Rumour: Bulldozer 50% Faster than Core i7 and Phenom II.
Status
Not open for further replies.
veri745
1,163
4
Yea I bet grandma is really going after an 8 core processor.
What about the 95% of people who never use a program that utilizes more than 4 cores?
Clever marketing by AMD, but not a real-world situation.
Not only did people say the same thing about quads when Ph I came out, they said the same thing about dual cores when the A64 X2 came out.
BLaber
184
A BD module has 2 cores but , comparing 4 BD module to 4 I7 core + 4 Ht threads is not apples to apples comparison because of huge difference in design philosophy of both the BD & I7 processors.
I guess the best way to compare performance is to compare die size of 1 BD module vs die size of 1 I7 core + ht thread for that core. :)
Wreckage
Banned
Jul 1, 2005
5,529
If Grandma uses IE8+ or Chrome then she is using a program that does utilize more than 4 cores. Especially if you mix in running apps/video with Flash, Silverlight, or Java inside the browser.
o_O
Maybe she should switch to Firefox which runs just fine on an ole P4.
Seriously if you are trying to sell someone on an 8 core CPU for the internet.... I'm guessing you are just being sarcastic.
Edrick
1,939
230
No, this is not true, they are all full cores. Every integer core has its own FP unit (actually a more powerful FMAC.)
It will be 8 cores, 8 threads.
Thanks for clearing that up. So an 8 core CPU is 50% faster than a 4 core CPU with HT. Clearly that is good news for AMD as it will be a nice performance boost. And even though I am happy with Intel, I would like to see more price wars.
But, based on those numbers (if true), means that an 8 core BD would be on a performance par with a 6 core SB (without HT enabled).
Now the question is will that 8 core BD be much cheaper than a 6 core SB.
Edrick
1,939
230
Or compare 1 BD core to 1 Intel core with HT turned off. :) At least if you want to see the IPC differences.
piesquared
1,651
473
Ya AMD said the same about Phenom I didn't they . Slides are still in those old topics.
Hey, could you ask your hero 'Bob for apples' why hardly any vendors want anything to do with oak trail? I thought you and big bad Bob claimed it was the second coming of Christ.
HW2050Plus
168
You seem very certain about something that hasn't been released, much less benchmarked.
Right. But the architecture has been released by AMD and there are some clear design informations, showing that Bulldozer will double the core count (simplified), in addition it is known that Bulldozer will run at 4-5 GHz (4.5 GHz would be a good guess which comes from 3.2 GHz * 23 / 17 [pipeline design FO4 count] + 5% [from 32 nm]).
It is quite a simple assumption that double of cores will give 70-100% gain. That is something we know already. So nothing magic with that. That is why one can be certain at least if overall performance is regarded. If it is better in a certain application or another I really can't tell. That and the exact performance gain within that range has to be shown by benchmarking the released product. As current rumors indicate, it would be at the high end of this range, but that is just based on rumors.
OBLAMA2009
6,574
er, uh, you dont fire your ceo for producing a chip that outperforms the competition by 50%
HW2050Plus
168
The beauty is that they are about the same.
Just look at IBM Power 7 processor. AMD is not first using this "module technique" and not the last. Intel will be heavily forced to make this design step as well (as they followed with 64 Bit/integrated memory controller/processor interconnect/L3 cache etc.).
exar333
8,518
8
Pure speculation. Please provide evidence and/or links to support these facts...HIGHLY doubtful of a 70-100% gain. Not going to happen.
Makaveli
5,004
1,600
Its all heresay right now no one has any concrete numbers and most are working with theories!
RussianSensation
19,458
765
1090T @ 4.0ghz easily got 7.0 in Cinebench R11.5.
980X @ 3.33ghz = 8.95
2600k @ 3.4ghz = 6.88 (Bit-tech)
i7-950 @ 3.06ghz = 5.57 (Bit-tech)
If we assume perfect "core" scaling from 6 core Stars Phenom II to 4 core/8 modules BD, that's 33.3% increase. I am going to be conservative and say it will only be a 20% increase. Let's assume BD will net at least a 10% increase in IPC over Stars (again on the conservative end).
On 45nm, 1100T is already at 3.3ghz with 3.7ghz Turbo. This means getting a 3.8-4.0ghz BD at launch is not out of the question on 32nm.
3.8ghz BD x 20% increase in cores x 10% increase in IPC = 5.0ghz Phenom II X6.
This would get us closer to 8.8 on Cinebench R11.5 with a stock BD.
Here is your 50% increase over i7-950 without breaking a sweat in a multi-threaded app and performance right near 980X.
And these are very conservative estimates on my part.
nyker96
5,630
I think if all the speculation on the street is true, then each BD core is roughly equal to 3/4 of Nahalem core. roughly, an 8core BD = 6core 980X roughly. maybe slightly less. so I conjecture that since SB is about 15% stronger IPC than Nehalem core, I'd say
1 BD core = 0.6 to 0.65 SB core.
so ::
an 8 core BD = 5 core SB
6 core BD = 4 core SB
4 core BD = 2.5 core SB
SolidSnake42
261
I'd just love to see what this bad boy can do when all the sites start doing their own tests. I've used both AMD and Intel in the past, so I have no biasness. I would love to see AMD get up there though and be competitive, neck and neck with Intel to make things fun, interesting and provide more and better choices. I'm used to being one sided for console wars, but when it comes to processors, I just go with what better suits my performance needs and even if I pick one over the other, I want the other to do well too. But if we can expect these kind of given performance stats, then give AMD props to really try to push themselves to do what they can to go toe-to-toe with Intel.
Daedalus685
1,386
His removal/firing/resignation/whatever likely had nothing to do with any single product at all and more to do with business strategy differences between him and the board.
Matrices
1,377
Whoever can open up the bottleneck of GTX 580 Tri-SLI at 2500x1600 (or equivalent-level performance) will win my money. At that resolution, and with those cards, the best i7 processor is still a hard bottleneck in a number of games, according to GURU3D.com.
Edrick
1,939
230
Exactly. He thought BD should have been released in 2009. The board thought 2011 was better. :)
Edrick
1,939
230
Including a 980X and 2600k?
RussianSensation
19,458
765
Send one of those 580s to me. And your bottleneck will be solved. :wub:
Makaveli
5,004
1,600
considering 4 current intel cores matches 6 amd cores who really made the poor design choice?
SB-E 6 - 8 core version will be coming out around the same time and this will be competition for BD not socket 1155.
christmas 2011 will be an great time to build a new system.
Status
