Speculation: Ryzen 4000 series/Zen 3
Page 114 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
coercitiv
7,450
17,764
For Zen4, it looks like rollouts will then start in late 2021/early 2022, and continue into late 2022.
Actually, based on slide interpretation from the chipset thread, this slide "clearly" shows Zen 4 is to be delivered before January 1st 2022, meaning it is a 2021 product. :p
On a more serious note, there is no way of relialy reading a Zen 4 launch year from that slide, which kinda makes previous complaints about lack of accuracy in H1/H2 or late/later statements seem small potatoes.
Topweasel
5,437
1,659
Sorry I'm being a bit pissy, but I miss the days of actual roadmaps that at least showed which quarter a product was coming out in; and I'm getting tired of there being less and less actually useful information given.
I'm sure all the big shareholders at the special private wallstreet teleconferences are being given more precise info, but this is all us plebes get.
I think opposite, what we have gotten in the past when they were sloppier with the links was the engineering roll-out. The thing you give your development partners to lay out your long term plans so they can be prepared for the new product lines.
This type has always been the standard "business" road-map. Sometimes if they were talking about a single years release you might see some gradient on period of the year release. But nothing ever more than a year out.
Valantar
1,792
508
I always get a kick out of it when a company uses H1/H2 instead of Q2/Q4. We know what you're up to.
Yeah, that's always fun. "H1/H2" just means "Q2/Q4 but we don't really want to admit that."
All technical data of AMD’s new “Renoir” desktop APU portfolio for AM4 at a glance | Exclusive Leak
very impressive!!
the 35W Version with 8C/16T looks awesome >> up to 4,35GHz CPU boost clk and 2.0GHz max GFX clk!
I would really like a 4c with more than 6 CUs for my HTPC, but overall, these look really good. Those iGPU frequencies are amazing, and definitely bode well for iGPU overclocks on the lower spec parts.
Olikan
2,023
275
This IGP should overclock to 2.2~2.4Ghz.... This is... illegal.... Rdna2 might reach close to 3.0ghz?
I wonder if even mem. latencys might bottleneck the IGP at this speed
Reactions: lightmanek
DrMrLordX
23,160
13,254
Mem latency probably not, but bandwidth? Possibly.
Valantar
1,792
508
Definitely, not possibly. Even with DDR4 >=3600 even a basic GDDR5 setup will be faster. There's a reason why dGPUs with lower CU counts typically outperform iGPUs with slower memory (yes, power is part of that reason, but memory bandwidth is arguably more important). That's why AMD's next platform with DDR5 will be really exciting for APUs (and hopefully before that laptops with LPDDR5).
DrMrLordX
23,160
13,254
Clocks are up, but CU count is down. Yeah I am familiar with how hungry APUs can be for memory bandwidth. It's less pronounced on lower CU counts.
Valantar
1,792
508
... because fewer CUs at the same speed need less bandwidth to stay saturated with data to work on. As clocks increase, so do bandwidth requirements. There are some savings to be had by going this route, but they are minor, and certainly not enough to mean APUs are no longer limited by memory bandwidth.
Shivansps
3,918
1,570
very impressive!!
Vega 8 at 2.1Ghz stock? oof. Thats probably means you can get to 2.4-2.5 with oc..
What black magic is this? as far i know the only changes they did were to reduce the CU count a little and cut ROPs by half, this along with the die shink results in massive freq gains... impressive.
maddie
5,198
5,600
In a past post, I remember it being said that there were a few internal changes to allow for better clocking. I remember you denying it. This was when you were screaming about the reduction in CUs.
Possibly this is what was always expected of Vega in the clocks department. A few critical pathways sabotaging the whole.
Shivansps
3,918
1,570
They were never clear about what they did, it was all open to interpretation. They did a single slide about Vega in Renoir comparing it to Vega in Picasso mobile with that "54% faster", but Picasso mobile has lower clocks and limited to DDR4-2400.
There is nothing else to say about CU count, i never expected these to be slower than Picasso, that would be too much. Seeing the results in mobile and the very high freqs it can get to ill say now that is justified.
Reactions: scannall and Olikan
maddie
5,198
5,600
Do you expect a detailed circuitry analysis? Here is a excerpt from an article by Tom's. This is not a straight port to 7nm.
'AMD chose to stick with the Vega graphics engine found in its previous-gen Picasso APUs because its hasn't optimized Navi for mobile yet, but the company chose to make several architectural enhancements when it ported Vega from the 12nm to the 7nm node. That includes reducing the number of compute units (CU) from 10 to eight, but a range of improvements led to an overall performance increase of 59% per CU (based on TimeSpy test results).'
Reactions: Tlh97
maddie
5,198
5,600
The guy in question is possibly the premier guy in leaking details... about Samsung's phones?
Uh... odd source, I know, but a guy like this has credibility and a track record, and guys like that don't really 'leak' stuff they aren't sure of.
Definitely worth trusting if you ask me.
'The rumored improvement of Zen3 theory is about 15-17%. According to engineers, the actual performance of the sample may exceed this.'
If he's not a PC guy then maybe he didn't realize that the FPU throughput was rumored to be massively increased. I really don't see much different here than what was expected. We generally always expected a much higher performance increase in selective workloads.
.vodka
1,203
1,538
Yeah, that's the Samsung leaks guy.
Nice info if that's average IPC increase over Zen2. That, and the higher FPU performance overall could actually support Forrest Norrod claiming performance in line of what you'd expect out of a new architecture I guess.
uzzi38
2,747
6,657
I'll just say IceUniverse has done nothing more than made the info that >17% is happening public, and that it's not in regards to the FP performance rumour. It's overall.
  • Love
Reactions: spursindonesia
Glo.
5,930
4,991
Rumors from months ago touted that overall PERFORMANCE(Clock+IPC) improvement over Zen 2 will be around 20%.
However I am slightly disgusted that this type of "leak" comes out today, to start talking about AMD, instead of ... their competition.
Shivansps
3,918
1,570
As i said, that could mean a lot of things, for example they did not say anything about reducing ROP number, and they did. I dont need a deep analysis, but that 59% could easily be the result of freq increase and the use of DDR4-3200.
Maybe cutting rops by half and reducing CU number along with the die shrink helped to archive those high freqs. But thats my guess, and nothing they said leads me to belive the Renoir CU performs better per clock than Picasso CUs. And thats was my point when we were discussing Renoir IGP a few months ago.
Wharever they did allows for very high freqs, thats is what makes up for the CU loss.
maddie
5,198
5,600
I'm talking circuitry layout low level changes. What I'm saying is that they said architectural enhancements. This is not rearranging the number of CU, rops, etc.
You of course can believe whatever you want, but expect to continue being surprised when reality is different from your reasoning.
TESKATLIPOKA
2,696
3,260
VEGA IGP can clock pretty high, much higher than Vega GPU could even on 7nm. The question is how high can RDNA2 go, turbo in PS5 is 2.23Ghz. If the next gen APU will have 12CU and high clocks, then It would mean a serious increase in performance!
