Discussion Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 7000, etc.)
Page 487 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Vattila
822
1,467
Except for the details about the improvements in the microarchitecture, we now know pretty well what to expect with Zen 3.
The leaked presentation by AMD Senior Manager Martin Hilgeman shows that EPYC 3 "Milan" will, as promised and expected, reuse the current platform (SP3), and the system architecture and packaging looks to be the same, with the same 9-die chiplet design and the same maximum core and thread-count (no SMT-4, contrary to rumour). The biggest change revealed so far is the enlargement of the compute complex from 4 cores to 8 cores, all sharing a larger L3 cache ("32+ MB", likely to double to 64 MB, I think).
Hilgeman's slides did also show that EPYC 4 "Genoa" is in the definition phase (or was at the time of the presentation in September, at least), and will come with a new platform (SP5), with new memory support (likely DDR5).
What else do you think we will see with Zen 4? PCI-Express 5 support? Increased core-count? 4-way SMT? New packaging (interposer, 2.5D, 3D)? Integrated memory on package (HBM)?
Vote in the poll and share your thoughts! :)
Reactions: richardllewis_01
Hail The Brain Slug
3,890
3,331
You can't just double all the numbers, it does not work like that. Your posts are approaching trolling.
That has been the approach to calculating absolute DRAM latency for a while. However, I will note that platform, DRAM technology, memory controller, etc. all have an effect on this. My Zen 3 at 3800C14 has higher measured latency than my Zen 4 at 6200C28, despite the latency calculation giving my zen 4 a disadvantage.
Hans Gruber
2,548
1,375
You are one of those people
With all the insults you throw around on this forum. I cannot understand why they allow you to be a moderator.
You still cannot call out moderators by their titles.
esquared
Anandtech Forum Director
Reactions: SMU_Pony
itsmydamnation
3,147
4,041
Clock for clock. Cas 14 latency DDR4 @ 3800mhz would be equal to Cas 28 DDR5 7600mhz if you double the speed. Obviously DDR5 has some raw performance gains in architecture. Even if you have E die 16Cas @ 3800DDR4 would be Cas 32 DDR5 7600mhz.
I am equaling out the performance to give you an idea of the latencies of top tier DDR4 vs. DDR5.
My point is that AMD needs much higher frequency support for DDR5.
no they don't , which is why it makes no sense
what matter is timing in NS , not Cas in isolation , not clock in isolation , CAS * Clock = timing
If you can make DDR5 8000 at CAS 40 for example , you can likely get DDR4 4000 CAS 20 from the exact same kit.
so if 6400 is the best data rate for AM5 and you can get 8000 for intel , vendors just need to sell AMD targeted Kits @ 6400 with CAS that reaches the first word latency in NS as the 8000 intel kit.
people love to over value memory bandwidth , vast majority of consumer workloads will favour latency
Reactions: lightmanek
Hans Gruber
2,548
1,375
That would be the architectural enhancements in DDR5 th
And the numbers speak volumes. DDR4 3600mhz even at Cas 18 smokes DDR4 3200mhz 14-14-14 in performance.
I mentioned in my earlier post that DDR5 has enhancements that improve performance over DDR4. The doubling of Cas latency and frequency is merely a ball park figure.
Consider that Zen 1 maxed out at 3000-3200mhz. I could get 3400mhz but I had a B-die kit and a good bios. 3200mhz was all that was stable. It was not until the big AGESA bios update that allowed Zen2 to achieve 3800mhz memory frequency.
You can search forum history. People said it wasn't a bios issue it was a motherboard hardware issue because some motherboards could do 3800mhz and other could not. It was a bios issue.
You can run Zen 2 and Zen 3 way beyond 4000mhz but you lose your 1:1 memory divider and introduce a ton of latency.
Zen 4 cannot even achieve the DDR5 6400mhz that AMD claimed was the sweet spot for Zen 4 CPU's. I remember when 3733mhz was the coffins corner for Zen 2. It would boot and run but would have memory issues and phantom crashes before the big AGESA bios. AMD said that AM4 would be supported all the way through Zen 3. Then it wasn't for B350/X370 motherboards. AMD released a bios update and now you can run Zen 3 on the oldest AM4 motherboards.
From what I understand with Zen 4. Regardless of memory dividers and timings. You cannot run any DDR5 rated or not stick of memory above 6400mhz without the system crashing or not booting.
scannall
1,960
1,678
Actually you pretty much can. CAS Latency explained. CAS latency is RAM clock cycles, not a measurement of time. So if your DDR5 is taking 28 cycles but running twice as fast a clock speed then they would be *roughly* equal to DDR4 at 14 cycles. DDR5 has some big architectural improvements in regards to banks etc which allows more throughput at a given latency and speed. DDR5 spec
Kocicak
1,177
1,232
I think AMD needs to speed up their CPU release cadence.
WHAT? These are not trainers! These are extremely complex and expensive things to develop, and also to manufacture and buy! Users (at least the corporate users of servers) need to run them for years.
There is no reason at all to come with a new CPU each half a year!
Det0x
1,490
5,121
7950x3d GB5
As we can see, the 7950X3D scored 2271 points in the single-core test and 24727 points in multi-core. That’s indeed much better than previous scores. It is worth noting that the 7950X3D will not support overclocking, at least not in a traditional form. There will be no frequency or multiplier modifications allowed, but users will have access to memory overclocking, and Precision Boost Overdrive and undervolting. That said, the new highest score was definitely not achieved with overclocking.
Timmah!
1,572
935
7950x3d GB5
well, only one core showing 5,7ghz is bit weak to support the claim the cpu can boost up to 5,7. I mean, did not the same list of vanilla 7950x frequencies shown all the cores being able to do 5,7?
Anywy, its still just 200~300 MHz less - i wonder if one will be able to PBO/CO tune it to boost to the same speeds as vanilla one…
Monday cant come fast enough and some proper review showing the clocks, all around performance and its tuneability.
deasd
610
1,045
deasd
610
1,045
Can't wait to see folks buy a $699 CPU, only to turn off the CCD without the V-cache :D
Since dual CCDs don't have any shared cache, like P and E cores, shutting down one CCD won't make any diference, except you can OC the V-cache CCD higher due to TDP and heat dissipating.
And you can even shutting down everything you can like SMT and some unused cores....
Kocicak
1,177
1,232
Timmah!
1,572
935
7950X3D, MT 24727
7950X, MT 24095
While having similar MT score, 7950X3D has exactly 200-300 MHZ lower frequency than the 7950X.
Thats in Geekbench. How about Cinebench or even better Vray.
stuff_me_good
206
35
If true we seem to get diminishing returns out of bigger cache. I guess the internal cache is big enough for price performance sweet spot?
Det0x
1,490
5,121
utahraptor
1,078
282
It looks like a pretty good showing for the 7950X3D. The slight defecit in the 2nd half of the synthetics is very minor.
The only whataboutisms I can envision are:
  • Price difference
  • Core i9-13900KS not tested
  • Core i9-13900K was not allocated DDR5 8,000
  • Mobo cost
I'm glad I waited for the 7950X3D.
LightningZ71
2,717
3,423
When the 5800x3d came out, it was compared against cache limited 11th gen Intel products and Alder Lake products with less cache than the current Raptor lake products. Current Raptor lake has 36MB of L3 and a lot of L2 coupled with a notably faster memory subsystem than previous processors. I wouldn't expect the large vCache to make a huge difference across the board any more, and only those few games that have moderate working sets that fall in the 50-100MB of size will strongly favor AMD. Anything larger will swing back to Intel.
leoneazzurro
1,114
1,867
  • Price difference
  • Mobo cost
Yeah, considering that the worst showing in these slides is not even a game and that the X3D version is limited to 120W TDP, it seems not bad at all. Provided we can trust these numbers, which must be confirmed by third parties. A pity that there are no rumors about a mobile version of these processors...
