Titans & GTX780's at 1.4Ghz with unlocked voltage control
BallaTheFeared
8,115
You can generally tell what vram you have based on the offset it will hit, but not always but it doesn't really matter what brand you have, only what offset you can hit :ninja:
rtsurfer
733
15
Actually found the right program on OCN.
Download Nvidia Inspector from Guru 3D.
For some strange reason I cannot post the download link.
Download the program and hover over Memory Type.
I got Samsung, Yayyyy..
jj109
391
59
I thought I had crappy Elpida RAM when I couldn't even do 6400 MHz, but turns out I have Hynix. I tightened the baseplate on my card a bit and now it's stable up to 7000 MHz.
I'm okay with this. :)
BallaTheFeared
8,115
Does this reset after power cycling? Would be pretty annoying to forget about it after restarting just to have the GPU fall flat on its face.
I don't know why I didn't think of this before, but it's pretty easy to get this to run each time you cycle the power.
It's pretty easy let me step it out here quick if you're interested...
  1. Go to your MSI Afterburner folder
  2. In the main folder with MSIAB.exe create a text document
  3. Open the newly created text doc and and put msiafterburner.exe /wi3,20,DE,09
  4. Close the text doc and rename it to LLC.bat
  5. Right click LLC.bat and create short cut
  6. Cut your LLC.bat(Shortcut) and paste it into your Startup folder
C:\Users\Balla\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
Each time you reboot/restart windows it will now run.
Face2Face
4,100
215
So I think I found the max on this card with my current cooling setup. I am pretty sure I can get 1550Mhz+, but a custom loop would be needed. This by no means even close to being stable for daily use, but it's still fun to see how hard I can push the card. I have a very basic 750w PSU, which is probably stupid to do this with. I saw over 800watts from the was with this single Lighting overclocked. For comparison sake, this card at stock settings pulls 315-325 watts from the wall in the same benchmark. After efficiency, I am thinking the card alone is pulling over 500-550 watts -- Freaking nuts. I didn't think one card could pull this much. I know It would pull less with a custom loop with lower temps, but hot damn... Too bad my card wasn't blessed with Samsung memory.....
lavaheadache
6,893
14
face2face,
That's a pretty manly overclock. Thread carefully though. I would be scared to go much higher though. Surly that kind of voltage for any length of time has detrimental affects. Maybe not...
Do you have any comparison numbers to see how well the clock speed is scaling?
Face2Face
4,100
215
face2face,
I ran the Tomb Raider benchmark and only saw a 6-8 FPS avg gain going from 1320/1656 to 1502/1656. A good memory clock is needed in order to see good scaling in most games with a GTX 780. I would never run 1.45v for any extended amount of time, but I wouldn't think twice about 1.35v for gaming. The power delivery system on the Lightning is incredible. 16 GPU phases and 3 memory phases, even @ 1502Mhz this card didn't blink running these benches, of course my cooling setup wouldn't keep it cool enough to game on. I only wonder what it would do with a full water block?
800 watts from the wall on 1 card??
Yeah - pretty nuts. Couldn't believe it when I watched the Kill-A-Watt hit mid 700's then spike to 800+ often... Pretty funny 181% power limit :D
lavaheadache
6,893
14
I wouldn't be surprised if a minor cpu bottleneck is holding you back from time to time.
I know even 1 overclocked 780 ti gets held back in certain spots in quite a few games on my 30". The metro LL benchmark is very cpu limited for me with 1 card let alone that I have 2. Even when I use my 4k screen I get the same behavior.
check your gpu usage #'s.
Face2Face
4,100
215
I have noticed Metro LL does exhibit odd GPU usage. I wasn't sure if this was because of a CPU bottleneck or the game engine itself? The CPU doesn't get that high in that game that I have noticed. Besides that, they only other games that I play that I know have a CPU bottleneck are Hitman AB and Crysis 3.
lavaheadache
6,893
14
When looking at cpu usage you have to look at per core load not the cpu as a whole. A lot of utilities report load differently so you really have to be sure what it is actually telling you. Current cpu's are definately too slow for current highend gpu setups.
Face2Face
4,100
215
When looking at cpu usage you have to look at per core load not the cpu as a whole. A lot of utilities report load differently so you really have to be sure what it is actually telling you. Current cpu's are definitely too slow for current highend gpu setups.
I use MSI AB to monitor core temps are usage. If you look in the screenshot I posted above you will see it in the bottom left corner.
badb0y
4,015
30
I can get my reference GTX 780 to 1.2 Ghz on 1.2 Vcore. What do you guys think is reasonable voltage to put through on a reference card? My max GPU temperature has been 45 degrees Celsius so far.
Face2Face
4,100
215
With a full cover block 1.3v should be completely feasible for 24/7 use. Maybe even 1.35v?
badb0y
4,015
30
Stupid vDroop is killing me, I was running Heaven on a loop and I saw the voltage drop from 1.2 to 1.162 and the graphics driver crashed immediately. Guess I have no choice but to flash skyn3t's BIOS.
Also I have Samsung memory and I can push +500 easily. So I was at like 1215 core/ and 3500(7 Gbps) memory. I think I will push it more but I have to get my core stable first.
