Discussion Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 7000, etc.)
Page 85 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Vattila
822
1,467
Except for the details about the improvements in the microarchitecture, we now know pretty well what to expect with Zen 3.
The leaked presentation by AMD Senior Manager Martin Hilgeman shows that EPYC 3 "Milan" will, as promised and expected, reuse the current platform (SP3), and the system architecture and packaging looks to be the same, with the same 9-die chiplet design and the same maximum core and thread-count (no SMT-4, contrary to rumour). The biggest change revealed so far is the enlargement of the compute complex from 4 cores to 8 cores, all sharing a larger L3 cache ("32+ MB", likely to double to 64 MB, I think).
Hilgeman's slides did also show that EPYC 4 "Genoa" is in the definition phase (or was at the time of the presentation in September, at least), and will come with a new platform (SP5), with new memory support (likely DDR5).
What else do you think we will see with Zen 4? PCI-Express 5 support? Increased core-count? 4-way SMT? New packaging (interposer, 2.5D, 3D)? Integrated memory on package (HBM)?
Vote in the poll and share your thoughts! :)
Reactions: richardllewis_01
Joe NYC
4,266
5,943
AMD based their whole range on the fact (among others) that the more higher in the range you go, the higher MT you get bit you don't lose ST (except 5950 if I'm not mistaken) or very little which means you do not regress in ST as a price to get better MT.
(Not taking APU into account obviously).
If you break this, you lose the incentive to go 12/16 cores CPU, which mean those with better margin which means less sales of high margin CPU. Why on earth would AMD do such a stupid move?
Just for PR of 'I'm still the best at games' ?
How shortsighted this would be.
2 * 5800x = 2 * 449 = $898
1 x 5950x = $799
2 of the 5950x CCDs have to perform in the same 105W envelope as 1 of 5800x CCDs.
AMD is wasting 2 best binning dies just to get decent ST performance in a CPU that is sub-optimal for ST.
Let me recap that: 2 best binning dies to just to get decent ST performance.
One of the best binning dies is sitting idle, slowing the other best binning die, but the one die that is doing work is so highly binned that it still does a decent job running ST task.
Joe NYC
4,266
5,943
Here is a nice example of 2 top bin CCDs slowing each other in 5950x and the lowest bin parts 5800x and 5600x zoom by 5950x.
This, in a ST dominated application. 5950x has 300 MHz and 200 MHz boost clock advantage over 5800x and 5600x.
That's some serious mis-allocation of resources on part of AMD,
Misallocation is that the dies that are capable of highest ST performance are sent to a MT optimized product, and dies capable of the lowest clock speed (lowest ST performance) are sent to ST optimized product.
DisEnchantment
1,779
6,798
I am not sure that is a problem with 5950X.
You can see 5600X beating a 5800X which makes no sense.
Could just be windows migrating threads all over the place or not optimal multihreaded programming
This review here of the scaling in Zen3 family shows 5950X on top in almost all cases
Why would people paying the most settle on a compromise? 5950X is the highest SKU in the 5000 series and AMD naturally reserve the best dies for this.
eek2121
3,491
5,190
That's actually what I was referring to as sub-optimal.
5950x is clearly a sub-optimal CPU for 9 out of 10 current games, 10 out of 10 of older games.
The reason it wins some is because AMD dedicated the highest binned parts to this CPU, and it has the highest boost clock.
5800x configuration with a single CCD is better suited for gaming, if it had the best binning parts and highest boost clock. Single CCD would have more of the power budget, and the performance is not slowed down by resolving memory coherency between 2 CCDs.
Maybe you missed the news that Intel is launching only the gaming oriented K SKUs this year, with DDR5, postponing all of the mainstream SKUs for next year.
Since when does “K” mean gaming oriented? All “K” means is that they are unlocked. Quite often, “K” CPUs are often binned better and have better clocks than “non-K” equivalents.
Also, I am going to call you out on calling the 5950X “sub-optimal” for gaming. Out of the 5 games I play regularly, only 1 uses less than 8 threads. The rest use > 8 threads. This isn’t 5 years ago, games are catching up with hardware.
Joe NYC
4,266
5,943
Probably just overhead of resolving potential conflicts between 2 CCDs. 5900x suffers equally.
But it just means that 2 CCD configurations of 5900x and 5950x are suboptimal for single threaded apps - vast majority of games.
The people buying 5950x are not paying the most. They get 2 of the best dies. And they get them at a discount compared to people buying 1 single inferior die in 5800x.
I hope Lisa Su has a serious talk with her "segmentation team" and slaps them around before the launch of Zen 3D
eek2121
3,491
5,190
Or maybe something is wrong with their setup. As usual AnandTech gives no information about their benchmarks, but running the standard "Gathering Storm" graphics benchmark on my 5950X gives me 193fps average, ~130 fps 95th percentile. Also, I took this screenshot of task manager after I quite the game. Notice that it uses ALL cores:
Also notice it uses 100% of the GPU, so clearly here it is GPU bound, not CPU bound.
EDIT: That is "Ultra Details" with full MSAA (8x) at a resolution of 5120x1440. I may try to run it in a CPU bound scenario later.
Reactions: Tlh97 and Joe NYC
eek2121
3,491
5,190
I found the issue with AnandTech's "review". Civilization 6 is still GPU bound at 1080p max. My benchmark figures:
Average: 223.26 fps
99th Percentile: 154.53fps
GPU usage was still 100%, CPU usage was 40%. AnandTech is GPU bound. Why did they get a better result on lower end CPUs? Probably less heat in the system so the GPU could run faster. Who knows. My CPU usage was around 30%.
EDIT: If you claim the 5950x is power limited, keep in mind it is easy for those of us with one to prove you wrong. It is trivial to disable a CCD.
Also I feel the need to note that mine runs at stock with PBO disabled and virtualization enabled.
EDIT: Because I'm feeling extra crunchy today and need to get to bed. With 1 CCD enabled (basically a 5800x with the faster clocks you mentioned):
Average: 184.03 fps
99th Percentile: 128.80fps
I then loaded up a very large save game I added and measured the FPS there, my results had slightly higher FPS for both configurations and slightly lower CPU usage. This save game I've been playing for months.
Same settings as with 2 CCDs.
EDIT: Almost forgot to add. Max CPU Package power was 142.667W, CPU Core Power was 105.974W. This is according to HWInfo64.
Joe NYC
4,266
5,943
When predominant customers base of "K" SKUs are gamers, I took a liberty to call it a gaming oriented CPU.
There is a difference between "uses" and is constrained by. I have one recent game that uses all cores, but is running them at a single digit utilization. There would likely be no difference in this game if my CPU had only 1-2 cores.
OTOH, I have 1 game I tested that is perfectly threaded, where all cores run at full utilization (when I fast forward the game), out of about 100 games I played over the years (called Sim Airport), with one more candidate that I have not tested. So maybe up to 2:98 ratio.
So I am not denying these games exist, but the games that would overwhelm 5800x, that they would need more cores, those are in a small minority.
eek2121
3,491
5,190
You ignored my posts calling you out for your inaccuracies. Want to address those? Please find me a single reproducible workload where my (or anyone else's) 5950x is crippled due to power limits (i.e. turns in worse scores/frame rate) vs. a 1 CCD 5950x, let alone a 5800x. I'll wait. I almost wanted to go down the rabbit hole of "make sure it is an actual workload that people use and it isn't malware", but I'll exclude that for now (though if you can't prove it is used or I suspect it contains malware, I'm not going to run it). Sure, it won't exhibit 100% scaling, but core-to-core/CCD to CCD latency can be a factor among a million other things.
For the record, the definition here is "Does not perform as well as the 5800X". The software must be usable on the latest version of Windows 10 without issue and/or Windows 11 (I'm on Windows 11). If it is a game, it must use DirectX 12 and/or Vulkan. (Very few games, if any, don't support either of those APIs), though if there is a recent game that only works on DX 11 and I own it, I'm willing to test it. (A single core game is not going to bottleneck a 5950x, if it runs slower on a 5950x it likely has other bottlenecks related to things outside the CPU. I am a developer and I'm willing to debate this.)
Joe NYC
4,266
5,943
The problem with Anandtech testing is that they test FPS on turn based game. <facepalm>
Civilization is still heavily Single Thread CPU constrained when processing turns, but this sort of test would need the reviewer play and understand the game to know what is important to test and how to set up a scenario.
Average: 223.26 fps
My hypothesis is that the 2 CCDs are just stepping on each other.
I don't think they are power limited. It would be interesting to see, under how many scenarios disabling 1 CCD improves performance.
Average: 184.03 fps
Nice! Thanks for running the test.
But you are getting different results than AnandTech is getting with actual 5800x, so perhaps there is still something different about a system with 1 CCD disabled just in BIOS vs. actual 5800x.
Looking at another set of reviews, of AnandTech Rocket Lake Review, where they have 5600x, 5800x and 5900x, and 5900x loses more than half the tests despite having 100 to 200 MHz advantage and extra 4 or 6 cores and 40 Watt advantage over 5600x. With equal clock speed and Wattage, 5900x would probably lose 9 out of 10.
Gaming Tests: Deus Ex Mankind Divided - Intel Rocket Lake (14nm) Review: Core i9-11900K, Core i7-11700K, and Core i5-11600K (anandtech.com)
AMD is just not sending us their best
(SKU configurations for gaming)
eek2121
3,491
5,190
Unless AnandTech's tests are reproducible, I have zero confidence in their tests. Some of their tests HAVE been reproducible, and my stock hardware or stock hardware I've been able to use has turned in different results from theirs.
Geekbench, for instance. In a closed case with a similar cooler, I get better results.
With JEDEC specced DDR4 3200 memory and stock settings on a 5950x I turn in 20%-30% better results on Geekbench, Cinebench, and a few others. This is with Stock BIOS settings and, in my case, with 2 different motherboards from 2 different vendors (ASROCK and Gigabyte) So do many other folks. I love AnandTech and I know Ian knows his stuff, but some of the benchmarks they've posted have shown to be flawed, and they almost NEVER follow up on the feedback. Once again...where is your proof? I can provide mine, but you are the one making extraordinary claims. Extraordinary claims need extraordinary evidence.
Joe NYC
4,266
5,943
No I never said that. That if 5950x loses, (in ST gaming tests) that it would be because of power limit. Because that's not what I believe is going on.
Quite the opposite, I think 5950x is most likely free to run at the max boost clock in games (when called for), which means that 5950x has 200-300 MHz advantage over 5800x or 5600x (which I did say).
My theory why 5900x and 5950x are losing so often in games has to do with having 2 CCDs, and some overhead associated with it.
That's the biggest difference, so I would call it #1 of the million other reasons far less likely.
What I am wondering (among other things) is how often Windows just switches the tasks that may have been somewhat idle to a completely different core, and perhaps a completely different CCD.
That could be another reason. Because if a task that is somewhat idle comes back to life on a different CCD, most of its data may be in L3 of the original CCD.
Joe NYC
4,266
5,943
I would not expect the same result, but I would expect that 5950x > 5900x > 5800x > 5600x, which is rarely the case in the 3 set of Anandtech reviews I looked since Zen 3 launch.
I was drawing my conclusions mainly from Anandech tests.
So just out of curiosity, I looked at Tom's review here, mostly consistent with clock speed scaling
Core i9-11900K and Core i5-11600K Gaming Benchmarks - Intel Core i9-11900K and Core i5-11600K Review: Rocket Lake Blasts Off | Tom's Hardware (tomshardware.com)
And Hardware Nexus video here, seems most consistent in Zen 3 performance scaling
Waste of Sand: Intel Core i7-11700K CPU Review & Benchmarks vs. AMD 5800X, 5900X, More - YouTube
PC Magazine is similar to Anandtech. 5800x mostly beats, sometimes trounces 5950x in gaming:
Intel Core i9-11900K Review | PCMag
This one, 5800x leads 5950x about half the time:
Intel 11th Gen 'Rocket Lake' Review - Games: Far Cry New Dawn - Tweakers
Timorous
1,989
3,918
Civ 6 is not the game to pick though. If you get 30fps then that is plenty. What matters is turn time and there the 5800X does fall behind the 5900X and 5950X.
Reactions: Joe NYC
moinmoin
5,248
8,463
This is an odd discussion since nobody can optimize for "gaming". Gaming is purely a PR target for consumer products. The (closed source) software environment is a mess of non-optimized parts, and gaming software performance is often defined by the most inane bottlenecks. Aside simply pushing up frequency that's always the easy solution to everything, the best approach to improving "gaming" is to improve performance for all possible workloads.
AMD claimed to have done just that between the first and current Epyc gen:
Why do I quote an Epyc slide? Because that's AMD focus:
  • All efforts first go into the server market. This defines the fundamental Zen design.
  • Second focus now is the mobile market. There improvements in power management are tested.
  • The desktop market gets scraps from the previous two. PR uses "gaming" to sell the overall performance improvements to consumers. (See also "game cache".)
I doubt AMD will change anything about this approach. Selling Zen 3D as a superior "gaming" platform to the consumer public tells me AMD is perfectly content with this modus operandi.
Thibsie
1,184
1,405
1 x 5950x = $799
AMD doesn't want to sell 2x 5800x, they want to sell 2x 5950x (or at least 5900x).
The pricing pretty much reflects that IMO.
Reactions: Joe NYC
Vattila
822
1,467
I think you are overly concerned about inter-CCX latency. For poorly written software, corner-cases and legacy applications where it has big effect, the user can mitigate it by disabling all but one CCX, or force the affinity of the process to use cores on a single CCX only (through the use of system tools).
Personally, I am a developer, and like others here who are developers or content creators, I like that the top SKU makes "no compromises". Currently, the only mainstream SKU that I somewhat covet is the 5950X, and I am very interested to see what the new Threadripper series can do. I like the idea of getting lots of cores without compromising single-thread performance. So I hope that focus continues at AMD.
There is also the idea of optimising for tomorrow, not yesterday. Like AMD CEO Lisa Su likes to say: "we need to always push the boundaries". By attracting gamers to SKUs with more cores, they are moving the technological progress along, making it possible for developers to depend on higher-performance hardware in future software. It is obvious that a game written to fully exploit a 16-core 5950X can achieve more than it can with an 8-core 5800X. Developers will just need to learn to deal with many cores, multiple CCXs and heterogeneous accelerators (GPU compute, FPGA, AI). That's where we want to be moving.
