Card works fine otherwise using older drivers.1.) Did it work correctly after installing the drivers from the AMD site rather than the one from microsoft update?
2.) Are you sure that the card isn't the culprit? Maybe the card is already dying
:thumbsdown:ATI drivers are still shit, why? because an Anandtech ADMINISTRATOR said so.
I mean like.. hell, if even an Anandtech Administrator cant vouch for ATI drivers, they must be just terrible, in fact they are WAY worse than Nvidia drivers.
Nvidia as the only other competitor to ATI in discreet cards is just gotto be incredibly good to make such good drivers.
Anyway Gillbot, welcome to 2011, its AMD not ATI. That also goes for drivers.
Basically, Yes.so this thread is to warn people not to use windows automatic update if you have an amd card?
Thank you for at least a worthwhile reply. While my intention was NOT to troll, it seems as though no matter what you post here, it's taken as such and you are attacked by the other camp right away.The short answer is "no."
To elaborate I think AMD drivers are now stable then ever before but video card drivers in general are still very volatile. When you updated through the Windows Update you probably ended up with a bad install of the drivers. Over the years I have learned video card drivers are something I would rather not mess around with if I have a working build and that has saved me a lot of time and trouble. Always go for latest drivers from the site, this cannot be stressed enough regardless of what company you card comes from and never update through any other procedure than getting the new drivers from the AMD/nVidia website.
It seems as though in my experience, a bad ATi update means a new windows install whereas a bad NV update I could just roll back or install a different one and be fine.
I don't have this problem at all. I had issues when I was running frankenfire setup mainly with BSOD's.. but safe mode+ uninstall + rollback always worked for me as of today.
I've actually heard of more problems with recent Nvidia drivers than AMD drivers.
I swear we wont ever see a topic made by (and lets use your own words here) "the other camp" where they admit to having good experiances with drivers that are not of their color, as apparant in this topic.
NO, they are much better than they used to be. Honestly.
Let me give you a recent example with my HD 6990. It failed in my X58 MB and AMD's advice was to move it to another MB. Well it works fine in my Phenom II MB but when i move it back to my Intel PC, it BSODs the systemI think some combinations of hardware (esp motherboard, soundcard) may have more issues with some graphics cards than others. My experience with Nvidia drivers in last several years has been stellar, which is one reason I'm in Nvidia camp. BUT I have seen several people complaining in driver forums using same card, same drivers as I was, albeit diff mobo, hardware. So I can only assume its that, diff hardware combinations are not as 'synergetic' as can be and/or drivers conflicting with other hardware or even software.
AMD has acknowledged that my problem is not unique. Unfortunately, i do not believe they will replace or repair it so i am stuck with it in a Phenom II system
(980BE at 4.3GHz) and can no longer bench it in my flagship PC.
I lean more toward AMD/ATI but I have had many nvidia cards too. My last being a 9800GT. My current ATI 5770 was a real PITA when I first got it, the drivers were freaking horrible. I had to go back 2 revs before I it stable. I havent updated the drivers in nearly a year because its stable right now and plays what I need well. IMO, just because there is a new driver doesnt mean you need it. I too miss Matrox and 3dfx and stb and competition in general. Now its just like PC vs apple.
My first battle was a pair of 3870's in crossfire. No matter what I tried with those things, they would NOT run stable regardless of the drivers I tried. Granted, that was LONG ago but it put a bad taste in my mouth. My next attempt was 4870x2's and it ended just as badly fighting crossfire issues and drivers. One set would work great until you'd enable crossfire, the next set wouldn't crossfire but everything else was super stable. I couldn't win.I ran two 4870's in crossfire for two years and a half and only had issues with one driver, 10.6 IIRC, I did some stupid things with the cards though and experienced additional issues, but as soon as I did a clean driver install the problems were gone.
I'd start again from scratch if I were you, and as far as cf is concerned, the 10.4 offered the best performance for my cards, nothing ulterior added anything else.
My apoligies IDC 🙁
hmm, what i ment to say was that anecdotal stories about ones failure with hardware or other things, really should be kept to oneself, unless you need help, i dont interpret this topic as such.
Another poster asked if the purpose of this topic was to "warn others to not use windows updater if you have a radeon card", and the OP said yes.
WHy isnt this reflected in the topic title?
What is reflected in the topic title is this: Are radeon drivers still THAT bad. Thats it. And the OP clearly knows where this is going, including a disclaimer of not wanting to start a flame war. Im no fanboy, just a critic of how somethings are presented and thus how they are (in the end) interpreted.
Do i read too much into it? maybe. But then i would either call you naive or think of you as not too bright, depending on your argumentation.
Gillbot, they are AMD drivers, if you install the latest Catalyst/radeon drivers, it is AMD who makes them, your card is irrelevant, as long as its included in the support list. Why do you insist on dragging your previous ATI experiance over to AMD?
What im trying to tell you, for the second time, is that things have changed, and while "things" have changed, you are arguing that you NEVER have had luck with ATI drivers. Wheres the sense in that?
Finally:
I challenge you to post when you have worked out which driver to install and tell us of your experiances with the card and driver issues Gillbot. Once you have the system up and running, do you experiance problems, or is it silky smooth?
AMD sent my HD 6990 directly to me for review; i am Editor-in-Chief for AlienBabelTech.If they do not replace the card i would go postal, you spend that much cash on something it better work properly. Which AIB made the card? most have decent customer service.
AMD is ignoring me and my requests for a replacement or repair as somehow it was my fault. This is same company that got the HD 6990 tested with the AUSUM switch by all of the tech sites - and after the results were posted versus the GTX 590, AMD changed their minds and refused to warranty it if the switch is flipped.
Well, we overclocked it (only for the review) and it failed a few months later and now i think i'd like to do a YouTube video and a creative way to destroy it; Shotgun blast sounds good and a HD 6990 funeral with full honors
:whiste:
