Ryzen: Strictly technical
Page 43 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
Gideon
2,044
5,103
Anyone seen this?
https://www.reddit.com/r/Amd/comments/60g5cj/windows_10_update_on_16_mar_have_partially_solved/
Reportedly Windows 10 update on 16 Mar has partially solved scheduler issue
Before:
After:
Can Anyone with Ryzen confirm?
tamz_msc
3,865
3,730
Excuse me but this is implicitely displayed and can be computed this way, say in the 2.1-3.3GHz range.
Frequency ratio is 33/21 = 1.57
Squared voltage ratio is (1010/710)^2 = 2.023
The product of those two values is the ratio of powers from 2.1 to 3.3GHz and is equal to 3.177.
Hence the degree of the polynomial is :
Ln(3.177)/Ln(1.57) = 2.56
o_O
You're trying to calculate a polynomial fit for a curve that doesn't exist in the first place? And what you're doing here is subsuming voltage-dependency of power consumption to show it as a polynomial function of frequency.
And FYI taking logarithms of ratios and dividing them is NOT how you do polynomial regression.
Intel process has a value that is close to the theorical optimum of 2, so their power scaling is significantly better..
The mathematical jugglery you do to claim this requires the ratio of the increase in voltage to be the square root of the ratio of the corresponding increase in frequency, in the linear range of the voltage-frequency curve. Show me this data for Intel CPUs and I'll believe you.
CB scale linearly with frequency and core count, that s why despite being ICC compiled it s a very valuable bench to test a uarch evolution..
From your own source, B&C,
frequency vs CB scores
3.0->1338
3.2->1393
3.7->1593
3.9->1690
it is obvious that scaling isn't perfectly linear.
Abwx
11,996
4,954
o_O
My calculation is accurate, in the considered range for 10% higher frequency power increase by (1.1)^2.56...
You can easily deduce the respective contribution of frequency and voltage for Ryzen..
Here it works because the considered segment is a straight line, this mean that the exponent is constant in this range.
This can be easily checked with the multiple CPUZ captures here and there, do your homework like i did, because i m not throwing random datas on this point but verified numbers..
3.0->1338
3.2->1393
3.7->1593
3.9->1690
It should be quasi linear, if it s not then the test wasnt perfectly done such that the conditions were strictly the same;
DrMrLordX
23,174
13,262
Anyone seen this?
I am getting 15061 as we speak (finally!) so I can do some testing, but before/after will be impossible because I'm patching out before as we speak.
edit: looks like the update is failing, not sure why. Grr.
JimmiG
2,024
112
Speaking of Baghdad Bob, any proof of this supposed miracle patch, like a KB article or something? Or did it just materialize out of thin air?
iBoMbY
175
103
86
Anyone seen this?
Before:
After:
This seems to be fake, probably pinned manually. If I create 8 threads on my Ryzen, it still distributes them over all logical cores. It only looks like it is trying to avoid SMT core, but the spikes are all over the place.
Edit: This is what it looks like with 8 Prime95 threads for me:
imported_jjj
660
430
It's app specific, Fritz wasn't behaving properly before,maybe now it does.
Are you testing with or without the Win update?
lolfail9001
1,056
353
Looks normal to me, basically load being spread on 1 physical core per thread. I would say it is painfully obvious even.
You can't and won't get rid of thread migration in Windows without manual affinity setting, so forget it.
The provide them. It was bad enough when you ignored silicon lottery in it's entirety comparing BC and Stilt's numbers.
Considered segment being straight line means exponent for freq/v is around 1, not whatever you made up, because it is linear. For power/freq it follows it is about 3. Gets trickier considering that linear scaling has it's offsets, but whatever.
23,102
1,551
With respect to the upcoming 1600 , 1500 and 1400 ryze models.
What got me wondering, with a ccx being a quad core and having 8 MB L3 cache, that cache is partitioned to at least 2MB for each core. Otherwise, hypothetically one core would use up all the L3 and the others would have none and the L2 tags needs storage as well. It got me wondering that when AMD has a 2 + 2 configuration or 3 + 3, the usable size of L3 for each core must increase as well. For only 2 cores per ccx, that seems easy.
4MB for each core. But with 3 cores for each ccx, 2 2/3. Which is not a binary number. I wonder how the cache is setup in these cases. Would it be rounded off to the first binary number ?
I mean, hypothetically a flexible format where one core could use all of L3 (with exception of storage for L2 tags for the other cores) when other cores need none, (An ideal situation that would never happen) and then suddenly other cores need the L3 victim cache as well, then there would need to be a policy of what is still left in the L3. I assume after L1 , L2 is checked and then L3, If not present, go to dram. That would cause weird timings in threads that run.
Reactions: looncraz
iBoMbY
175
103
86
I have the latest standard updates for Windows 10 (whatever Microsoft thinks I should have). But it doesn't look like they changed anything on the scheduler, if anything someone changed something on Fritz Chess ...
imported_jjj
660
430
Bits and Chips got a large gain in UT3 so it's looking llikely that something changed.
bjt2
784
180
86
The last update is the one that behave correctly, so it's normal what you have seen. You should have performed same screenshot before the update...
JimmiG
2,024
112
Some are saying the update is only part of the latest Fast Ring Windows Insider Build. I'm calling BS on this since there's no documentation anywhere about any changes to the scheduler. Just a forum post on some Chinese forum.
KB4015438 is the latest regular Windows update, and it just replaces KB4013429.
This update includes quality improvements. No new operating system features are being introduced in this update. Key changes include:
Addressed a known issue with KB4013429 that caused Windows DVD Player (and 3rd party apps that use Microsoft MPEG-2 handling libraries) to crash.
Addressed a known issue with KB4013429, that some customers using Windows Server 2016 and Windows 10 1607 Client with Switch Embedded Teaming (SET) enabled might experience a deadlock or when changing the physical adapter’s link speed property. This issue is most commonly seen as a DPC_WATCHDOG_VIOLATION or when verifier is enabled a VRF_STACKPTR_ERROR is seen in the Memory dump.
Changing the scheduler to work better with Ryzen would be a "key change", no?
Status
