MagnusTheBrewer
IN MEMORIAM
Dude, do you even bucket?
Flex Seal!
Maybe he could point a space heater at the bucket, thus causing the water to evaporate at a rate approximately equivalent to how quickly it fills.
OK hotshots, you think you're slick? Answer me this...
A madman has rigged OP's house with explosives. OP must empty out exactly 1 quart of water or his house will explode. He has been given a 2 quart and a 2 gallon bucket, as well as a leaking pipe.
assuming he has a clock, time the amount of time it takes to fill the 2 qt bucket. dump it out, and fill it for half the time.
Fill the bucket halfway? Assuming the 2 quart bucket is shaped like most liquid-containing-objects and is symmetrical, it's very simple to fill halfway. Doesn't require a cylinder, just horizontal symmetry (vertical line split). Examples below.No clock. As I said, OP only has a 2 quart bucket, a 2 gallon bucket, and a leaking pipe.
If you need half a quart:
Sounds like some asshat that's just trying too hard to kill people.Well, it was a madman who rigged it all up. I assume he used some weirdly-shaped buckets.
its a GD relief valve? thats a 5 to 10 min fix with a part from home depot or lowes or a hardware store.
If you have a two gallon bucket, and a two quart bucket, how many buckets do you have?
I have a small drip leak in the basement (relief valve). I put a 2-gallon bucket under it. If I put another smaller 2-qt bucket within that bucket, does it allow me more volume before I have to clear it?
