cbn
Here is my Mini Review of the Fractal Design Core 1000:
Pros- 1.) Overall a very nice looking case (with good build quality) for something so budget. 2.) Drive mounts (on the removable vertical mounting plate) have rubber grommets to isolate noise and vibration. Second 5.25" bay comes with a built-in 3.5" drive adapter. 3.) Will accept a maximum length video card (350mm length) with either side mount or back mount PCIe power connectors provided the lower drive mount on the Vertical mounting plate is populated with a 2.5" SSD, not a 3.5" drive.
Cons- 1.) Maximum cooler height listed at 135mm 2.) Rear fan mount is 92mm (rather than 120mm) and does not come with a fan mounted. 3.) Drive spacing on the vertical mounting mounting plate means that either two SATA strands from the PSU will be needed or a single strand with three SATA (with the first and third SATA being the ones used). 4.) Cable management options are limited.
Overall, I do like this case a lot.....and would buy again.
