Durvelle27
thx for all the help just hope the speaker wire fixes my problem
when i did the test the receiver didn't shut off till the rear speakers were connected
might see if walmart has 12awg full spec copper in the store also
I'm still suspicious that you have a ohm problem, potentionally due to a bad speaker. Did you try using different speaker combinations? I.e. Just front, just rear, just center, etc. Unless the problem is related to wiring or a speaker, you might have a bad reciever.
yes i did that and it worked fine until the volume was raised
when i was doing it i never had a problem with 0nly 2Ch 2speakers connected it was fine
volume like -5dB 2CH and 3CH are the only setups that are working when i did what you said
