GaiaHunter
- Jul 13, 2008
- 3,723
- 418
- 126
Do they make stock 675 core EVGA cards?
I think 720 core is the NEW Evga stock speed. My bad you right mabe the temp would rise 2c. I really didn't notice.
The 6850 still runs hotter then the gtx460.
And the TDP is not MUCH lower for the 6850. Its about 11 watts.
So you just decided to ignore the TDP measurements of AT from the exactly same review where your temperature figures came from?
Well lets get the PCperspective ones then
Doesn't seem to be 11W,
http://www.pcper.com/article.php?aid=1022&type=expert&pid=13
Temperatures are tricky because they depend a lot on the cooling solution at work with each GPU but can still provide an interesting data point. For instance, the new HD 6870 runs about 10 degrees C hotter than the HD 5850 and the reference GTX 460 1GB card easily becoming the "hottest" card in this segment. The HD 6850 doesn't fare much better as it runs hotter than anything else we compared it to.
Obviously the HD 6850 chip is running cooler than the HD 6870 chip but AMD's cooling solution choices are keeping them at the same level.
