So who has the most sophisticated home network?
Asthmaboy
444
iMac G5 and custom built PC - Mine
15" Powerbook G4 - Older Brother's
iMac G5 ver2 - Little Brother's
iMac G3 333mHz, I think - First Mac given to me and older brother.
G5 Tower, G4 Tower x3 - My Dad's
PowerPC - Mom's
We stilll have a couple iMac G3s and PowerPCs sitting in the garage.
:D
Oct 16, 2002
142
Originally posted by: dquan97
Originally posted by: homestarmy
Rather simple setup here.
All connected with a WRT54G.
Main PC for everyday stuff, on all the time running bittorrent - 370GB Storage
HTPC connected to projector, G Wireless, sleeps most of the time, wakes to record HD programming - 250GB Storage
HDPC connected to HDTV, G Wireless, sleeps most of the time, wakes to record HD programming - 320 GB Storage
Packet 8 DTA Device for VoIP
[need to connect to network, lazy] PS2 sharing internet access through HTPC, with 200GB HDD for games
Averatec Laptop for stuff that you do on a laptop
Dell Axim X50v, on wireless for bedtime browsing and remotely controlling PCs etc
But my network is power efficient, 4 of the 5 PCs are only on on demand.
how did you get them to auto-power on demand?
that's sort of one of the big features of MCE2005.
TC10284
308
Oh oh.....Tav likes this thread!
I think 32 PCs in all. (hehe) Most are custom built and networked by myself. 16 of which are connected to four, 4 port Zonet KVM switches. The rest are just using regular monitor, keyboards, and mice.
Starting with my router, a Pentium 133MHz system running IPCop with around 160MB of RAM I believe. From there, it connects to a Linksys BEFSR41 router that is set to act as a switch, it also connects to my Toshiba laptop. From the BEFSR41 it goes to a 24 port Netgear 10/100mbps switch. That switch connects my web/FTP server (Celeron 2.93GHz), a domain controller/DNS and NTP server (Athlon XP 1900+), my sisters Averatec laptop in her room, my Averatec laptop, and connects to an 8 port 10/100/1000 Netgear switch. The 8 port Netgear connects my main PC (2.8GHz P4), my file server (Dual P3 1GHz), a Sempron 2600+ system and to another 4 port Netgear 10/100/1000 switch (that is at another desk). There is only one system on the four port Netgear running at 1000mbps, an Athlon XP 2400+ system.
OK, now go back to the BEFSR41. It also connects to a 24 port Asante 10/100mbps switch that is mounted on a moveable 19" rack system (more will be mentioned about the rack shortly). From the Asante is a Duron 1.3GHz system (file share system), A P3 750MHz (running BOINC projects such as Rosetta, Einstein, Seti, Protein Predictor, and LHC), an Athlon 800MHz Socket A (also running CPDN on BOINC), an Athlon XP 2000+ system, Athlon XP 1600+ system, P4 2.4GHz system, and an Athlon XP 2100+ system. Two IBM 380XD laptops; one is running 3Com Syslog so it can get syslog messages from IPCop and other systems that use Syslog messages (when they run) and the other 380XD is running SETI using BOINC. They are both connected via the Asante.
On another table is a Netgear router with 802.11b Wifi and a 4 port 10/100 switch that is set as just an access point and switch that connects to the Asante. From there is an older 5 port 10/100 Linksys switch. On this table is a dual PII 300MHz system that is a replicating domain controller/DNS and NTP server, a PII 300MHz system that captures broadcast packets or any packet that comes to this system with Ethereal (just for a simple network monitor), an Athlon 700MHz Slot A system (running Stazki (spelling?), Seti, LHC, Einstein, Rosetta, and Protein Predictor), and a PII 400MHz system. On the adjacent table is my other Linksys BEFSR81 router that is set as a switch. It connects via the Asante switch. Also uplinked to the BEFSR81 is a Linksys WRT54G router with 802.11b/g and a 4 port 10/100 switch that is set as an access point and switch. Connected to the BEFSR81 are some of my older machines that did run other distributed computing clients (except the power bill was a little expensive so I shut those down hehe). Such clients as Distributed.net, F@H, World Community Grid, and FightAIDS@Home. Those systems are: A P233, P133, another P233, K6-2 500MHz, HP Pavilion Pentium 200MHz, and an HP Pavilion K6-2 300MHz.
That's not completely it but that's it for my systems.
My workbench is connected to the Linksys WRT54G. My other workbench connects to the Asante.
