JEDIYoda
I actually made no point for you..because each case has different results...
Your statement in and of itself can be true but because your PSU is housed in a different location doesn`t mean your case is superior.
Also most PSU`s are tested at 40c...and alot are still tested at 25c....
Thats another reason I went with the PSU I did..... 50c...
Interesting reading....
CPU: One of your apparent pet peeves has to do with PSU temperature ratings. Why exactly?
Dodson: People don?t understand that the actual temperature that the power supply and its components see is far higher than room temperature. When a power supply is rated for 25 degrees C, like most of our competitors, especially the ones that are designed for home use, that?s a totally fabricated number put together in order to exaggerate the wattage claim.
CPU: Why fabricated?
Dodson: There is no way in the world that the air going to the power supply is going to be 25 degrees Celsius in the real world because with a 15-degree buildup inside the machine first, before the air reaches the power supply, that means that the room temperature would have to be 10 degrees C. Now you?re talking about it being in the 50s Fahrenheit. What these guys selling power supplies rated for 25 C are saying is that as long as you use the power supply in a room that?s 50 degrees Fahrenheit, you?re OK. But if you were to actually go through the de-rating that they keep very secret and re-rate those power supplies that are rated at 25 C at a more realistic 40, you?d have to cut the wattage rating by at least 33%, compared to what they?re advertising. You have a 400W power supply, but the fine print is, yeah, at 25 degrees C. At 40 degrees C, it?s a 300W power supply, and the public doesn?t understand that it?s not getting an apples to apples sort of rating when it is out there, buying it in the store, because these manufacturers don?t even specify what the ambient temperature is for full load. That?s one of the most common deceptive practices in the power supply business.
CPU: But if this were such a big deal, shouldn?t it have been more publicized by now? Does it really matter in the real world?
Dodson: For the last five years, companies have been marketing power supplies as being 400W and 500W on this basis. And they?ve been getting away with it without any sort of testing or validation by anyone. The reason they got away with it is because computers, up until recently, only needed like 300W. Since they only needed 300W and were actually capable of 300W, you don?t get caught if you?re saying yours is 500W. You only get caught when suddenly there?s technology that really needs 500W. For SLI you?ve got like 200W just for the video and another 120W for the CPU. So when the temperature inside the power supply starts getting way high, and it?s not designed for that, before you know it power supplies are just crapping out left and right. They were never designed to produce a realistic, true 500W in the first place.
CPU: So if we buy a 500W PSU with accurate thermal considerations, we?re good to go?
Dodson: Actually, it really isn?t the wattage of the power supply that counts today, because if it?s all on the wrong rails, it doesn?t do you any good. The only rail that matters whatsoever in today?s systems is the 12V rail. That?s because the video cards, CPUs, and drives are all being run from it. If the power supply design isn?t recent and doesn?t take this fact into account, it doesn?t matter if you have a 500W power supply, if it only has 20A of +12V power. You?ll see 600W power supplies that are down at 24A, whereas our 510W puts out a continuous 34A. That?s 50% more power than a power supply that, by wattage, is rated higher than we are.
CPU: Should people focus on peak or continuous power ratings?
Dodson: You want to zero in on the peak rating of the 12V output and how long that rating is for. If you get a 15-second rating on that and you have plenty of amps, then you know that even if you have eight to 10 hard drives, you?re going to have no trouble bringing them up simultaneously, with no need for sequencing or a second power supply. But a one-second peak isn?t going to get you anywhere. If it puts out the power for one second, that?s not enough time for the drives to get going.
CPU: But drives have very little draw.
Dodson: Well, drives on startup have 300% more draw than they do after they?ve stabilized. So even though they may not require much once they?re running, like say they require an amp of 12V, which would be 12 watts. Well, at startup, they could require 3A, which is 36 watts. Now if you have, say, five of them, that?s a 180W peak load at startup, which would be enough to bring a lot of power supplies to their knees.
Now lets take a closer look at your misinformed statement...based on assumptions..
Then you can easily take off 20-30% of the power supplies capabilities if it is housed like most computer cases, at the top of the case.
So what are you using to back that statement up??
Just because a PSU is housed on the bottom rather than the top doesn`t mean the ambient temps are going to better....
A case in point.....my ambient tamps inside my case are in the low 20`s celcius...
You are also assumming that a majority of people with top mounted PSU`s don`t have adequate airflow.....
Some of the Lin whatever cases actually are designed with the power supply mounted down low to help in this matter. YES....Lin cases are nice cases but without proper airflow they are just like any other case with bad airflow.
Remember, your case will run 10-20 F hotter at the top of the case than the bottom.
Possibly so thus the need to have proper airflow throughout your case.
For every 10 F higher temp, you can knock off 10% in the power suppy's ability to deliver juice.
Where did you get that figure from?
Then you make a bogus statement in and of itself...
I'm not going to dig for obscure sources to prove the point further on a subject that is common knowledge in EE circles
Of course your not going to dig....also if what you are stating is obscure then perhaps it is also outdated information...
So I guess I guess my response did not prove you correct..
and lastly the only thing you did was add another reason as to why people should purchase a quality PSU instead of a piece of Junk.
3-5 yr warranty......preferably a PSU rated/tested at 40c -50c.......
It would appear there can be huge problems with actual factual specs that become scewered if a said PSU is rated using 25c..instead of the more honest 40c or 50c.
In fact a PSU when compared to one thats rated 40c to 50c....becomes for lack of better terminology suspect to false wattage claim..or at best need to be scaled down accordingly!!
Have a nice evening!!