All that said, the N7 CCDs have been in production at TSMC for a very long time, and the yield and binning must be pretty good by now, so there may be room for increasing the boost frequency on the SKUs that lie further down the product stack as well. So I expect a "Zen 3" refresh with V-Cache and slightly better frequencies across the product range.
PS. I don't think you need to worry that AMD is not aware of the competition (e.g. "Alder Lake"). Like you, I think they care a lot about leading in the gaming space. Gaming is part of high performance compute — AMD's core business — and a lot of their customers, products and revenue is in the gaming industry. But, of course, they will do what makes most business sense within their capabilities and schedule. We can only hope it will be good!
Joe NYC
4,266
5,943
Yes, when sifting through results, I found some web sites that in fact test the turn times (Hardware Nexus) and 5950x had the highest score. The margin was in proportion to boost clock, not core count.
Hard to send a link because it was somewhere in the middle of a video review.
The way to interpret it is that if the game is running faster on 5950x (not slower as it seems to happen randomly and quite frequently) and if the margin is proportional to the clock difference (not core count), then the second CCD is wasted for that game.
Reactions: Tlh97 and Vattila
Joe NYC
4,266
5,943
Are you sure about that? AMD usually uses one good die and one bad die with their 2xCCD CPUs since the second CCD rarely ever sees max boost clocks.
Interesting idea.
Slight problem is that if you have 2 cores highly utilized, you would want them to be on different CCDs, to fully take advantage of L3s and thermals.
And the 16 cores still need to adhere to minimum all core frequency within the power limit...
Joe NYC
4,266
5,943
I am not talking about optimizing the cores to gaming. The core is what it is, and luckily for gamers, the profile of what makes the "Enterprise" apps perform well is not too different from gaming.
What I AM talking about is optimizing SKUs using 2 variables:
- binning
- core count (CCD count).
It is a very easy equation to solve: you get the best cost effective high gaming performance with high binning part with single CCD.
In other words, SKU that AMD did not release.
In not too distant future, 3rd variable - 3D stacked L3 will enter the equation.
Joe NYC
4,266
5,943
Well, AMD is able to sell a lot of the 5800x despite the fact that it is arguably the worst deal for the customers (and the best deal for AMD) of the 5000x line of processors.
8:1 in proportion to 5950x
TechEpiphany on Twitter: "🔥 CPU Sales Week 30 (mindfactory) 🔥 AMD: 2575 units sold, 76.98%, ASP: 320.84 Intel: 770, 23.02%, ASP: 233.89 AMD Revenue: 826'175, 82.1% Intel Revenue: 180'092, 17.9% Please share 🙏This is a product of weeks of work #AMD #Intel #AMDRyzen https://t.co/3C0LbV2GTK" / Twitter
Thibsie
1,184
1,405
Of course they are. you don't even try to answer my point.
Joe NYC
4,266
5,943
Maybe I am.
Alternative: strange gaming results, where higher clocked 5950x comes behind 5800x and 5600x are the result of poor testing methodology. That seems to be very wide spread.
Personally, I am a developer, and like others here who are developers or content creators, I like that the top SKUs makes "no compromises". Currently, the only mainstream SKU that I somewhat covet is the 5950X, and I am very interested to see what the new Threadripper series can do. I like the idea of getting lots of cores without compromising single-thread performance. So I hope that focus continues at AMD.
My problem is not that AMD is selling 5950x with 4.9 GHz boost clock.
My problem is that AMD is NOT selling a version of 5800x, say 5810x with 4.9 GHz or higher boost clock.
In addition to current 5800x CPU with 4.7 GHz boost clock.
The volumes of 5000x processors were quite low November 2020 - April 2021, but now they are widely available at MRSP. But since Zen 3D is right around the corner, it's probably too late to introduce another 5800x variant...
All that said, the N7 CCDs have been in production at TSMC for a very long time, and the yield and binning must be pretty good by now, so there may be room for pushing the frequency on the SKUs that lie further down the product stack as well. So I expect a "Zen 3" refresh with V-Cache and slightly better frequencies across the product range.
I hope so too. And hopefully we will also see N6 version of Zen 3, which may lift the floor of the majority of CCDs, lifting the clock speeds at least marginally.
AMD will have quite a component set to craft SKUs. I am hoping they will have one SKU that beats Alder Lake in every test.
Say 6950x is first, Alder Lake 2nd in test A.
And there is a test B where Alder Lake beats 6950x but a theoretical maxed out single CCD 6850x would beat it.
All I want for AMD to have that SKU.
There is no law that says AMD can have only 4 SKUs in a certain class of chips.