There's also a DLINK 802.11a/b/g access point on the Asante, a Gateway P3 600MHz upstairs that my mother uses via wireless, and my dad's PII 350MHz in the garage also via wireless. In my room is a P4 1.8GHz system that I use as my TV/Stereo (connected through the Netgear 24 port). Most are running Windows (from 98SE, 2000, to XP). A few are running Linux, unfortunately not any of are servers (running daemons). I am trying to learn more about Linux (namely Fedora Core since Redhat is based here in NC, and Ubuntu) so I can depend less on Windows (yes I realize the Linux kernel/OS is VERY powerful, very stable, and much more secure. It's just I have little time to work with it with other things to do). :eek:
I also recently acquired an "HP 9000 T600 Corporate Business Server" that has like 6GB of RAM across 24 or so modules, and 8 180MHz PA-RISC CPU's. Haven't tried it out yet though because it uses a 250v 30A power connection.
As for the rack mount:
From the top down - a Siemons 48 port patch panel that is currently not being used, the Asante 24 port 10/100 switch, a Cisco Catalyst 1900 24 port 10mbps switch, A Cisco 12 port 10/100 hub, two Cisco 2514 and two 2501 routers with transcievers and serial cables (being used for CCNA courses), Three old Baynetworks BayStack "Access Nodes" that I hope to get serial cables for and attempt to get them communicating with the Cisco's.
IPCop gives out the IPs of my two local LAN DNS server's and the third DNS server IP is my ISP DNS server. All of the Win 2000/XP systems are connected to my local domain and updates the clients' time via the NTP servers. The two local NTP servers update the time using pool.ntp.org. IPCop automatically updates the IP to my dynamic DNS service (no-ip.org). IPCop is also running a caching proxy add-on called Adv Proxy (the builtin proxy was OK, but Adv has a lot more features/settings)
There are a few other systems just sitting that have two NICs in each system running router OS's such as Coyote 3.0, BrazilFW, another IPCop, and FloppyFW (would like to try m0n0wall and FreeSCO as well as soon as I find two more applicable systems)
Hmmm....I think that is about it other than my network capable Lexmark Z65N printers. I have three. That's a long story involving RMA replacements and how I came about with three of them. I'd rather have a network capable laser printer but they are pretty expensive. Most of this stuff I've bought, collected, or acquired over the years. That or sold and replaced.
I've been into computers since I got my first HP Pavilion 7125 back in 1996. I realize that's not long ago for some of you "older" guys (not really older ;-) hehe), but it is a long time for me being 21 hehe.
I am not gloating but I thought I would share my setup with you guys. :D
Goosemaster
48,775
man TC10284...you're like a friend I have...who can't decide on a purpose and goes all out tryign to find one:p
that is a lot of gear...but try to sell it and learn how to consolidate all that. Most everything that you are doing can be done with one box as the server :)
ivwshane
33,518
17,023
I was running AD but have since taken it down. My setup now looks like this:
dsl modem
clarkconnect box running dhcp, gallery, print server, email server
8 port switch
windows storage box running another webserver, ftp and servering as a file server, administered via remote desktop.
main pc
secondary pc
laptop
xbox
Soon I hope to have a dvd server and a media pc added to the mix.
Atheus
7,313
Originally posted by: Mo0o
I have 2 computers connected to a router that gets internet access. I guess my penis isn't as big as yours
So what you're saying is - we shouldn't talk about our computer hardware because it's just bragging and male egos... may i ask why you have 13 THOUSAND posts on a computer hardware forum then?
And no, I suspect your penis is not as big as mine.
TC10284
308
lol :D
TC10284
308
:D
:Q Sell it?! No way! Yea, I could consolidate a lot of it but I'd rather just keep it all and keep collecting. It's one reason why I've gained so much knowledge, the ability to mess with things from the quantity that I have. Not saying that someone couldn't learn the same things I know with a lot less than what I have, it's just a huge help to me and that's how I like to learn. hehe
EatSpam
6,423
My "home" network consists of 3 sites:
Site 1, my condo:
my computer - crusty Athlon 3000+ XP, WinXP
wife's computer - Pentium M 1.7ghz, WinXP
basement htpc - Pentium M 1.7ghz, WinXP
bedroom htpc - mobile Athlon XP 1.8ghz, Win2k
firewall,vpn - EPIA PD6000, OpenBSD 3.7
exchange,dc server - EPIA VT-310DP, Win2k3, Exchange 2003
WSUS,dc server - EPIA SP13000, Win2k3
storage server - Celeron 2400, 3.2tb storage, Fedora Core 4
future:
VM server - Opteron 165, Win2k3 64-bit, Virtual Server (got it free)
Site 2, parents' house:
parents' computer - P4@2.53ghz, WinXP
little brother's computer - Athlon XP 2800+, WinXP
firewall,vpn - EPIA M9000, OpenBSD 3.7
Site 3, father's office:
5 workstations, Athlon XP systems of various speeds, WinXP
main server, P4@3.0ghz, Win2k
citrix server, P4@3.0ghz, Win2k3
firewall, VPN - EPIA PD6000, OpenBSD 3.7
mjia
94
Have you calculated the amount of power used by the machines that you have running @home type apps? Sounds like they are mostly slow, electrically inefficient machines, it might make more sense to donate the money saved on your energy bills to the respective companies (not to mention the environmental impact of inefficient energy usage). You can also donate the old machines to schools.
