Right, so you want to prove that overclocking does damage by linking to an article demonstrating how over-volting does damage? You don't need to over-volt to get a 300MHz increase, and a 1-2C increase in CPU temps won't degrade a chip. At this point, if you're gonna argue about temps, room temperature will make more of a difference than the OC. A mild OC on stock voltage won't do anything to a chip.
If it's machines in a home office or home business you're gonna support yourself instead of an enterprise, there's no problem with a mild OC.
But leave it to you to spread paranoia and BS.
maybe you should read the article jackass
"Too many people believe overclocking is "safe" as long as they don't increase their processor core voltage - not true. Frequency increases drive higher load temperatures, which reduces useful life."
