Discussion Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 7000, etc.)
Page 294 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Vattila
Except for the details about the improvements in the microarchitecture, we now know pretty well what to expect with Zen 3.
The leaked presentation by AMD Senior Manager Martin Hilgeman shows that EPYC 3 "Milan" will, as promised and expected, reuse the current platform (SP3), and the system architecture and packaging looks to be the same, with the same 9-die chiplet design and the same maximum core and thread-count (no SMT-4, contrary to rumour). The biggest change revealed so far is the enlargement of the compute complex from 4 cores to 8 cores, all sharing a larger L3 cache ("32+ MB", likely to double to 64 MB, I think).
Hilgeman's slides did also show that EPYC 4 "Genoa" is in the definition phase (or was at the time of the presentation in September, at least), and will come with a new platform (SP5), with new memory support (likely DDR5).
What else do you think we will see with Zen 4? PCI-Express 5 support? Increased core-count? 4-way SMT? New packaging (interposer, 2.5D, 3D)? Integrated memory on package (HBM)?
Vote in the poll and share your thoughts! 🙂
Whenever shipments of Epyc chips reach a level where supply pass demand I can imagine AMD reintroducing non-Pro Threadripper.
That was my suspicion, though there's basically three (actually four?) tiers of demand here:
Level 1: Hyperscalars. ODM sales
Level 2: General market EPYC. Retail.
Level 3: Threadripper Pro
Level 4: Threadripper
AMD will have to exhaust the first three market tiers before they can realistically consider Threadripper again.
MadRat is right. Apple has a serious advantage in the video editing space.
Sure, when fixed-function hardware is in play. Handbrake tells a different story.
The implication there is that AMD only implemented a single AVX-512 Vector unit in Zen4 instead of the dual units in Cascade Lake and Ice Lake Xeon.
Are we still talking about Cinebench ST scores? Cuz Cinebench R23 barely uses anything over AVX2.
Handbrake is poorly optimised for ARM and highly favours x86 instructions. Also the Air M2 is fanless leading it to throttle. Can AMD perform the same with fanless zen in a laptop?
I'd split the levels as follows:
  • High margin: Epyc, Threadripper Pro -> all served during supply constraint
  • Not high enough margin: Threadripper -> not considered until there's some oversupply
Another layer to consider is quantity ordered:
  • High amount in few orders: Cloud -> served first as those ensure a minimum amount of trade right out of the gate even if volume discount reduces margin somewhat
  • Medium amount in more orders: Enterprise and ODM -> served second, slower to expand into but also longer lasting customer base due to slow general turnaround
  • Low amount in too many orders: Retail -> too little quantity, too much price competition, but great for building initial mindshare
Genoa 866
vs
Bergamo 897
To reduce space(To put 16 pieces of 8 Core CCDs AMD Halved the L3 and removed AVX512, but left AVX256 )
If real, I would have expected Bergamo to be a bit lower clocked, but it is *only* a 64-core processor. If it can clock really high, then perhaps we will see Bergamo chiplets elsewhere. I was thinking that they would have little to no boost clock, which would make them not as attractive for a lot of uses compared to regular Zen 4.
Perhaps they are using a denser/Shorter AVX512 like they did with PS5 Zen2(compact AVX256), that saved them a 56% die area space.
This is what I believe Bergamo is going to look compared to Genoa.
Bergamo Full ISA compatible(AVX512 with less throughput), 1MiB L2 and 16MiB per CCD. Bergamo lacks the TSV Rails.
I haven’t seen this before; been out of the loop for a bit. Where are the photos from? Is Bergamo supposed to be 2 CCX per die with 8 cores per CCX?
edit: Bergamo would need to be two of these per die, right? So a 16-core Bergamo die would actually be quite large if that is just half of the die.
I can believe halving the L3 for Bergamo. Maths on that just works really. Die size is around 75-80 and with Zen 3 32MB of L3 took up about half of that area. With N5 offering better logic scaling than cache scaling it stands to reason 32MB of L3 will be around 2/3s of the die area give or take leaving 1/3 for cores. Well if you half that L3 you end up with 1/3 cores and 1/3 cache allowing you to add another 8 core cluster for a 16c CCD and use a very similar amount of die area.
CPUZ AVX512
Oh okay. Hmm isn't the CPU-Z benchmark mostly integer though?
Apple and it's many fans/developers have had plenty of time to address that issue.
Okay whose fault is that?
I dunno, is anyone dumb enough to sell a >15W PPT Rembrandt in a fanless unit?
Yes and no one did. lol
It's not a fault per say. It's just how it is.
Well, AMD should make a 9-15W APU. Intel is going to make a 5-10w meteor lake CPU next year. Fanless is good for certain needs like no dust getting into the laptop.
While IIRC it was stated by an AMD rep that bergamo was cloud specific (no desktop), it would not surprise me at all if AMD pushes out a desktop version down the road. Note that 3D V-Cache would negate the hit by halving L3. AMD could do a 32c/64t Ryzen chip pretty easily with just two chiplets.
Not sure if Bergamo will ever see an -X variant, nor is it likely that we'll see some weird mobile or desktop chip based on a hypothetical Bergamo-X.
Seems like the hard launch is indeed pushed 2 weeks back to late Sept due to BIOS-related issues.
Unknown source. Final silicon is ready for sure.
Your post got picked up by VIdeocards 😀. They are lurking these forums after all.
Hope he tells us how does it feel to be famous now 🙂
