Rumour: Bulldozer 50% Faster than Core i7 and Phenom II.
Page 112 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
drizek
1,410
I built a Linux box recently, 160$ for 1090T, 100$ for a 880G AM3+ mobo and 70$ for 8 gigs of ram, around 330$, 6 real cores, runs my virtual machines like a champ.
Except for your OS X virtual machines.
Feature-wise, K10.5 is in the stone age.
dali71
1,117
21
You also seem to forget the 45% difference in price. That, and the difference between finishing an editing job in 26 minutes and 30 minutes isn't really significant.
Using your numbers, if you do editing 8 hours a day, you would save over 5 hours a week, or over 260 hours in a year (assuming 2 weeks off for vacation). Seems worth an extra $70 to me.
LOL_Wut_Axel
4,310
8
Same thing could be applied to getting the 2600K over the 2500K and the i7 970 over the 2600K and dual Xeon X5675s over the i7 970. It's an endless argument.
People have a budget. You seem to forget this. Not only that, but platform costs for AMD are also lower. What you end up with is a difference that's in reality closer to $100, which may make a huge difference in terms of what can be bought and how you look at its relative performance. The Phenom II X6 1055T is great bang-for-buck for these applications at its current $140 price, especially since it can be OCed to 4GHz.
bridito
350
Granted, and as a guy who spent a fair amount of his youth trying desperately to figure out how to make the rent payment, I am not going to argue that every computer user should throw cubic money at their next CPU. However, it's a matter of value for use. If a computer is used just to check email and mess around on Facebook (as many people do) then blowing a wad on a powerful CPU is a total waste of cash. However, in my personal case, I spend anywhere between 10 and 12 hours a day in front of my PC, seven days a week. A bare minority of that time is goofing off, the rest of it is in working to make a living. I put in an absolute minimum of 50 hours a week in PC work. I've had my i7 940 for about 2.5 years, so I can confidently say that I have spent well over 6,500 hours making money on this CPU. If I had spent, say, $250 more on the CPU it would amortize to less than 4 cents per hour. Is that 4 cents worth spending if it makes some complex functions faster to execute? With the rate I charge my clients, if I save one second per hour I've broken even on that 4 cents. That's why I'm fully expecting to pay around $500 for my next CPU which will last me another three years or so. The extra cost from a less capable processor is likely one of the best investments I'll ever make.
LOL_Wut_Axel
4,310
8
Hmm, I'm not quite sure I understand what you're saying. Didn't the Core i7 920 and the 940 OC the same? I mean, considering the 920 was half as expensive, it made more sense since if you were OCing you'd get the same performance from both.
bridito
350
Fortunately or unfortunately I'm in the vast majority of computer users who do not OC their CPUs. My primary reason is to keep the noise level way down in my system. When you're working the hours I do, the last thing you want is to put up with drone coming from the various fans. I have my side cover off my midtower and have a "reasonably quiet" HSF fan on my Arctic 7 Pro Rev 2 as the only airflow device. As it is I'm topping out at around 75C under load. I certainly don't want to do anything that adds more heat and thus requires more airflow, although for my next system I'm definitely eyeing the Noctua NH-D14 or similar top ranked HSF. But I'm still not going to OC it. ():)
LOL_Wut_Axel
4,310
8
If you want something cheap and effective nowadays you can just get something like a Corsair A50. Better than the Hyper 212+ and cheaper. For something higher-end I'd recommend the Scythe Mugen 3. It's the same heatsink as the older Mugen 2 except for a bit more depth and one extra heatpipe. It's only $40 at Directron and only 3C off the NH-D14. The fan is even quieter than those of the Noctua.
You could've gotten a 920 and did a stock voltage OC to 2.93GHz. That would probably only rise temps around 1-2C over stock, thus requiring no additional cooling.
Abwx
12,027
4,989
At 180$ a 1100T is 30% more expensive than the 1055T but with
a frequency increased by about 20% , a rare case where the extra
performance is almost proportionnal to the price difference..
Still 20% cheaper than a 2500K and better in multithreaded aps.
LOL_Wut_Axel
4,310
8
At 180$ a 1100T is 22% more expensive than the 1055T but with
performance is proportionnal with the price difference..
