiculous amount.
Are you sure it wasn't two PSI?
Everybody on earth pretty much feels the same way, which begs the question yet again of WHY are they cheating? They're good enough to win, why do they do things like this?OK, the Patriots may have done something outside the rules, and that's unacceptable... but I don't care if the Colts used regular balls and the Patriots used origami footballs, the Patriots are still winning that game. It was 45-7. Does anyone on Earth legitimately believe that's solely because of a few pound feet of air pressure in a ball?
Anyway, I'm still not sold they were deflated on purpose. They need to find how it was done and who did it before I buy it. It was cold, and that's enough to change the pressure if the balls were filled at room temp. Probably happens all the time and nobody really notices.