It seems that you are interested in contributing to society, but you might want to reconsider how best to do so. @home type programs are designed to take advantage of unused cpu cycles that would be wasting energy/time. To have machines that only do this might not be the economically effective (for society overall).
Genx87
41,091
513
Pretty simple
Internet -->Cable Modem --> Cisco 8.xx router -->Dell 16 port Gbit managed switch -->House
In the house I have
1 Athlon XP 2400 1.5 GB of Ram, 200GB Raid 1 storage, 80GB Raid 1 boot.
Soon to be upgraded to >2TB with raid controller.
Role - AD controller, WSUS server, IIS,file storage, A\V central, and VPN. I dont run exchange on it yet
1 A64 3000+ @ 2.2Ghz, 1.5GB ram, 74GB raptor, 6800GT, 160GB storage
Role - Games, workstation, backup.
1 Dell Inspiron 7200? P6 1.6Ghz, 512MB Ram, 40 GB HD. Wifes computer
Role - Let her play on the internet
1 A64 3000+, 6600GT, 1GB ram, 160GB HD
Role - HTPC
1 Athlon 800Mhz, 1GB ram, 60GB HD
Role - Sit there and record shows from cable to disk to be stored on the file server. This machine like the AD controller is controlled completely through VNC and sits in a closet with the rest of the networking equipment.
I have two other computers that just sit around picking their arse and will continue to do so.
Atheus
7,313
[Insane array of powerful rigs including this - "HP 9000 T600 Corporate Business Server" that has like 6GB of RAM across 24 or so modules, and 8 180MHz PA-RISC CPU's. Haven't tried it out yet though because it uses a 250v 30A power connection.]
Even though he's not running it, I just worked out the power for that server - 250*30=7500W or 7.5 Kilowatts! I bet there are whole houses with less consuption than that. I bet there are vehicals with less consumption.
I wouldn't worry about environmental or social impacts though, this would count as his hobby as well as a contribution to society. If he was woodworking or welding as a hobby you wouln't begrudge him a few kilowatts would you?
Atheus
7,313
BTW - I run a D-link DSL modem to a custom linux firewall system I developed for my dissertation (anyone wants info on this, i could talk for hours...), then a wrt54g v2.0 running hyperwrt or openwrt depending on my mood. One of my 54gs (the openwrt one) has the serial port mod, plus a heatsink added for overclocking.
One port of this router goes to a 16 port switch (mostly for friends' machines to plug into), another goes to my personal PC (overclocked athlon XP, 512MB OCZ CAS2, 9800pro) and another to my server. The server is a dual P3-S tualitan 1.1GHz with 512MB crucial registered ECC and a mix of SCSI and IDE drives. It runs modified debian sarge, a couple of websites on apache/php/mysql, mail server, mailing list manager, samba, etc. There is a secondary PC on the wired segment and a ghetto HTPC using another wrt54g in client mode to hook an old duron box from the lounge. That has a playstation controller hooked up to the parallel port which acts as a mouse and handy gamepad for playing emulated mario or final fantasy. I also have older athlon machines, a P133, some old sun boxes including a sparcstation and an ultra-1 with 300MB ram, but i'm not running them.
wexsmith
194
All on WRT54G
HTPC - MCE 2K5 (wireless - I'll get it on wired after I move)
- streaming video
- streaming music
- web
- ftp
- multiple concurrent remote desktops (two for the wife and I)
- used for long downloads or multiple downloads
My Desktop (wired)
- Gaming
- Internet/Email
Her Desktop (wired)
- Gaming
- Internet/Email
Bedroom PC (wireless)
- MCE extender pretty much...
Her Notebook (wireless)
- Work work and more work
XBox 360 (wired)
ProviaFan
14,993
This network is currently split between home and school, so I'll include comments on how things will be in a few months when I come home from school.
