Originally posted by: dirtfarmer
:roll:
do in your view a Diablo / 400-Watt / ATX / Dual 80mm Fan / 24-Pin / SATA Ready / Power Supply (D15-1052) is not to good power supply
Originally posted by: jonnyGURU
¡El Diablo es una fuente de alimentación hecha del caca!
The Diablo is a source of food made of ******? How droll. 🙂 Caca pasa!
Source of FOOD?!?! Source of POWER!!! Made from caca!!! 😀
Yep! Alimentación is literally, alimentation or food energy. Alimentos are items of food. And caca is our local slang term for mierda a.k.a. merde, a.k.a. that bad smelly stuff.
OK a very liberal translation would, POS. And that is "un pedazo de mierda." A "PDM?" 😀
All kidding aside - an excellent series of articles and knowledge. Good job!
Originally posted by: GalvanizedYankee
This should be a new thread.
I would only use an Andyson built Ultra PSU. The UL number would be E239028.
The Youngyear built Ultras are E126556 and I would avoid those myself.
...Galvanized
Originally posted by: integramodder
That is a picture of the first computer pop up I've gotten in reference to my power issues. I am going to take it apart and see how I have it wired to make sure I'm not putting too much strain on the PSU on one rail.
This is my system:
AMD Athlon 64 3000+ Winchester 1GHz FSB Socket 939
Leadtek GeFORCE 6600 GT
1 GB RAM, 2 Sticks
1 10000 RPM Raptor
4 7200 RPM HD's
1 CDRW
1 DVD-RW
4 Panaflo 80mm Fans
This is my system:
1 GB RAM, 2 Sticks
1 10000 RPM Raptor
4 7200 RPM HD's
1 CDRW
1 DVD-RW
4 Panaflo 80mm Fans
You need to connect a power cable from the PSU directly to your 6600GT.
This is my system:
1 GB RAM, 2 Sticks
1 10000 RPM Raptor
4 7200 RPM HD's
1 CDRW
1 DVD-RW
4 Panaflo 80mm Fans
Assuming that 6600 even has a power connector, right? 😉
This is my system:
1 GB RAM, 2 Sticks
1 10000 RPM Raptor
4 7200 RPM HD's
1 CDRW
1 DVD-RW
4 Panaflo 80mm Fans
It does not.
These are the specs for my current power supply.
Is this enough?
This is my system:
1 GB RAM, 2 Sticks
1 10000 RPM Raptor
4 7200 RPM HD's
1 CDRW
1 DVD-RW
4 Panaflo 80mm Fans
It does not.
Is this enough?
Can you provide a link to your graphics card? Is it AGP or PCI-E?
Brand Leadtek
Model PX6600GT TDH
Interface
Interface PCI Express x16
Chipset
Chipset Manufacturer NVIDIA
GPU Geforce 6600GT
Core clock 500MHz
PixelPipelines 8
Memory
Memory Clock 1000MHz
Memory Size 128MB
Memory Interface 128-bit
Memory Type GDDR3
3D API
DirectX DirectX 9
OpenGL OpenGL 1.5
Ports
D-SUB 1
DVI 1
TV-Out S-Video/Composite Out
VIVO No
General
Vista Ready Yes
Tuner None
RAMDAC 400 MHz
Max Resolution 2048x1536@85Hz
RoHS Compliant Yes
SLI Supported Yes
Cooler With Fan
Operating Systems Supported Windows 2000/XP
System Requirements Intel Pentium III, AMD Athlon or compatible CPU
64MB System Memory or above
CD-ROM
Requires PCI Express x16 slot compliant motherboard
Originally posted by: dBTelos
You have plenty of power.
-dB
-dB
Thanks.
Do you know why the vid card could be displaying such a fault?
