RX 480 PC Crash issue (*Headache*)
Jan 31, 2017
65
As long as it is powered by a 6-pin connector it should be alright. If you're from India, then Zotac is usually the best in terms of warranty and price.
Alright. Thank you for the help. :) But, I don't know why other users also face the same issue like I'm am. What about the quality of the ZOTAC cards and cooling?
Sent from my iPhone using Tapatalk
tamz_msc
3,865
3,730
Zotac is good. It is very popular in India, you can say that it's as popular as EVGA is in the US.
I'm not sure about the problem you're having with the RX 480, but I'm inclined to believe its related to power delivery.
Reactions: Balakrishna Prasad
Jan 31, 2017
65
I'm really disappointed as this is my first ever built PC. I must have took some time in picking up a good PSU though. I chose RX 480 because of its features like DX12, Vulkan and Async but I didn't know it requires more power that my PSU can't handle it. Anyway, thanks pal.
96Firebird
5,749
345
As a last ditch effort before blaming the graphics card, run something like Prime95 to re-test the CPU/RAM isolated from the GPU and make sure those aren't the culprits. I'd hate to have you get a new card, only to have the same issue again.
Jan 31, 2017
65
Alright, I will run them again. I think I need to blame my PSU first.
I don't know, right now I'm on my PC, re-installed WINDOWS 10 freshly. It is weirdly slow and lagging sometimes! It's like 1GB of RAM. I mean even after fresh install? (Also happened before). I reset my BIOs and cleared the CMOS. Is this could be a cause of bad PSU or else something? No GPU is installed.
Tweak155
11,449
264
Have you tried pulling the GPU and running on the onboard graphics? While not an ideal test, it would really only help you rule out memory. I doubt power draw would be anywhere near as high.
Also a 600w+ PSU is plenty enough for either RX480 or GTX1060, I think what is being questioned is the quality of the particular unit you received. Once you start building and you stick with it, I think naturally you'll have an extra PSU or 2 for testing this particular problem. It can happen, but generally is more frequent with no-brand names or "budget lines" from brand names.
Jan 31, 2017
65
I have tried everything pal. No problems while using iGPU. Nope, I don't have any extra PSU to test out. Currently, I am using my PC without GPU. I re-installed Windows 10 and is acting weird right now. No apps installed just installed the Drivers. Is PSU a cause?
Tweak155
11,449
264
PSU is a possible cause. Based on this I would start with a replacement GPU. It's hard to know for certain without either a spare known working video card or a spare known working PSU. So, you have to take your pick and go with it.
Jan 31, 2017
65
Pal! Just now, got some BSOD error! Indicating 'BAD_SYSTEM_CONFIG' after reboot. I'm feeling really bad. It's my new PC! Been on my PC since morning figuring out the problems.
Jan 31, 2017
65
Nevermind! Everything is fine unless I use the GPU.
tamz_msc
3,865
3,730
As a last-ditch effort, before you replace the card, you can try this - if the card came with a dual 6-pin to 8-pin adapter, and I think the ASUS STRIX does, could you try to see if connecting both the PCI-e connectors from your PSU to the card helps in any way?
Jan 31, 2017
65
No pal, I didn't get any adapters with 'STRIX'. And I tried both the PCI-e connectors that came from my PSU. Nothing worked. I have already returned my card and I'm not willing to replace it. I want to get 'ZOTAC GTX 1060'. I think the RX 480 is a faulty card which requires more Driver Development efforts. Thank you for your suggestion. :)
Bouowmx
1,150
553
Jan 31, 2017
65
Lol :confused:
My specific data point: I have a PowerColor Radeon RX 480 4 GB Red Dragon with power supply Rosewill Valens-500 grinding energy-intensive RC5 well: http://moowrap.net/show_host_detail.php?hostid=732334 and its tasks.
Anyway, if you insist on ZOTAC GeForce GTX 1060, I suggest the AMP! Edition with 2 fans to maintain high Nvidia GPU Boost frequency.
Yeah, I chose 'AMP! Edition'. So, you are saying, you have not experienced any crash even with 500W PSU. Am I right? :p
Bouowmx
1,150
553
So is it a faulty GPU I have got? :p But why the amount of power doesn't matter?
Typical load power (W): 65 (CPU) + 150 (GPU) + 50 (rest of system: RAM, motherboard, storage, etc.) = 265: lots of headroom in power.
Although I did say amount of power is not an issue, power supply still cannot be ruled out: harder to check is quality of power.
Anyway, if you get a new GPU and similar issues come up, power supply is a likely culprit.
SlickR12345
542
44
www.clubvalenciacf.com
So, GTX 1060 can be handled by my PSU? I am thinking to buy a ZOTAC GTX 1060 6GB. Is that good or else should I choose MSI?
That is nonsense, don't listen to him! The PSU can deliver up to 50A or 600W on that V12 rail. Its 99.9% your GPU. You've gotten a faulty one, it happens quite often actually. Just RMA it.
Jan 31, 2017
65
I honestly doubt my GPU. Major people who owns RX 480 are facing this issue. No matter what GPU Brand. I have seen videos on YouTube, and some guy who uses 850W from Corsair is still facing the same issue like me! So, it's not the PSU, Mobo or anything, it's the GPU as you said. I have tried many things until my two hair pieces fell off (Tested very hard). It's really a mystery why many users are experiencing the same! I doubt the 'AMD's RX 480', there's something weird going on with the cards. I am really disappointed with AMD. :(
Jan 31, 2017
65
Alright, will check out and post the reply after the test. :)
Jan 31, 2017
65
Did you try switching the PCI-E slot?
Oops pal, I don't have room in my case to fit the card in the other PCI-e slot which is nearer to the drive bay. Anyway, I've returned my card and getting a NVIDIA Card as soon as I get my refund.
bystander36
5,154
132
The one common theme I keep hearing is people disregarding a product failure. Just because PSU is rated for such, and should work, doesn't mean it wasn't defective. Just like GPU's, PSU's can fail.
On a new build, it's really tough when something doesn't work right, as everything is new. If you still have the system you had prior, you could use parts from that system to test things out. Without spare parts, this is a very difficult diagnosis.
[DHT]Osiris
17,565
16,925
Please keep in mind that not all PSUs are made to the same quality, some are trash and have fun effects such as:
Coil Whine
Failure @80% rated capacity
Fire hazard
Completely incorrect voltage delivery
And much more...
That power supply in question (Corsair VS650 650W) doesn't appear to be purchasable from the US newegg, (and in fact I can only find it on amazon.in) which raises a few eyebrows, and would encourage me to not purchase it. I'd personally be eyeballing that thing very closely.