Home network setup: SBC 1.5mbps/384kbps DSL comes into an Efficient Networks SpeedStream 5100b, which will go into an as-of-yet-undecided router (I'm thinking about a Cisco 851W if the budget permits, but in reality I will probably have to choose the less-glamorous and more power-hungry option of using a PC for routing and just getting a wireless access point).
College network setup: a 100mbps network port on the wall. :p
Currently at home:
  • Athlon XP 1700+ / 1GB RAM / 40GB disk - parents' machine for web browsing and office tasks
  • HP iPAQ hx2750 - PDA which I bought for college but gave to my dad when I realized what a dumb decision that was; it's offline until I sort out how we'll do wireless at home
At college:
  • Athlon X2 4400+ / 4GB RAM / 36, 80, 300GB disks - my main workstation, used for school and photo editing
  • Powerbook G4 Aluminum 1.5GHz / 1.5GB RAM / 80GB disk - my portable schoolwork system (and photo repository when I go home for breaks or on trips)
  • Duron 800MHz / 0.5GB RAM / 40 GB disk - currently running Smoothwall as a firewall, NAT, and DHCP box, but hopefully will transition to dedicated Linux-based programming box this summer
WileCoyote
694
20/2 mbps Cox business cable internet
Dell 400SC: Windows 2003 Server Standard - 3.4ghz P4, 1GB ram, 74GB raptor
DHCP, DNS, FTP, VPN, Files, Printer
2 D-Link gigabit switches
1 D-Link 108mbps wireless router
Both pcs and server have Intel Pro 1000 MT adapters
Work PC - 3.0ghz P4, 2GB ram, 74GB raptor, 19" Dell Ultrasharp
Gaming PC - 4400+ AMD, 2GB ram, 150GB raptor, 2 7800GTs, 20" Dell Ultrasharp
Work laptop - Thinkpad T41
Girlfriend's laptop - Thinkpad R52
HP Officejet 7310 networked multifunction printer
Minolta 2300W color laser printer
HP 475 photo printer
3 external 250GB USB backup drives
Everything connects together for one big happy family.
mooseracing
1,711
Linksys cable modem to a Netgear PROSafe FR111P (router, firewall, print server), to a Dlink wireless router. Then my machine(xp64, used for gamin and occasional browising), my armada e-500 laptop just used for remote troublshooting/reapiring, roomates Dell P4 just a basic user, IBM Xsever 3U Quad Xeon 700mhz PIII's (webserver, sometimes a game server) and a Rockford OmniFi media streamer.
MulLa
1,755
Thought there would be a lot more people with Cisco gear in here...
Cisco 1841 with an ADSL2 WIC
Cisco Catalyst 2950T 24 Port Switch
Cisco Aironet 1200 802.11b/g Access Point
Still debating if I should get a PIX... eBay is evil!!! :|
Goosemaster
48,775
nice setup
MulLa
1,755
Thanks, took me a while to save up enough for them, but it was a great learning process building it all up. Tho there're a few more people here at work with more Cisco equipment than me :eek:
xtknight
12,974
How about simple and easy? :p
Wired network (100mbps CAT5):
Comcast HSI Cable 6mbps/384kbps-->Motorola Surfboard SB5120-->Cisco Linksys BEFSX41 NAT (100mbps router mode)->PCs\\one hub uplink (goes 'up stairs' through air ducts)
DHCP enabled on router (will also accept static IPs). Occasionally when I need to setup a server I'll forward ports to my LAN-level static IP.
I also use a dynamic DNS redirector service.
No software firewalls/IPSec/etc. NAT is firewall enough for me along with not opening e-mail attachments like a madman. Worth noting I tried the wireless (G) Linksys WRT54G, and the thing wouldn't transmit a signal through my ceiling, so I promptly returned it. No, I don't think I have lead walls or anything. Who knows. It worked fine right next to the thing though. :p
skyking
22,764
5,928
9 drops of cat5E in the walls, certified with an Agilent wirescope.
Dell 16 port unmanaged switch.
Firewall/router: Astaro Security Linux
two WRT54G with DD-WRT v23 in WDS mode, bridging to the repair shop.
nameserver: freebsd 4.11 with bind9
HTPC: Mythtv on Debian sid
two desktops in the office with xp pro.
4 port KVM for projects.
laserjet 4plus with j2550 network card.
n0cmonkey
42,936
My 4 Sun machines made me realize that. It's a PITA to close an ebay account.... :p
spidey07
65,469
does a hodge-podge of 11 cisco 2500, 2600 and 4500 series routers, some 3500/2900/5500 switches count?
no atm gear, that stuff is dead.
