Ryzen: Strictly technical
Page 63 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
PhonakV30
987
378
$160 for a motherboard and no custom P-states and broken fan control is simply unacceptable when my wife's $100 ASRock board has the same features and perfect fan control.
So other MBs does have custom P-stats? like Gigabyte and MSI ?
Reactions: Drazick
mat9v
25
Is there any way to make a custom voltage curve and bind it to multiplier? So I can have 1.15V for 3Ghz and 1.35V for 4Ghz?
JimmiG
2,024
112
To top it off their last BIOS update seriously broke memory compatibility. I went from being able to run 2933 to now not being able to post above 2133. I'm seriously considering buying a new motherboard that has better RAM support.
I would hold out for a few more weeks. There's another AGESA update coming out in May. If that doesn't improve the situation with your memory, then maybe switch to a different board (the way RAM prices have kept increasing, that's probably cheaper than getting different RAM).
I think Asus went a bit too far with the cutting of features compared to the C6H. They're mostly software-based UEFI features that they could have kept on the Prime if they wanted. I get it that they'd rather you pay more for the C6H, but it doesn't exist in a vacuum. There are plenty of other X370 boards from other vendors, with more options at lower prices.
Reactions: looncraz
Veradun
564
780
The Prime X370 is the first X370 or B350 motherboard I've seen without them.
And while I'm not ready to give it back to Amazon and get an ASRock instead (that was my top choice, but I couldn't find any K4 or Taichi here in Italy), I'm actually considering it, just to punish ASUS as they really underdelivered badly this time. I still have time, but Amz IT still as no choice of ASRock x370 MBs at correct prices :/
looncraz
722
1,651
Swapped the Prime X370 Pro with an ASRock Fatalwhatever Gaming K4. Generally better options, though not all fan headers can run in DC mode... only real downside I could find.
Did not resolve virtualization issue, so I will assume that we will just have to wait for the software ecosystem to catch up. Boot times, interestingly, decreased by about 5 seconds when using RAID (fast boot vs fast boot - most of the benefit occurring during Win 10 boot, so that could simply be a matter of Windows reorganizing its boot-time drivers).
Having full AMD extended options available, VRM temperature monitoring, and an extra M.2 slot makes it a pretty easy choice, IMHO... two of those things aren't even advertised, so you'd never know.
Dresdenboy
1,730
554
citavia.blog.de
I assume prices are the main concern. I got a Taichi via Amazon.de for € 266 (directly from ASRock) as they had it in stock. I think you should be able to get it EU wide, just not at US prices ($200+VAT).
Reactions: Drazick
Veradun
564
780
I can survive to 266€, but Amzn IT has it for 376€ :D
Reactions: Dresdenboy
Malogeek
1,390
778
yaktribe.org
The Asus Prime X370-Pro seems to be the red headed step-child of their AM4 boards. They focus almost everything on their CH6 and even their B350 gets more attention and updates, but more specially, their other boards didn't completely break memory speeds on the latest BIOS.
Reactions: looncraz
IEC
14,604
6,091
Buildzoid (Actually Hardcore Overclocking) reviews the VRM on the MSI B350M Gaming Pro (cheapest B350 motherboard):
https://youtu.be/3BYAdyO9nZo
TLDW: The board is 3+2 and at realistic maximum ratings (125C, 100A, 1.42V vcore) the board will be dissipating 22W of heat through the vcore VRMs. He is pretty critical of the FETs used by MSI (which are the same PK616BA and PK632BA FETs on all their AM4 boards) because they are 1) cheap and 2) inefficient. Which is actually okay IMO on a $69.99 motherboard (price has dropped since I purchased).
BTW I wasn't able to set vcore voltage higher than 1.40V on any EFI for this board, so MSI clearly knows the board's limits and added an extra margin for safety.
Reactions: looncraz
Magic Hate Ball
290
250
It's not great but for $70 that's still a great buy for a R5 1600 or less to pair with for overclocking moderately.
IEC
14,604
6,091
Yep, I have a Ryzen 1600 on the way and will likely be doing a modest OC using a Spire cooler to 3.7GHz all-core to match a 1800X stock (minus 2 cores, of course).
Reactions: Magic Hate Ball
Timur Born
300
154
Does someone have an explanation why 50% core-parking (aka CCX1 fully parked) nets slightly worse benchmark results for 7-Zip and WinRar single-thread benchmarking? Shouldn't it be the other way around with the level 3 cache being utilized on a single CCX?
krumme
5,956
1,596
Robert Hallock explains the various settings related to high speed memory overclocking and what they do. From the press event with MSI in Austin, TX:
https://www.youtube.com/watch?v=vZgpHTaQ10k
Ok good vid.
Takeaway from ram is soc voltage at 1.1v ram voltage at eg 1.4 to 1.5 no probs. But keep soc high.
For cpu never go higher than 1.45 to remain longterm life.
That pretty high btw. So people shouldnt be scared of eg 1.42v considering lifespan.
Rifter
751
Yeah if they dont get there shit together with the next bios update or two im selling it off and buying a ASrock.
JimmiG
2,024
112
It's ridiculous that Asus have reps answering questions and giving support for the C6H in forums threads, but they don't give a crap about the Prime. Sure the C6H is $100 more, but I thought that was only supposed to buy you more hardware features, not a private tech support team from Asus.
looncraz
722
1,651
Cache aware algorithms expecting access to 16MB of L3 cache and allocating pools that are larger than 8MB.
Reactions: Aenra and Drazick
Timur Born
300
154
Wouldn't that be a problem for both cases, 50% parked and everything unparked? It's still 2x 8 mb cache instead of 1x 16 mb regardless of whether both CCX are active or only one, isn't it?
Dresdenboy
1,730
554
citavia.blog.de
The interesting part is that these are single threaded tests. so that one thread could never fill and then use the 8 MB L3 of the second CCX, regardless if it's active or not.
It's a victim cache. So if one CCX is completely parked, no core would fill the associated 8MB of L3 by throwing out L2 cache lines.
looncraz
722
1,651
This is when kernel thread leveling acts to improve performance by forcing both L3s to have the data. If a CCX is parked, it will never have the data.
Status
