Originally posted by: Googer
Thanks!
I did buy a set of Klipsch Quintet III's and Matching Synergy Subwoofer for Half Price on Black Friday. I am considering a Denon AVR-3806 at
Costco but it's price makes me think twice. However Costco is selling it for $100 less than the less capable
AVR-2807's list price. A little more realistic is the
Onkyo TX-SR803
Things I like about Onkyo:
Clarity and fidelity.
High Frequency responce up to 100KHz for SACD
The Onkyo Reputation
Things I like about Denon:
Power, Power, and Power
Good Clairty
Good video capabilities (on certain models)
Denon Link DVD compatability. Denon DVD rocks and is a swinging factor in purchasing a DENON Reciever.
I am also scouring Craigslist for some lightly used equipment in hopes of striking a good deal. The one I am looking at appers to be older than what the seller lists in his ad. My reasearch show that the
AVR-2805 is a 2004 model and can be found as new old stock for $500. Would $250-300 be a reasonable offer for this?
Now go to bed and I will wait untill morning for any other answers. I'd hate to be the reason that you dont get any sleep!
Those are some good options, but those are pretty expensive for the speakers you got. You certainly got a good price on the speakers, but a ~$1000 receiver for $250 speakers that were originally $500 is a bit more than I would spend to try to get a good price/performance balance.
Something nice about receivers when you get into this range is you start getting not only HDMI inputs, but also conversion of analog sources to HDMI. If that's an important feature to you, then by all means go for it.
Also in this range a popular option would be one of the Pioneer Elite units.
If you haven't already, look around here and check out some of your options.
http://www.avsforum.com/avs-vb/forumdisplay.php?f=90
Just as a general guideline, I think you should be spending at least as much on speakers as your receiver, and in most cases, more. I don't know exactly why I'm telling you this now, other that to say that getting a $1000 receiver for these might be overkill.
At over 90dB sensitivity, "Power, Power, and Power" might not need to be a priority.
As for the remote issue, I agree that you shouldn't have any problem integrating a DVD player to be used with your receiver. Even if you do have an issue, that could be solved with a nice Logitech Harmony remote that I might recommend getting anyway just for ease of use.
I would have a very hard time spending more than a couple hundred dollars on a DVD player now with how well some more inexpensive players are performing (
Oppo 971 for example scoring 98% on the Secrets test ) and HD-DVD players coming down in price.
As for 100kHz on the Onkyo's output, that's not really going to make any difference unless your speakers are capable of getting up there too. The 3806 manual gives 100kHz as it's -3dB point as well.
Overall I think that 2805 on Craigslist might be a better idea for you
Looking off completed ebay auctions / audiogon / videogon though, $400-ish seems about right for that one?