Right, but the 1055T OCs the same as the 1100T, and on the stock cooler you can take it to 3.3GHz on stock voltage. If you don't have a good air cooler you can just get a $21 Corsair A50 and push for those 4GHz.
bridito
350
Believe me, I'm well aware of the benefits of OCing as I've been lectured to by dyed in the wool enthusiasts for several years. Still... not for me. ():)
ed29a
212
You are right. Assuming I run OS X, none of my OS X virtual machines will run on it. Good thing is, I have exactly zero OS X virtual machines and I am planning to run exactly zero OS X virtual machines on my server.
Runs Linux? Check.
Has hardware virtualization extensions? Check.
Fast enough for me? Check. Hell, I am thinking of undervolting it to consume less power, speed is not what I need. Cores are.
Has lot of real cores? Check.
Cheap? Check.
Is it the right tool for my needs? Check.
Motherboard is sort of future proof? (AM3+ socket)? Check.
I could have gotten a six core 1136 socket chip and the CPU alone would have set me back almost double in cost vs my entire system. Not to mention 1136 is dead end as well. Or I should have waited for Bulldozer/SB-E and wait, and wait and wait, seeing that both are delayed? Just because Thuban core is not the second coming of Jeebus, it doesn't mean it can't do the job well. The difference between Thuban and something else means I can actually get a nice SSD to go with it. Or two ...
LOL_Wut_Axel
4,310
8
Hmm... :colbert:
Efficiency improves with stock voltage over-clocks. I OC the CPU on my LAPTOP from 2.8GHz to 3.2GHz with no ill effects (well, aside from a rise of 2C in temps) and I can get things done quicker.
But hey, whatever floats your boat. :)
Phynaz
10,140
819
Hmm... :colbert:
Business use dude. Not worth the risk. Ever.
bridito
350
Just to be clear about my position and I want to state that I certainly don't wish to offend any OCer... but I'm not going to void my warranty on my business use computer. So I'm perfectly happy shelling out a hundred extra bucks or so and getting a more capable CPU which runs out of the box at the speed that the less expensive OCd one would. OCing is great, it provides wonderful results, but with all due respect, I still won't OC. :)
Cogman
10,286
147
Then why don't AMD/Intel just sell the chips at those frequencies?
Not enough demand at that price for those frequencies. If a Fabbing process is particularly good, it is possible that most chips on the wafer are capable of hitting the highest speeds. However, They still have customers that demand lower prices for their CPUs.. AMD and Intel can't just ignore that market space, so they cripple those CPUs on the wafer and sell them at a lower price. This way, they don't waste money on chips that never sale.
Voo
1,684
That can't happen if the OC is stable, a lot less so on a moderate stock voltage OC.
And you retest your CPU every few months to avoid any regression? If you do, that's fine - but many people would not and in that case OCing and sensible data don't mix.
jvroig
2,394
When talking about enterprise-class reliability (i.e., for business use), there is no way for us to achieve a "stable OC". Only Intel and AMD have the tools to do a real CPU test (that achieves significant coverage) to determine, beyond just usual use cases, that something is truly stable for a particular clock-speed, voltage, temperature, and time/period/duration (years).
All our "enthusiast" stress-testing tools like OCCT, Prime95, LinX, etc., don't really cut it. They do not get significant coverage, and are little more than "max operating temp testers". This is why you hear over and over again stories of overclocks being stable in [Prime | OCCT | LinX | whatever ] for hours, but then crashes in another tool, or in a couple of games.
I try to delude myself by relying on AMD's Overdrive utility, convincing myself that it seems to do a wide-range of tests and must have been designed by AMD's CPU engineers so it's possible that it might actually be getting enough coverage. While it has not bitten me back yet, I have no illusions that it is a substitute for the real tests done at AMD/Intel labs, so still no good for any business/enterprise reliability needs.
LOL_Wut_Axel
4,310
8
From what I'm reading all this sounds to me just like panicking over a 0.0001% chance of something going wrong. I'll believe a 300MHz OC on a modern CPU at stock voltage can cause havok on hardware when I see it.
Status
